برنامج ... CircuitMaker 2000
النتائج 1 إلى 3 من 3
    Mu7ammad
    Mu7ammad غير متواجد حالياً
    Received: 8
    The CircuitMaker 2000
    Windows OS | Size: 10.00 Mb
    The CircuitMaker 2000 importer has been improved:
    * Files containing macros (reusable pieces of circuitry) are better handled.
    * Situations where the libraries (DEVICE & USER) are not loaded before the CKT files are now managed more appropriately. Now an adequate error will be added to the CM2000 log file & the loading process will be stopped.
    * When the the current locale decimal separator is different from '.' (period), CircuitMaker2000 files are still imported correctly.
    * Loading of corrupted CKT files has been improved. In these cases, an error will be added to the importer's log file and the loading process will stop.
    * The Setup dialog has been improved and streamlined.
    * If no path is specified in the Setup dialog (when no values are found in LoadCM2000.INI file), default directories are displayed in Libraries Path & Models Path edit boxes. These default directories are: %DXPInstallationDirectory%SystemCircuitMaker2000Li braries & %DXPInstallationDirectory%SystemCircuitMaker2000Mo del. If these directories don't contain the required SchLib libraries or models then an error will be added to the log file when the importer tries to find the components in the loaded libraries.
    DownLoad
    .... والله ولى التوفيق ...
    أهل الحديث
    أهل الحديث غير متواجد حالياً
    Received: 205
    Given: 261
    { الَّذِينَ آتَيْنَاهُمُ الْكِتَابَ يَعْرِفُونَهُ كَمَا يَعْرِفُونَ أَبْنَاءَهُمُ }
    prof_decor
    prof_decor غير متواجد حالياً
    شكرا على هذا البرنامج الرائع احمد فتحى
