مكتبة الهندسة الميكانيكية Mechanical Engineering eBooks
صفحة 28 من 32 الأولىالأولى ... 1824 25 26 27 2829 30 31 32 الأخيرةالأخيرة
النتائج 271 إلى 280 من 314
  1. [271]
    أهل الحديث
    أهل الحديث غير متواجد حالياً
    Received: 205
    Given: 261
    Pump Users' Handbook, 2nd Edition
    General Contents
    The Principles of Pumping; Main Classifications of Pumps and Physical Properties of Liquids
    How to Make a Liquid Flow Into Pump (Pumping Element)
    How to Define the Total Pump Heat (Pressure)
    The Stuffing-Box
    The Choice of Materials for Pumps
    How to Select and Order the Correct Pump
    Electric Pump Drives
    Pipeline Systems and Valves
    Pressure Surges in Pipelines and Control
    How to Test Pumps
    Hints for Users
    Health and Safety
    http://rapidshare.de/files/24333769/5K200604080016.rar
    PASS: A8sa06pUh2
    http://rapidshare.de/files/19418899/PH_060502.rar.html
    { الَّذِينَ آتَيْنَاهُمُ الْكِتَابَ يَعْرِفُونَهُ كَمَا يَعْرِفُونَ أَبْنَاءَهُمُ }
  2. [272]
    أهل الحديث
    Received: 205
    Given: 261
    Know and Understand Centrifugal Pumps
    First Edition
    Summary:
    Pumps are commonly encountered in industry and are essential to the smooth running of many industrial complexes. Mechanical engineers entering industry often have little practical experience of pumps and their problems, and need to build up an understanding of the design, operation and appropriate use of pumps, plus how to diagnose faults and put them right. This book tackles all these aspects in a readable manner, drawing on the authors' long experience of lecturing and writing on centrifugal pumps for industrial audiences
    http://rapidshare.de/files/21048993/...ugal_Pumps.rar
    http://rapidshare.de/files/16538978/...Pumps_muya.rar
    http://rapidshare.de/files/16524283/...Pumps.rar.html
  3. [273]
    أهل الحديث
    Received: 205
    Given: 261
    Heat and Mass Transfer
    By: Hans D. Baehr Karl Stephan
    ISBN: 3540295267
    Publisher: Springer - 2006-05-22
    Hardcover | 2 Edition | 22 Pages | List Price: $89.95 (USD)
    This comprehensive presentation of the whole field of heat and mass transfer makes the reader familar with the fundamentals and enables him to solve practical problems. The basic theory is developed systematically, and the solution methods to all important problems are covered in detail. Therefore, this book will be useful not only to students, but likewise to scientists and practising engineers. All areas of heat and mass transfer are dealt with. Many calculated examples in the text and numerous exercises and elaborate solutions will facilitate learning and understanding. For the second edition, changes apply to heat and mass transfer correlations based on theoretical results or experimental findings. They were adapted to the state-of -the-art. Some of the worked examples as well as the compilation were revised or updated
    Fast non-rapidshare mirror
    http://mihd.net/1.613/Heat_and_Mass_Transfer.rar.html
    http://rapidshare.de/files/30068864/...s_Transfer.rar
  4. [274]
    أهل الحديث
    Received: 205
    Given: 261
    ASME B31.5-2001
    Refrigeration Piping and Heat Transfer Components
    American Society of Mechanical Engineers
    01-Dec-2001
    ISBN: 0791826295
    100 pages
    This Code prescribes requirements for the materials, design, fabrication, assembly, erection, test, and inspection of refrigerant, heat transfer components, and secondary coolant piping for temperatures as low as -320 deg F (-196 deg C), whether erected on the premises or factory assembled, except as specifically excluded in the following paragraphs. Users are advised that other piping Code Sections may provide requirements for refrigeration piping in their respective jurisdictions. This Code shall not apply to: (a) any self- contained or unit systems subject to the requirements of Underwriters Laboratories or other nationally recognized testing laboratory: (b) water piping; (c) piping designed for external or internal gage pressure not exceeding 15 psi (105 kPa) regardless of size; or (d) pressure vessels, compressors, or pumps, but does include all connecting refrigerant and secondary coolant piping starting at the first joint adjacent to such apparatus
    http://rapidshare.de/files/24347309/...r_4AH.rar.html
  5. [275]
    أهل الحديث
    Received: 205
    Given: 261
    Estimator's Piping Man-Hour Manual, Fifth Edition
    (Estimator's Man-Hour Library)
    Summary
    This reference provides reliable piping estimating data including installation of pneumatic mechanical instrumentation used in monitoring various process systems. This new edition has been expanded and updated to include installation of pneumatic mechanical instrumentation, which is used in monitoring various process systems
    11.34MB
    http://rapidshare.de/files/20902608/...__5th_ed._.rar
  6. [276]
    أهل الحديث
    Received: 205
    Given: 261
    Everything you need to plan, select, design, specify, and test entire piping systems Here's a complete design guide and reference for all service and utility piping systems found in laboratory, R specs and selection tips for piping, valves, and jointing methods; examples of system design procedures using actual field conditions; and listings of FDA, EPA, and OSHA requirements. This new edition has been revised to include metric units throughout; updated codes and standards that reflect
    http://rapidshare.de/files/24393258/5K200604110032.rar
    PASS: A14fr06fPsH2
    http://rapidshare.de/files/20976426/FPSH.rar.html
  7. [277]
    أهل الحديث
    Received: 205
    Given: 261
    Haynes VW Golf 2 & Jetta Service And Repair Manual
    Volkswagen Golf and Jetta Mk 2 Petrol (Mar 84 - Feb 92) A to J
    Golf Hatchback and Jetta Saloon (Mk 2) inc. 16-valve and special/limited editions, Mar 84 - Feb 92, A to J
    1.0 litre (1043cc), 1.3 litre (1272cc), 1.6 litre (1595cc) and 1.8 litre (1781cc)
    Contents
    Introduction Page
    Safety First! Page
    Roadside Repairs
    Introduction Page
    If your car won’t start Page
    Jump starting Page
    Wheel changing Page
    Identifying leaks Page
    Towing Page 0•9
    Weekly Checks
    Introduction Page 0•10
    Underbonnet check points Page 0•10
    Engine oil level Page 0•11
    Coolant level Page 0•11
    Brake fluid level Page 0•12
    Power steering fluid level Page 0•12
    Screen/headlamp washer fluid level Page 0•13
    Wiper blades Page 0•13
    Tyre condition and pressure Page 0•14
    Battery Page 0•15
    Electrical systems Page 0•15
    Lubricants and fluids Page 0•16
    Capacities and tyre pressures Page 0•17
    MAINTENANCE
    Routine Maintenance and Servicing
    Servicing specifications Page 1•2
    Maintenance schedule:
    Vehicles manufactured before August 1985 Page 1•5
    Vehicles manufactured after August 1985 Page 1•6
    Maintenance - component location Page 1•7
    Maintenance procedures Page 1•10
    REPAIRS & OVERHAUL
    Engine and Associated Systems
    Engine repair procedures - 1.05 and 1.3 litre - pre August 1985 Page 2A•1
    Engine repair procedures - 1.05 and 1.3 litre - post August 1985 Page 2B•1
    Engine repair procedures - 1.6 and 1.8 litre 8 valve Page 2C•1
    Engine repair procedures - 1.8 litre 16 valve Page 2D•1
    Cooling, heating and air conditioning systems Page 3•1
    Fuel and exhaust systems - carburettor models Page 4A•1
    Fuel and exhaust systems - K-Jetronic fuel injection - 8 valve engines Page 4B•1
    Fuel and exhaust systems - K-Jetronic fuel injection - 16 valve engines Page 4C•1
    Fuel and exhaust systems - Mono Jetronic fuel injection Page 4D•1
    Fuel and exhaust systems - Digijet fuel injection Page 4E•1
    Fuel and exhaust systems - Digifant fuel injection Page 4F•1
    Ignition system - contact breaker type Page 5A•1
    Ignition system - transistorised type Page 5B•1
    Ignition system - fully electronic type Page 5C•1
    Starting and charging systems Page 5D•1
    Transmission
    Clutch Page 6•1
    Manual gearbox Page 7A•1
    Automatic transmission Page 7B•1
    Driveshafts Page 8•1
    Brakes and Suspension
    Braking system Page 9•1
    Suspension and steering Page 10•1
    Body Equipment
    Bodywork and fittings Page 11•1
    Body electrical systems Page 12•1
    Wiring Diagrams Page 12•17
    REFERENCE
    Dimensions and Weights Page REF•1
    Conversion Factors Page REF•2
    Buying Spare Parts and Vehicle Identification Page REF•3
    General Repair Procedures Page REF•4
    Jacking and Vehicle Support Page REF•5
    Tools and Working Facilities Page REF•6
    MOT test checks Page REF•8
    Fault Finding Page REF•12
    Glossary of Technical Terms Page REF•20
    http://rapidshare.de/files/15763430/...air_Manual.rar
    http://rapidshare.de/files/10743144/...anual.pdf.html
  8. [278]
    أهل الحديث
    Received: 205
    Given: 261
    Elements of Gas Turbine Propulsion
    Author: Jack Mattingly
    Publisher: McGraw-Hill Science/Engineering/Math
    Publication Date: 1996-01-01
    Number Of Pages: 960
    Average Amazon Rating: 4.5
    This text provides an introduction to the fundamentals of gas turbine engines and jet propulsion for aerospace or mechanical engineers. The book contains sufficient material for two sequential courses i propulsion (advanced fluid dynamics) an introductory course in jet propulsion and a gas turbine engine components course. The text is divided into four parts introduction to aircraft propulsion; basic concepts and one-dimensional/gas dynamics; analysis and performance of air breathing propulsion
    http://rapidshare.de/files/22503702/...Propulsion.pdf
  9. [279]
    أهل الحديث
    Received: 205
    Given: 261
    Learn the latest advances in SiC (Silicon Carbide) technology from the leading experts in the field with this new cutting-edge resource. The book is your single source for in-depth information on both SiC device fabrication and system-level applications. This comprehensive reference begins with an examination of how SiC is grown and how defects in SiC growth can affect working devices.
    Key issues in selective doping of SiC via ion implantation are covered with special focus on implant conditions and electrical activation of implants. SiC applications discussed include chemical sensors, motor-control components, high-temperature gas sensors, and high-temperature electronics. By cutting through the arcane data and jargon surrounding the hype on SiC, this book gives an honest assessment of todayâ??s SiC technology and shows you how SiC can be adopted in developing tomorrowâ??s applications
    http://www.oxyshare.com/get/138124981344c37d9841b644.90334529/SESaddow.rar.html
    http://rapidshare.de/files/26730371/SESaddow.rar.html
    http://tinyurl.co.uk/e6xn
    http://rapidshare.de/files/5862104/Advances_In_Silicon_Carbide_Processing___Applicati ons_-_Artech_House.rar.html
    pass :www.blueportal.org
  10. [280]
    أهل الحديث
    Received: 205
    Given: 261
    Dimensioning and Tolerancing Handbook
    Author: Paul J. Drake
    Publisher: McGraw-Hill Professional
    Hardcover: 704 pages;
    Edition: 1999-10-14
    Summary
    This book tries to capture the major topics that fall under the umbrella of "Variation Management." The book is laid out so that the reader can easily understand the variation management process and how each chapter maps to this process. This book has two purposes. It is a"one-step" resource for people who want to know everything about dimensional management and variation management. It is a useful reference for specific target audiences within the variation management process. This book includes many new techniques, methodologies, and examples that have never been published before. Much of the new material revolves around Six Sigma techniques that have evolved within the past 5 years. This book offers high level information and expertise to a broad spectrum of readers, while providing detailed information for those needing specific information. The contributors are practitioners who have hands-onexperience. Much of the expertise in this book is a result of identifying needs to solve problems in our companies and businesses. Many of the chapters are the documented solutions to these needs
    http://rapidshare.de/files/5400247/DimTolHan.rar.html
    Pass: barbaxy*ebooksclub
