كتب من المهندس: مجدي
صفحة 4 من 10 الأولىالأولى 1 2 3 45 6 7 8 ... الأخيرةالأخيرة
النتائج 31 إلى 40 من 99
  1. [31]
    م.مجدي عليان
    م.مجدي عليان غير متواجد حالياً
    عضو تحرير المجلة
    الصورة الرمزية م.مجدي عليان
    Received: 24
    Thumbs up Failure Analysis Case Studies II
    ISBN: 0080439594
    Author: D.R.H. Jones
    Publisher: Pergamon
    Edition: (June 1, 2001)
    Hardcover: 456 pages
    URL: /http://www.amazon.com/exec/obidos/redirect?tag=songstech-20&path=ASIN%2F0080439594
    Summary:
    The first book of Failure Analysis Case Studies selected from volumes 1, 2 and 3 of the journal Engineering Failure Analysis was published by Elsevier Science in September 1998. The book has proved to be a sought-after and widely used source of reference material to help people avoid or analyse engineering failures, design and manufacture for greater safety and economy, and assess operating, maintenance and fitness-for-purpose procedures. In the last three years, Engineering Failure Analysis has continued to build on its early success as an essential medium for the publication of failure analysis cases studies and papers on the structure, properties and behaviour of engineering materials as applied to real problems in structures, components and design.
    Failure Analysis Case Studies II comprises 40 case studies describing the analysis of real engineering failures which have been selected from volumes 4, 5 and 6 of Engineering Failure Analysis. The case studies have been arranged in sections according to the specific type of failure mechanism involved. The failure mechanisms covered are overload, creep, brittle fracture, fatigue, environmental attack, environmentally assisted cracking and bearing failures. The book constitutes a reference set of real failure investigations which should be useful to professionals and students in most branches of engineering.
    http://rapidshare.de/files/8130123/F...es_II.rar.html
    http://rapidshare.de/files/21092632/...Studies_II.rar
    Best Regards
    Majdi N. Elyyan
  2. [32]
    م.مجدي عليان
    عضو تحرير المجلة
    Received: 24
    Thumbs up The Nalco Guide to Cooling-Water Systems Failure Analysis, 1992-11
    General *******s:
    - Cooling Water System Design and Operation
    Concentration Cell Corrosion
    - Crevice Corrosion
    - Tuberculation
    - Underdeposit Corrosion
    - Oxygen Corrosion
    - Biologically Influenced Corrosion
    - Acid Corrosion
    - Alkaline Corrosion
    Cracking Phenomena in Cooling Water Systems
    - Stress-Corrosion Cracking
    Introduction to Failure Modes Involving Mechanical Damage
    - Corrosion Fatigue
    - Erosion-Corrosion
    - Cavitation Damage
    - Dealloying
    Introduction to Material and Weld Defects
    - Material Defects
    - Weld Defects
    - Galvanic Corrosion
    - Graphitic Corrosion
    http://rapidshare.de/files/14016848/...ysis_muyac.rar
    http://rapidshare.de/files/13190090/0070284008.rar.html
    Password: ebooksclub.org
    (15.9 Mb)
    Best Regards
    Majdi N. Elyyan
  3. [33]
    م.مجدي عليان
    عضو تحرير المجلة
    Received: 24
    Thumbs up Buried Pipe Design, 2nd Edition
    MiHD download
    http://mihd.net/7fklaw
    http://rapidshare.de/files/27262672/...esign.rar.html
    Best Regards
    Majdi N. Elyyan
  4. [34]
    م.مجدي عليان
    عضو تحرير المجلة
    Received: 24
    Thumbs up ASM Handbook, Vol. 19: Fatigue and Fracture
    You'll learn about fatigue and fracture from both the fundamental and practical standpoint. It's the essential data necessary for you to make informed decisions on alloy design and material selection. You'll also gain valuable insight into fracture control, life assessment, and failure analysis
    http://rapidshare.com/files/1522315/...ol_19.rar.html
    OR
    http://mihd.net/bzv6mh
    Best Regards
    Majdi N. Elyyan
  5. [35]
    م.مجدي عليان
    عضو تحرير المجلة
    Received: 24
    Thumbs up ASM Handbook, Vol. 08: Mechanical Testing and Evaluation
    This newly revised and comprehensive ASM Handbook contains over 50 all-new articles plus newly revised updates on standard test methods for tensile, compressive, shear, hardness, creep, fatigue, and fracture-toughness properties. Expanded coverage also includes new articles on surface wear testing, adhesion testing, nanomechanical testing, Hopkinson bar techniques, dynamic indentation testing, fatigue testing, residual-stress measurements, and extensive new coverage on the mechanical testing of engineering components such as gears, bearings, fasteners, adhesive-bonded joints, piping, and welds.
    Book Info
    Provides up-to-date information on mechanical testing for metals, plastics, ceramics, and composites. Covers all of the basics, as well as all of the various methods for indentation testing and mechanical testing if components such as gears, bearings, welds, adhesive joints, and other such items. Previous edition: c1984. DLC: Metals--Handbooks, manuals, etc
    http://mihd.net/3itqx7
    http://mihd.net/s2hvml
    OR
    http://rapidshare.com/files/1506199/...ol_08.rar.html
    Best Regards
    Majdi N. Elyyan
  6. [36]
    م.مجدي عليان
    عضو تحرير المجلة
    Received: 24
    Thumbs up Metal Fatigue: Effects Of Small Defects And Nonmetallic Inclusions
    ISBN: 0080440649
    Author: Yukitaka Murakami
    Publisher: Elsevier Science
    URL: /http://www.amazon.com/exec/obidos/redirect?tag=songstech-20&path=ASIN%2F0080440649
    Summary:
    . This book is an English translation of the original Japanese, first published in 1993, but with two brand new chapters on fatigue failure of steels and the effect of surface roughness on fatigue strength. The first part of this book includes a concise explanation of metal fatigue. The methodology employed is based on important and reliable experimental results and may be usefully applied to other fatigue problems not directly treated in the book. The second half mainly addresses problems related to the influence of nonmetallic inclusions. This includes the introduction of an inclusion rating method based on the statistics of extremes, which will be useful not only for fatigue strength evaluation but also for making improvements in steel processing and material quality control.
    Engineers and researchers involved in the study of metal fatigue should find this work useful for solving practical problems in industry and developing new laboratory
    http://rapidshare.de/files/21106567/...Inclusions.rar
    Best Regards
    Majdi N. Elyyan
  7. [37]
    م.مجدي عليان
    عضو تحرير المجلة
    Received: 24
    Thumbs up Fatigue of Structures and Materials
    Summary:
    This book is primarily a textbook written for engineers, students and teachers, and for people working on fatigue problems of engineering structures and materials. The book can be used for graduate and undergraduate courses, workshops, and short courses for people working in the industry or research institutes. The book also offers useful comments for researchers in view of the practical relevance of investigations and to plan future research. An important theme of the book is the understanding of what happens in the material of an engineering structure subjected to a spectrum of cyclic loads in service. Knowledge of the fatigue mechanism in the material and how it can be affected by a large variety of practical conditions is essential for dealing with fatigue problems. The structure must be designed for durability, and thus against fatigue. This includes not only the overall concept of the structure and safety and economic aspects, but also questions on detail design, joints, production and material surface quality. The designer must predict the fatigue performance of the structure. Knowledge of the various influencing factors is essential. Similar considerations arise if fatigue problems occur after a period in service when decisions have to be made on remedial actions. A unique feature of the book is the integrated approach to fatigue of engineering structures as outlined in the picture on the front cover of the book.
    download from:
    http://rapidshare.de/files/27859047/...ap_Schijve.pdf
    Best Regards
    Majdi N. Elyyan
  8. [38]
    م.مجدي عليان
    عضو تحرير المجلة
    Received: 24
    Best Regards
    Majdi N. Elyyan
  9. [39]
    م.مجدي عليان
    عضو تحرير المجلة
    Received: 24
    Thumbs up Intelligent Control Systems Using Soft Computing Methodologies
    ISBN: 0849318750
    Author: .
    Publisher: CRC Press
    Edition: (March 27, 2001)
    Hardcover: 504 pages
    URL: /http://www.amazon.com/exec/obidos/redirect?tag=songstech-20&path=ASIN%2F0849318750
    Summary:
    In recent years, intelligent control has emerged as one of the most active and fruitful areas of research and development. Until now, however, there has been no comprehensive text that explores the subject with focus on the design and analysis of biological and industrial applications. Intelligent Control Systems Using Soft Computing Methodologies does all that and more. Beginning with an overview of intelligent control methodologies, the contributors present the fundamentals of neural networks, supervised and unsupervised learning, and recurrent networks. They address various implementation issues, then explore design and verification of neural networks for a variety of applications, including medicine, biology, digital signal processing, object recognition, computer networking, desalination technology, and oil refinery and chemical processes.The focus then shifts to fuzzy logic, with a review of the fundamental and theoretical aspects, discussion of implementation issues, and examples of applications, including control of autonomous underwater vehicles, navigation of space vehicles, image processing, robotics, and energy management systems. The book concludes with the integration of genetic algorithms into the paradigm of soft computing methodologies, including several more industrial examples, implementation issues, and open problems and open problems related to intelligent control technology.Suited as both a textbook and a reference, Intelligent Control Systems explores recent advances in the field from both the theoretical and the practical viewpoints. It also integrates intelligent control design methodologies to give designers a set of flexible, robust controllers and provide students with a tool for solving the examples and exercises within the book.
    http://rapidshare.de/files/20595139/...DWARF.zip.html
    Best Regards
    Majdi N. Elyyan
  10. [40]
    م.مجدي عليان
    عضو تحرير المجلة
    Received: 24
    Thumbs up The Engineering of Chemical Reactions (Topics in Chemical Engineering)
    General *******s:
    Fundamentals
    - Introduction
    -- Chemical Reactors
    -- Chemical Reaction Engineering
    -- Industrial Processes
    -- Modeling
    - Reaction Rates, The Batch Reactor, and the Real World
    -- Chemical Reactions
    -- Multiple Reactions
    -- Reaction Rates
    -- Approximate Reactions
    -- Rate Coefficients
    -- Elementary Reactions
    -- Stoichiometry
    -- Reaction Rates Near Equilibrium
    -- Reactor Mass Balances
    -- The Batch Reactor
    -- Variable Density
    -- Thermodynamics and Reactors
    -- Adiabatic Reactor Temperature
    -- Chemical Equilibrium
    -- Petroleum Refining
    -- Polyester from Refinery Products and Natural Gas
    -- Reaction-Rate Data
    - Single Reactions in Continuous Isothermal Reactors
    -- Continuous Reactors
    -- The Continuous Stirred Tank Reactor
    -- Conversion in a Constant-Density CSTR
    -- The Plug-Flow Tubular Reactor
    -- Conversion in a Constant-Density PFTR
    -- Comparison Between Batch, CSTR and PFTR
    -- The 1/r Plot
    -- Semibatch Reactors
    -- Variable-Density Reactors
    -- Space Velocity and Space Time
    -- Chemical Reactors in Series
    -- Autocatalytic Reactions
    -- Reversible Reactions
    -- Trasients in Continuous Reactors
    -- Some Important Single-Reaction Processes: Alkane Activation
    -- Synthesis Gas Reactions
    -- Staged Reactors
    -- The Major Chemical Companies
    -- Reactor Design for a Single Reaction
    - Multiple Reactions in Continuous Reactors
    -- The Petrochemical Industry
    -- Olefins
    -- Mass Balances
    -- Conversion, Selectivity and Yield
    -- Complex Reaction Networks
    -- Series Reactions
    -- Parallel Reactions
    -- Multiple Reactions with Variable Density
    -- Real Reaction Systems and Modeling
    -- Approximate Rate Expressions for Multiple-Reaction Systems
    -- Simplified Reactions
    -- Reaction Mechanisms
    -- Collision Theory of Bimolecular Reactions
    -- Activated Complex Theory
    -- Designing Reactors for Multiple Reactions
    - Nonisothermal Reactors
    -- Heat Generation and Removal
    -- Energy Balance in a CSTR
    -- Energy Balance in a PFTR
    -- Equations to be Solved
    -- Heat Removal or Addition to Maintain a Reactor Isothermal
    -- Adiabatic Reactors
    -- Trajectories and Phase-Plane Plots
    -- Trajectories of Wall-Cooled Reactors
    -- Exothermic Versus Endothermic Reactions
    -- Other Tubular Reactor Configurations
    -- The Temperature Profiles in a Packed Bed
    - Multiple Steady States and Transients
    -- Heat Generation and Removal in a CSTR
    -- Adiabatic CSTR
    -- Stability of Steady States in a CSTR
    -- Observation of Multiple Steady States
    -- Transients in the CSTR with Multiple Steady States
    -- Other Reactions in a CSTR
    -- Variable Coolant Temperature in a CSTR
    -- Designing Reactors for Energy Management
    - Catalytic Reactors and Mass Transfer
    -- Catalytic Reactions
    -- Catalytic Reactors
    -- Surface and Enzyme Reaction Rates
    -- Porous Catalysts
    -- Transport and Reaction
    -- Mass Transfer Coefficients
    -- External Mass Transfer
    -- Pore Diffusion
    -- Temperature Dependence of Catalytic Reaction Rates
    -- The Automotive Catalytic Converter
    -- The Catalytic Wall Reactor
    -- Langmuir-Hinshelwood Kinetics
    -- A Summary of Surface Reaction Kinetics
    -- Designing Catalytic Reactors
    -- Electrochemical Reactors
    -- Real Catalytic Reactors
    -- Bioreactors
    -- The Human Reactor
    Applications
    -- Designing a Chemical Reactor and Introduction to Applications
    -- Stages of Design
    - Nonideal Reactors, Bioreactors and Environmental Modeling
    -- The "Complete" Equations
    -- Reactor Mass and Energy Balances
    -- Residence Time Distribution
    -- Laminar Flow Tubular Reactors
    -- Dispersion in Tubular Reactors
    -- Recycle Reactors
    -- CSTRs in Series
    -- Diagnosing Reactors
    -- Modeling the Environment
    -- Cell Cultures and Ecological Modeling
    - Reactions of Solids
    -- Reactions Involving Solids
    -- Chemical Vapor Deposition and Reactive Etching
    -- Solids Reactors
    -- Reaction Rates of Solids
    -- Films, Spheres and Cylinders
    -- Macroscopic and Microscopic Solids
    -- Dissolving and Growing Films
    -- Dissolving and Growing Spheres
    -- Diffusion Through Solid Films
    -- Transformation of Spheres
    -- Electrical Analogy
    - Chain Reactors, Combustion Reactors and Safety
    -- Chain Reactions
    -- Characteristics of Chain Reactions
    -- Autooxidation and Lab Safety
    -- Chemical Synthesis by Autooxidation
    -- Combustion
    -- Hydrogen Oxidation
    -- Chain Branching Reactions
    -- Alkane Oxidation
    -- Thermal Ignition
    -- Thermal and Chemical Autocatalysis
    -- Premixed Flames
    -- Diffusion Flames
    -- Energy Generation
    -- Combustion of Liquids and Solids
    -- Solid and Liquid Explosives
    -- Explosions and Detonations
    -- Reactor Safety
    - Polymerization Reactions and Reactors
    -- Ideal Addition Polymerization
    -- Polyolefins
    -- Free-Radical Polymerization
    -- Catalytic Polymerization
    -- Condensation Polymerization
    -- Fisher Tropsch Polymerization
    -- Polymerization Reactors
    -- Forming Polymers
    -- Integrated Polymer Processing
    -- Crystallization
    - Multiphase Reactors
    -- Types of Multiphase Reactors
    -- Mass Transfer Reactors
    -- Mass Balance Equations
    -- lnterfacial Surface Area
    -- Mass Transfer between Phases
    -- Multiphase Reactor Equations
    -- Equilibrium between Phases
    -- Membrane Reactors
    -- Falling Film Reactor
    -- Bubble Column Reactors
    -- Falling Film Catalytic Wall Reactor
    -- Trickle Bed Reactor
    -- Multiphase Reactors with Catalysts
    -- Other Multiphase Reactors
    -- Analysis of Multiphase Reactors
    -- Reactor-Separation Integration
    -- Catalytic Distillation
    -- Chromatographic Reactors
    -- Iron Ore Refining
    -- The Petroleum Refinery
    http://rapidshare.de/files/17832311/...10010.rar.html
    PASSWORD: A12we06tEoCr1
    Best Regards
    Majdi N. Elyyan
