البرنامج الهندسي المدني Adapt_rc_v5.00.2-lnd
النتائج 1 إلى 9 من 9
    hassananas
    hassananas غير متواجد حالياً
    Received: 224
    Given: 6
    ADAPT_RC_V5.00.2-LND
    consistent results while minimizing errors and omissions. This screen shows a user defining a frame's geometry
    The definition of applied loading is as easy as selecting the appropriate load distribution model using the drag-and-drop interface and entering its value
    ADAPT-RC displays the model generated by you in multiple 3D views, showing all its features, such as drop cap/panel, and steps in the slab - enabling you to examine and verify the structural model before execution
    A shaded 3D solid model complements the wireframe mode
    ADAPT-RC presents its analysis results in comprehensive graphical and tabular formats.
    ADAPT-RC generates professional design reports. Image below is design report for a 3-span continuous T-beam.
    Using ADAPT-RC's investigation module, user can quickly define their provided reinforcement areas by initializing from the amount of required steel, as calculated by the program.
    A sample graphical rebar report showing provided vs. required reinforcement.
    Software for Design, Analysis, and Investigation of Reinforced (Nonprestressed) Concrete Beams, Slabs and Floor Systems
    Industry standard and choice of consulting engineers for an easy to use, efficient, and reliable production tool. This software is based on the proven Equivalent Frame Technology and features the following:
    * Complete modeling and design of a reinforced concrete floor
    * Analysis and capacity calculation of an existing floor (investigation mode)
    * One-way and two-way floor systems
    * Beam frames
    * Drop caps, drop panels, steps above and below the slab
    * Multiple beam cross-section: T, L and I-section
    * Reinforcement check for strength and minimum code requirements
    * Beam shear and punching shear checks
    * Integrated punching shear reinforcement design (studs or stirrups)
    * Deflection calculation, including cracked section analysis
    * Gives the capacity of a floor system for a user-defined reinforcement distribution
    * Performs capacity/demand analysis for existing floor systems
    * Graphical display of moments, shears and deflections
    * Graphical and tabular display of location, length and amount of reinforcement required.
    * Click here for ADAPT-RC Screen Shots...
    Codes
    The program comes supports the following design codes:
    ACI-318 1999 and 2005
    IBC International Building Code 2003
    British-BS8110 1985
    Canadian-A23.3 1994
    Australian-AS3600 2001
    Brazilian-NBR6118 2001
    European EC2 2004
    Units
    The program supports the following units:
    SI
    MKS
    American Customary
    Hardware Requirements
    PC compatible computer
    Windows operating system
    Minimum of 128 MB RAM
    10 GB hard drive
    Download: 21.609 MB
    http://rapidshare.de/files/23007052/...2-LND.rar.html
    Password: www.devilived.com
    aalmasri
    aalmasri غير متواجد حالياً
    عضو تحرير المجلة
    الصورة الرمزية aalmasri
    Received: 10
    الملف غير موجود اخي, هل يمكن التأكد منه؟
    عمروعلى3
    عمروعلى3 غير متواجد حالياً
    الصورة الرمزية عمروعلى3
    أخى برجاء اعدة وضع الرابط الصحيح مرة أخرى
    وعلى فكرة يجب ان تنقله باستخدام
    copy shortcut
    وليس
    copy
    أخوانى فى الله اعضاء الملتقى الكرام
    كنت قد انقطعت لفترة كبيرة عن التواصل معكم
    ووجدت رسائل على الخاص كثيره يطلب فيها راسليها المساعده
    لذلك اعتذر لكم جميعا عن عدم التواصل والرد عليها فى حينها
    كن صديق على الفيس بوك
    CVLMASTER
    CVLMASTER غير متواجد حالياً
    الصورة الرمزية CVLMASTER
    Received: 18
    مشكور
    مشكورمشكور
    مشكورمشكورمشكور
    مشكورمشكورمشكورمشكور
    مشكورمشكورمشكورمشكورمشكور
    مشكورمشكورمشكورمشكورمشكورمشكور
    مشكورمشكورمشكورمشكورمشكورمشكورمشكور
    مشكورمشكورمشكورمشكورمشكورمشكورمشكورمشكور
    مشكورمشكورمشكورمشكورمشكورمشكورمشكورمشكورمشكور
    مشكورمشكورمشكورمشكورمشكورمشكورمشكورمشكورمشكورمشكور
    مشكورمشكورمشكورمشكورمشكورمشكورمشكورمشكورمشكورمشكور مشكور
    مشكورمشكورمشكورمشكورمشكورمشكورمشكورمشكورمشكورمشكور مشكورمشكور
    مشكورمشكورمشكورمشكورمشكورمشكورمشكورمشكورمشكورمشكور مشكورمشكورمشكور
    مشكورمشكورمشكور
    مشكورمشكور
    مشكور
    File Not Found
    أحمد المرزوقى
    أحمد المرزوقى غير متواجد حالياً
    Given: 3
    الملف تم ازالته من الرابط
    برجاء اعادة رفعه
    م. الباحث
    م. الباحث غير متواجد حالياً
    ارجو اذا كان هناك امكانية اعادة رفعه على موقع اخر
    سردار عزالدين علي
    سردار عزالدين علي غير متواجد حالياً
    Received: 18
    رجاءا اعادة التحميل
    mohy_y2003
    mohy_y2003 غير متواجد حالياً
    الصورة الرمزية mohy_y2003
    Received: 350
    Given: 448
    الملف غير موجود برجاء اعاده رفعه
    مهندس إسلام سامى
    مهندس إسلام سامى غير متواجد حالياً
    Received: 13
    جزاك الله كل خير
