Din 16901
النتائج 1 إلى 3 من 3
    mee
    mee غير متواجد حالياً
    Din 16901
    If Any One Can Send Me This Din 16901.
    This Din For Plastic Molding.
    I Need It In Arabic Or English.
    Thank You Very Much All.
    Your Prother
    Zoheer.
    من مواضيع mee :
    محمد فوزى
    محمد فوزى غير متواجد حالياً
    الصورة الرمزية محمد فوزى
    http://www.bopla.de/english/technisc...nen/kutol.html
    يمكن الرجوع للرابط اعلاه او الاطلاع على التفصيل التالى
    Deviations from the nominal dimensions are unavoidable in the manufacture of plastic shapes.
    There are various reasons for these deviations:
    a) Machining distribution
    this depends on
    - the evenness of the shape
    - the setting of the machine
    - the temperature of the tools
    - the distortion of the tool under pressure.
    b) The condition of the tool
    - manufacturing tolerances for tool dimensions (see DIN 16 749)
    - wear on tools
    - deviations in the position of mobile tool parts.
    The tolerances for this norm have been laid down taking into account these factors and numerous measurements in practice.
    The plastics in this norm are divided into tolerance rows. All the plastics used by Bopla for standard enclosures, PS, ABS, PC, Noryl SE 1 (PPE), PA (GF, GB), and polyester are in Row 130, for which the tolerances given below apply. The tolerances apply on the basis of the machining shrinkage worked into the tool only for the appropriate enclosure with the standard material stated.
    Nominal Dimensions
    over
    to 0
    1 1
    3 3
    6 6
    10 10
    15 15
    22 22
    30 30
    40 40
    53 53
    70
    For dimensions not tied to tools¹)
    ± 0,18
    ± 0,19
    ± 0,20
    ± 0,21
    ± 0,23
    ± 0,25
    ± 0,27
    ± 0,30
    ± 0,34
    0,38
    For dimensions tied to tools ²)
    ± 0,08
    ± 0,09
    ± 0,10
    ± 0,11
    ± 0,13
    ± 0,15
    ± 0,17
    ± 0,20
    ± 0,24
    ± 0,28
    Nominal Dimensions
    70
    90 90
    120 120
    160 160
    200 200
    250 250
    315 315
    400 400
    500 500
    630 630
    800 800
    1000
    ± 0,44
    ± 0,51
    ± 0,60
    ± 0,70
    ± 0,90
    ± 1,10
    ± 1,30
    ± 1,60
    ± 2,00
    ± 2,50
    ± 3,00
    For dimensions tied to tools²)
    ± 0,34
    ± 0,41
    ± 0,50
    ± 0,60
    ± 0,80
    ± 1,00
    ± 1,20
    ± 1,50
    ± 1,90
    ± 2,40
    ± 2,90
    Figures in mm
    1) Dimensions not tied to tools are those formed by the interaction of mobile tool parts, e.g. wall thicknesses and floor thicknesses or dimensions that are affected by additives or pushers.
    2) Dimensions tied to tools are those in the same part of the tool.
    mee
    thank you brother alot
din
