Performance Test Run
النتائج 1 إلى 3 من 3
    The river
    The river غير متواجد حالياً
    Dear All
    any one has done or has experince in Performance Test RUn for new unit in the refinery ?
    i need your help to calculate the Performance of Heat Exchanger
    The river
    Performance Test Run for H.Exchanger
    after searching through the net i found the attached file .in this file you can find how the duty can be calculated of Heat Exchanger .
    sultan0064
    sultan0064 غير متواجد حالياً
    Thanks and thanks alot
