3D Studio Max 9 Full Tutorials
النتائج 1 إلى 5 من 5
    الصورة الرمزية المعماري السوداني
    المعماري السوداني
    المعماري السوداني غير متواجد حالياً
    دروس فيديو لكل الجديد في ماكس 9 حصريا معنااا بحجم تقريبا 823 ميجا
    بس للاسف بروابط علي الرابد شير معلش ارجو من يستطيع رفعهم علي موقع اخر او تحويلهم لروابط مباشرة يكون جزاءة الله كل خير عنا
    يشمل علي كل الجديد في الاصدارر الاخير
    64-bit Release for Windows
    3ds Max 9 marks the first full release of 3ds Max software with both 32-bit (Windows®) and 64-bit (Windows®) executables. It enables you to address considerably more memory than you could in the past, allowing you to handle larger and more complex scenes than ever before.
    Easily Render Realistic Scenes
    mental ray 3.5 adds powerful rendering functionality to 3ds Max 9. Create photorealistic skies based on the position of the sun with Physical Sun and Sky mental ray shader. New Architectural and Design shaders make it easier for designers and architects to create effects such as blurred reflections, frosted glass, and glossy car paint. The ability to create bump mapping on glossiness only and to simulate round corners and soft edges makes objects appear even more natural and true to life.
    mental ray 3.5 Core
    mental ray 3.5 adds a simplified user interface for working with Final Gather. IT also has a unified indirect lighting model that provides consistent results when switching between different 3ds Max radiosity modes.
    Performance Optimizations
    Core performance enhancements have been made to 3ds Max 9 to maximize your productivity and accelerate your creative workflow. For example, enjoy greater viewport interactivity when working with dense meshes and the ability to switch between high-res and low-res bitmap proxies
    to allow for faster interaction.
    Layered Animation
    The ability to place animation into separate layers allows you to easily tweak dense and complex animations. Layers can be turned on or off to evaluate an animation, can blend new keys with existing motion, and can allow for a full range of adjustments without having to modify the key frames of the animated object.
    Character Animation Workflow Improvements
    Craft and refine your character animation more easily with numerous enhancements to Biped functionality. For example, you can now move keys past each other and work in negative frames. This saves steps when tweaking a Biped animation and is particularly useful when trying to reverse an animation, since one can now negatively scale an animation range.
    ProBooleans
    ProBooleans is a new tool for modeling with Boolean operations allowing you to quickly and easily model inorganic shapes—useful for prototyping geometry, creating game level layout designs, and complex architectural elements. Merge, intersect, subtract, or add meshes to create rich and complex objects. ProBooleans re-evaluates the topology to remove bad triangles, allowing you to create higher-quality meshes with fewer small edges and skinny triangles.
    Hair and Cloth Improvements
    Easily work with Cloth and Hair in 3ds Max 9. Create, manipulate, and style hair directly in the viewports using standard navigation and selection tools. As of 3ds Max 9, you can cinch waistlines, shorten hems, and tailor clothing in the stack without the need to edit the original pattern to make clothes fit.
    XRef Object Enhancements
    Many enhancements have been made to XRefs in 3ds Max 9. You can now reference scene geometry, materials, and controllers and can maintain dependencies between XRef’d items. The XRef system’s new dependency handling lets you preview object relationships in both merge and XRef operations, providing more control over how external objects are used.
    Enhanced FBX Support
    The Autodesk® FBX® 3D authoring and interchange format allows you to exchange assets between 3D applications. Enhancements in FBX include improvements to mesh compatibility, pixel accuracy when transferring assets and data between 3ds Max, Maya and MotionBuilder software
    Display Support for DirectX and CG Shaders
    Support for all DirectX® shaders and performance enhancements have been made for 3ds Max 9. You can now load cgfx files into the DX material and have them displayed in the viewport.
    Realize Your Full Potential
    The products in the Autodesk® 3D Product Portfolio — 3ds Max, Maya, MotionBuilder, and Autodesk® VIZ — represent the broadest set of solutions, applications, development resources, and streamlined workflow available in 3D. Whether your project calls for out-of-the-box functionality or customized toolsets, Autodesk has a 3D solution for you
    للتحميل [/RIGHT]
    [LEFT][RIGHT]http://rapidshare.com/files/1545040/....rar.part1.rar
    http://rapidshare.com/files/1545004/....rar.part2.rar
    http://rapidshare.com/files/1544816/....rar.part3.rar
    http://rapidshare.com/files/1556032/....rar.part1.rar
    http://rapidshare.com/files/1557399/....rar.part2.rar
    http://rapidshare.com/files/1554454/....rar.part3.rar
    http://rapidshare.com/files/1555896/....rar.part1.rar
    http://rapidshare.com/files/1558487/....rar.part2.rar
    http://rapidshare.com/files/1556267/....rar.part3.rar
    http://rapidshare.com/files/1588228/....rar.part1.rar
    http://rapidshare.com/files/1556889/....rar.part2.rar
    http://rapidshare.com/files/1556471/....rar.part3.rar
    http://rapidshare.com/files/1553344/....rar.part1.rar
    http://rapidshare.com/files/1562650/....rar.part2.rar
    http://rapidshare.com/files/1556673/....rar.part3.rar
    http://rapidshare.com/files/1587832/....rar.part1.rar
    http://rapidshare.com/files/1557255/....rar.part2.rar
    http://rapidshare.com/files/1557096/....rar.part3.rar
    http://rapidshare.com/files/1557659/....rar.part1.rar
    http://rapidshare.com/files/1557563/....rar.part2.rar
    http://rapidshare.com/files/1587057/....rar.part3.rar
    http://rapidshare.com/files/1559063/....rar.part1.rar
    http://rapidshare.com/files/1559186/....rar.part2.rar
    http://rapidshare.com/files/1557805/....rar.part3.rar
    http://rapidshare.com/files/1559432/....rar.part1.rar
    [URL]http://rapidshare.com/files/1558412/X3D.Studio.Max.9.part09.rar.part2.
    المشاركة منقولة للفايدة
    king sabri
    king sabri غير متواجد حالياً
    شكرا يا أخي الحبيب
    لكن الرابيد شير حبيب الناس إللي ترفع ملفات و عدو الناس إللي تنزل الملفات
    ويعطيك العافيه
    مــا خفتُ المـــوتَ ولا عقبـــــاهُ^^^ فما أعظم شأنه غيرَ مولاهُ
    أهـوِن بما في الموتِ من حــدثٍ^^^غــــيرَ أن بـــهِ اللهَ ألـــقــــاهُ
    ama-nti
    ama-nti غير متواجد حالياً
    شكرا على هذا المجهود و نتمنى منك المزيد
    elne3mey
    elne3mey غير متواجد حالياً
    شكرا على هذا الاصدار الجديد وجزاك الله خير
    hassan201064
    hassan201064 غير متواجد حالياً
    الف شكر ياجميل
