اريد معلومات عن electrosurgical unit
صفحة 2 من 2 الأولىالأولى 1 2
النتائج 11 إلى 16 من 16
    اللويمي
    اللويمي غير متواجد حالياً
    السلام عليكم ..
    وانا بعد ياليت تخدموني أبي معلومات عن الجهاز نفسه لغرض دراسي
    مو بحث بحث ,, يعني بحث صغير 4 او 5 صفحات تكفي اقدمه للدكتور بس بالأنجليزي ...
    المواقع اللي ابحث فيها احصل عروض بيع مافيه معلومات شامله ,,
    ولكم مقدما جزيل الشكر على جهودكم
    وعلى فكره هاذي اول مشاركه لي
    moo7seen
    moo7seen غير متواجد حالياً
    Electrosurgical Unit
    Abbreviation / other : ESU
    What does it do?
    The ESU cuts tissue and/or stops the bleeding by coagulating the blood
    (haemostasis)
    Physiology :
    During surgery the tissue and blood vessels are cut which causes bleeding. To prevent too much blood loss and to keep the operating field free of excess blood, electro surgical units are used. Different modes of operation can be set. “Cut” is for cutting tissue, “Blend” is a mixture of cutting and coagulation. This mode is used to cut and the same time reduces bleeding (haemostatic). “Coagulation” is used for maximum Haemostasis, “Desiccation” is used for destroying tissue. The monopolar mode (single electrode) is used for cutting and coagulation, the bipolar mode (forceps like electrode) is used mainly for desiccation (destroying tissue)
    How it works :
    An electric current with a frequency of about 500kHz is used to cut and coagulate tissue. This process involves applying an RF (Radio Frequency) spark between a probe and the tissue. The electric current through the tissue heats up the tissue and evaporates the water in the cell destroying it. This achieves special surgical effects namely cutting, coagulation and desiccation. The voltage on the electrode is between 1000 – 10,000 V p-p.
    Units of measurement : Watts.
    Typical values :
    Bipolar Cut: 50 Watts Coag: 8 Watts
    Monopolar Cut: 150 – 300 Watts Coag: 40 – 80 Watts
    solidus_snack
    solidus_snack غير متواجد حالياً
    شكرا اخي علي المعلوماااااااااااات يريت موقع او حاجه يبقي فيها pdfs وشغل كيدا كبييييير وشكرا علي المجهوووووووووووود
    glucose
    glucose غير متواجد حالياً
    الصورة الرمزية glucose
    Received: 12
    أخي الكريم حطلي *****ك وأنا ببعتلك تقرير جاهز بالعربي ان شاء الله مع ملف بور بوينت بس بصراحة بودي لو أني أقدر أنشرو بالمنتدى وفيد الكل بس هو مو لألي
    solidus_snack
    السلام عليكم اخيglucose هوه ده *****ي ويرييييت لو تبعتلي التقرير واكون مشكوووور فعلاsolidsnack2004***********اوmostafaZ3********** ***
    شكرا
    solidus_snack
    solidsnack2004ده الميل بتاع ******وو
    mostafaZ3ده الميل بتاع ********
