مكتبة الهندسة الميكانيكية Mechanical Engineering eBooks
صفحة 9 من 32 الأولىالأولى ... 5 6 7 8 910 11 12 13 19 ... الأخيرةالأخيرة
النتائج 81 إلى 90 من 314
  1. [81]
    أهل الحديث
    أهل الحديث غير متواجد حالياً
    Received: 205
    Given: 261
    Carbon Fiber Composites
    ISBN: 0750691697
    Title: Carbon Fiber Composites
    Author: Deborah Chung
    Publisher: Butterworth-Heinemann
    Publication Date: 1994-09-23
    Number Of Pages: 215
    In Carbon Fiber Composites, the reader is introduced to a wide range of carbon fiber composites, including polymer-matrix, metal matrix, carbon-matrix, ceramic-matrix and hybrid composites. The subject is examined in a tutorial fashion, so that no prior knowledge of the field is required. In contrast to other books on composites, this book emphasizes materials rather than mechanics, as the prominence of composite materials has resulted from their increased presence in applications other than structure.
    Provides up-to-date information on the entire spectrum of carbon fiber composites.
    Emphasizes processing as the foundation of composite materials development. Addresses the processing, properties and applications of each type of material
    systematically.
    CODE
    http://rapidshare.de/files/2295227/s...91697.rar.html
    password: smileybooks.net
    { الَّذِينَ آتَيْنَاهُمُ الْكِتَابَ يَعْرِفُونَهُ كَمَا يَعْرِفُونَ أَبْنَاءَهُمُ }
  2. [82]
    أهل الحديث
    Received: 205
    Given: 261
    Handbook of Molded Part Shrinkage and Warpage
    ISBN: 1884207723
    Title: Handbook of Molded Part Shrinkage and Warpage
    Author: Jerry Fischer
    Publisher: Plastics Design Library
    Publication Date: 2003-06
    Number Of Pages: 244
    Handbook explains in plain terms why moldings shrink and warp, shows how additives and reinforcements change the picture, sets out the effects of the molding process conditions, and reveals why you can never have a single 'correct' shrinkage value. For researchers, equipment designers, and software developers designing material and equipment improvements
    http://rapidshare.de/files/5615145/H...OREE_.zip.html
  3. [83]
    أهل الحديث
    Received: 205
    Given: 261
    Handbook of Adhesives & Sealants
    ISBN: 0070498881
    Title: Handbook of Adhesives & Sealants
    Author: Edward M. Petrie
    Publisher: McGraw-Hill Professional
    Publication Date: 1999-10-11
    Number Of Pages: 896
    First-Of-Its-Kind Guide to Polymeric Adhesives and Sealants. Now you can find in a single, well-organized source, information about adhesives and sealants normally available only in technical and vendor literature. In Handbook of Adhesives and Sealants, industry pro Edward Petrie brings together information from chemistry, material and surface sciences, and solid mechanics. Covering structural and non-structural applications, the Handbook lets you thoroughly explore the use of polymeric adhesives and sealants for joining or bonding metals, plastics, composites and elastomers. You get the best available information and recommendations on: *Applicable theories and fundamentals *Joint design *Adhesive/sealant selection *Selecting optimal process and manufacturing equipment *Selecting proper testing and quality control methods *Application, curing, and other production processes *Expected end-use properties The "how-to" user emphasis includes plenty of real-life examples. General formulations clarify why certain components are used, and help you spot future development opportunities in the industry
    http://rapidshare.de/files/5615156/H...OREE_.zip.html
  4. [84]
    أهل الحديث
    Received: 205
    Given: 261
    Handbook of Material Weathering
    ISBN: 1895198127
    Title: Handbook of Material Weathering
    Author: George Wypych
    Publisher: Asm Intl
    Publication Date: 1995-12-20
    Number Of Pages: 566
    PDF 7,3 MB
    Our weather is a hostile environment and has adverse effects on many common materials such as polymers, coatings, fabrics, and building materials. The Handbook of Material Weathering is a comprehensive guide to causes, effects, and countermeasures in this important field. The discussion covers the fundamentals of weathering, test methods, and evaluations, stabilization, and biodegradation. The handbook includes weathering data and sensitivities for a large range of specific plastics, and will be an invaluable reference to a vital aspect of materials and product performance
    http://rapidshare.de/files/5614968/H...OREE_.zip.html
  5. [85]
    أهل الحديث
    Received: 205
    Given: 261
    Arrow كتاب ... Engineering Procedures Handbook
    ISBN: 0815514107
    Title: Engineering Procedures Handbook
    Author: Phillip A. Cloud
    Publisher: Noyes Publications
    Publication Date: 1998-06-01
    Number Of Pages: 394
    This handbook is a new systematic approach to engineering documentation, therefore, it will simplify the end users ability to set up or enhance their engineering documentation requirements. Companies with small manual systems, to large scale mass production facilities, can use this handbook to tailor their engineering documentation requirements.
    If an individual or company wishes to create or improve an engineering documentation system, there is no need to start from scratch. Instead, use this new handbook, complete with 47 specially designed forms and with procedures that cover every major aspect of a comprehensive engineering documentation system. Another book published by Noyes, Engineering Documentation Control Handbook can be very helpful if used in conjunction with this handbook.
    This book contains 62 engineering procedures and 27 forms. Most of these engineering procedures are influenced by the author's background in aircraft, aerospace, and the computer industry. The manufacture of Printed Circuit Boards, was used as an example throughout the book. However, the principles are applicable to all engineering and operational disciplines.
    http://rapidshare.de/files/5537684/E...OREE_.zip.html
  6. [86]
    أهل الحديث
    Received: 205
    Given: 261
    Arrow كتاب ... Advanced Polymer Processing Operations
    Title: Advanced Polymer Processing Operations
    Author: Ph.D. Nicholas P. Cheremisinoff
    Publication Date: 1998-05-01
    Number Of Pages: 287
    This volume covers advanced polymer processing operations and is designed to provide a description of some of the latest industry developments for unique products and fabrication methods. Contributors for this volume are from both industry and academia from the international community. This book contains nine chapters covering advanced processing applications and technologies
    http://rapidshare.de/files/5537713/A...OREE_.zip.html
  7. [87]
    أهل الحديث
    Received: 205
    Given: 261
    Arrow كتاب .... Fundamentals of Polymer Engineering
    ISBN: 0306457261
    Title: Fundamentals of Polymer Engineering
    Author: Arie Ram
    Publisher: Plenum Publishing Corporation
    Publication Date: 1997-12-31
    Number Of Pages: 264
    This ideal introductory text covers the basics of polymer chemistry and engineering, as well as structure-property relationships in plastics, in a concise manner. Technically authoritative and up-to-date, the volume offers a survey of the basic chemistry of monomers and their conversion to the various polymers, the essentials of structure and performance, rheology of polymers as liquids and solids, and mechanical properties. Problem sets enhance the book's suitability for advanced undergraduates in chemical engineering or materials science
    http://rapidshare.de/files/5537799/F...OREE_.zip.html
  8. [88]
    أهل الحديث
    Received: 205
    Given: 261
    Arrow كتاب ... Engineering Vibration Analysis with Application to Control Systems
    ISBN: 034063183X
    Title: Engineering Vibration Analysis with Application to Control Systems
    Author: C. Beards
    Publication Date: 1995-06
    Number Of Pages: 448
    Most machines and structures are required to operate with low levels of vibration as smooth running leads to reduced stresses and fatigue and little noise. This book provides a thorough explanation of the principles and methods used to analyse the vibrations of engineering systems, combined with a description of how these techniques and results can be applied to the study of control system dynamics. Numerous worked examples are included, as well as problems with worked solutions, and particular attention is paid to the mathematical modelling of dynamic systems and the derivation of the equations of motion
    http://rapidshare.de/files/11151298/...tems.part1.rar
    http://rapidshare.de/files/11151324/...tems.part2.rar
    http://rapidshare.de/files/11151342/...tems.part3.rar
    http://rapidshare.de/files/11151076/...tems.part4.rar
  9. [89]
    أهل الحديث
    Received: 205
    Given: 261
    Arrow كتاب ..Applied Materials Science: Applications of Engineering Materials in Structural
    ISBN: 0849310733
    Title: Applied Materials Science: Applications of Engineering Materials in Structural, Electronics, Thermal, and Other Industri
    Author: Deborah D. L. Chung
    Publisher: CRC Press
    Publication Date: 2001-06-13
    Number Of Pages: 256
    Materials are the foundation of technology. As such, most universities provide engineering students with the basic concepts of materials science, but few offer the applications-oriented background that students need to succeed in industry. This book fills that gap. From a cross-disciplinary perspective, the author examines the practical applications of engineering materials across a broad range of industries. The topics addressed include electronic packaging, smart materials, thermal management, and materials development. Designed for use as both a text and a reference, Applied Materials Science is both scientifically rich and technologically relevant
    http://www.megaupload.com/?d=19V0ZQTO
    http://rapidshare.de/files/11658105/...k-EEn.rar.html
  10. [90]
    أهل الحديث
    Received: 205
    Given: 261
    Arrow كتاب ... Corrosion and Chemical Resistant Masonry Materials Handbook
    ISBN: 0815510535
    Title: Corrosion and Chemical Resistant Masonry Materials Handbook
    Author: Walter Lee Sheppard
    Publication Date: 1986-08-01
    Number Of Pages: 722
    This information packed volume describes corrosion and chemical resistant masonry materials necessary for buildings and equipment requiring such materials. Written by 40 authorities, it covers a broad variety of materials, from structural materials, membranes and lining systems, to inspection and failure analysis. This will enable practicing engineers and architects to write specifications and instructions, and draw details, for proper installation of such masonry materials and equipment. It will also be of use to a wide variety of manufacturing and chemical process industries
    http://rapidshare.de/files/5537865/C...OREE_.zip.html
