برنامج ... Home Plan Pro v5.1.85 ... للمهندسيين
النتائج 1 إلى 6 من 6
    Mu7ammad
    Mu7ammad غير متواجد حالياً
    Received: 8
    Want to build your dream house? Add a room to your home? Whatever your
    drawing needs, Home Plan Pro is your best choice.
    - It is so easy to learn how to use, you can begin drawing plans
    within minutes.
    - Since it is easy to use, you save tons of time.
    - On-line help answers your questions in seconds.
    - All the drawing power you will ever need.
    - You can use the mouse, the keyboard, or a combination of both to
    build the plan.
    - A full array of graphic drawing tools is provided, all you will ever
    need.
    - A host of pre-drawn figures are included to represent furniture,
    fixtures, windows, doors and so forth. Just click and position the
    one you need.
    - Save elements you have drawn for later use, even in other plans.
    - Export plans to DXF files or common bitmap formats.
    - Complete instructions are provided at every step; you simply can’t
    go wrong.
    And There’s More!
    - A host of printing options are available. For example, a specific
    scale can be selected. Or your plan can be automatically fitted to
    the largest paper size available.
    - With the built-in fax driver, you can fax your plans anywhere in the
    world.
    - With the built-in Email server, you can attach your plans to messages
    and email them to friends and co-workers.
    - Free updates can be automatically downloaded and installed with a
    click on a button; you will always have the latest enhancements at
    your finger tips.
    New in version 5.1:
    - Zoom from 6400′ to 1/32″
    - Detailed Print Preview
    - Draw a Series of Parallel Lines
    - Draw Double Walled Rectangles
    - Wall Thickness in Fractions
    - Windows widths and patterns
    - Metes & Bounds
    - Prevent Printed Text From Scaling Too Big
    - Create a Column of Text
    - Snap Grid spacing is saved for each zoom level)
    - Speed settings are also saved separately for each zoom level.
    - New Zoom Bar buttons provide instant zooming to any level
    DownLoad Part 01
    DownLoad Part 02
    .... والله ولى التوفيق ...
    mokh
    mokh غير متواجد حالياً
    عضو متميز جداً
    الصورة الرمزية mokh
    Received: 27
    Given: 5
    مشكور اخى الكريم على البرنامج لحين تجربته
    ممدوح انور
    ممدوح انور غير متواجد حالياً
    مشكور وجزاك الله خيرا
    وهيب الدين
    وهيب الدين غير متواجد حالياً
    الف شكر وجزاك الله خير
    سامح مكة
    سامح مكة غير متواجد حالياً
    شكررررررررررررررررراااااااااااااااااااااا جزيلاااااااااااااااااااااا
    اياد الحمداني
    اياد الحمداني غير متواجد حالياً
    الصورة الرمزية اياد الحمداني
    بارك الله فيك وجزاك خير الجزاء
