برنامج ... Winamp 5.31 pro + keygen
النتائج 1 إلى 1 من 1
    Mu7ammad
    Mu7ammad غير متواجد حالياً
    Received: 8
    Windows OS | Size: 6.42 Mb
    Changes in Winamp 5.31 :
    * New: [in_cdda] CD Text reading support (with sonic engine enabled)
    * New: [in_flac] Nullsoft FLAC Decoder
    * New: [enc_flac] Nullsoft FLAC Encoder
    * Improved: [ml_disc] Smarter tagging when ripping tracks
    * Improved: [in_cdda] Better CD metadata
    * Improved: [in_mp3] support for reading ID3v2.4 per-frame unsynchronization
    * Improved: [in_mp4] HTTP streaming support
    * Improved: [in_wave] HTTP streaming support
    * Improved: [in_wm] follows 24bit/mono/surround playback setting
    * Fixed: loading folders via playlists
    * Fixed: Shortcut icons for multi-user installations
    * Fixed: Thinger icons for old wa3 skins (filereader.w5s missing)
    * Fixed: truncated text in version history
    * Fixed: handling of shortcuts in folders
    * Fixed: [dsp_sps] simple pitch and tempo preset (thanks ujay)
    * Fixed: [gen_ff] System.playFile not working on URLs
    * Fixed: [in_mp3] seek from end of file
    * Fixed: [in_mp3] quality issue
    * Fixed: [in_mp3] random crash when writing ID3v2 tag
    * Fixed: [in_mp3] incorrect track length on concatenated MP3 files
    * Fixed: [in_mp3] gapless glitch
    * Fixed: [in_mp3] maximum number of redirects raised to 3 to allow playback on some podcasts with crazy php scripts
    * Fixed: [in_mp3] lyrics3 security vulnerability (thanks iDefense)
    * Fixed: [in_mp3] ultravox security vulnerability (thanks iDefense)
    * Fixed: [in_mp3] seek problems on files with multiple id3v2 tags
    * Fixed: [ml_disc] ripping discs with international titles
    * Fixed: [ml_local] breaks 'always on top' for other programs
    * Fixed: [ml_local] 'Use Library title information for Playlist Item Formatting' not being followed
    * Fixed: [ml_local] track number showing as 4294967295 in title
    * Fixed: [ml_playlists] memory leak
    * Fixed: [ml_pmp/pmp_ipod/pmp_usb] 'no disc in drive' error message
    * Fixed: [out_ds] logarithmic/hybrid volume control
    * Fixed: [pmp_p4s] crash on 0-length tracks
    * Fixed: [pmp_usb] bad xml writing
    It's highly recommended that you update to this version as a lot of bugs are fixed in this.
