ملف اكثر من رائع عن Centrifugal Pumps: Basic Concepts of Operation
النتائج 1 إلى 10 من 69
    الصورة الرمزية Eng-Maher
    Eng-Maher
    Eng-Maher غير متواجد حالياً
    مشرف قسم الهندسة البحرية.
    Received: 104
    Given: 408
    Centrifugal Pumps: Basic Concepts of Operation, Maintenance, and
    Troubleshooting (Part- I)
    الملخص ......................:
    Introduction
    The operating manual of any centrifugal pump often starts with a general statement,
    “Your centrifugal pump will give you completely trouble free and satisfactory service only
    on the condition that it is installed and operated with due care and is properly maintained.”
    Despite all the care in operation and maintenance, engineers often face the statement
    “the pump has failed i.e. it can no longer be kept in service”. Inability to deliver the desired
    flow and head is just one of the most common conditions for taking a pump out of service.
    There are other many conditions in which a pump, despite suffering no loss in flow or head,
    is considered to have failed and has to be pulled out of service as soon as possible. These
    include seal related problems (leakages, loss of flushing, cooling, quenching systems, etc),
    pump and motor bearings related problems (loss of lubrication, cooling, contamination of
    oil, abnormal noise, etc), leakages from pump casing, very high noise and vibration levels,
    or driver (motor or turbine) related problems.
    الرابط ................................................. :
    http://www.cheresources.com/centrifugalpumps.pdf
    مع تحياتى
    Eng-Maher
    Received: 104
    Given: 408
    مشاركه واحده توحد الله ..
    علشان لو الموضوع وحش والله ما هزعل ..
    الحمد لله
    AHMED AHMED
    AHMED AHMED غير متواجد حالياً
    بارك الله فيك على هذا الكتاب المفيد
    Eng-Maher
    Received: 104
    Given: 408
    مشكووووووور اخى احمد احمد
    الحمد لله
    مهندس بالفطره
    مهندس بالفطره غير متواجد حالياً
    مشكور وبارك الله فيك
    يعطيك العافيه الموضوع جميل ومفيد
    بصراحه اهني نفسي واعضاء منتدى الهندسه الميكانيكيه بوجودك معانا عضو مميز وتستحق اكثر من هذا بصراحه
    الى الامام وبالتوفيق انشاء الله
    Eng-Maher
    Received: 104
    Given: 408
    انا لى الشرف بوجودك اخى ( مهندس ب الفطره) فشكرا لك وشكر الى كل اخوانى المهندسين العرب وفقنا الله ووفقهم جميعا .. وفعلا الى الامام بأذن الله .
    الحمد لله
    Eng-Maher
    Received: 104
    Given: 408
    الحمد لله
    أبوالحارث
    أبوالحارث غير متواجد حالياً
    مشكووووووور thanks
    Eng-Maher
    Received: 104
    Given: 408
    اقتباس المشاركة الأصلية كتبت بواسطة أبوالحارث مشاهدة المشاركة
    مشكووووووور thanks
    بارك الله فيك
    الحمد لله
    ثومة
    ثومة غير متواجد حالياً
    شكرا يا مهندس
