Megapost Solidworks 2006: Official training manuals (PDF) + Project files
النتائج 1 إلى 10 من 15
    أهل الحديث
    أهل الحديث غير متواجد حالياً
    Received: 206
    Given: 261
    SolidWorks uses a limited "parametric" approach to modeling and assembling. In the SolidWorks 3D modeling environment the creation of a solid or surface typically begins with the definition of topology in either a 2D or 3D sketch. The topology defines the connectivity and certain geometric relationships between vertices and curves both in the sketch and external to the sketch. To this topology are added dimensions which determine the lengths and sizes for the curves and locations for the vertices in conjunction with topological constraints. The dimensions which are added are termed "parameters" because they can be changed either independently or by "parameters" created prior to their creation. The dimensions are limited "parameters" because they cannot be varied by subsequent actions on the sketch in which they are defined. An example of this limitation is to create a simple rectangle in a 2D sketch, place dimensions on the sides of the rectangle and then to extrude the 2D sketch to form a parallel piped shape. The sketch dimensions cannot be varied based on the location of the 2D sketch (generatrix) along the extrusion length. SolidWorks would not allow the height "parameter" of the rectangle to vary with the square of the distance extruded. In other words the dimensions or "parameters" cannot be parameterized to "parameters" created in the subsequent hierarchy of features. Parameters are therefore fixed in the feature that contains them. SolidWorks is therefore hierarchical in the creation of features in that subsequent features should have no effect on prior features. To create volume and modifications, SolidWorks employs a feature-based system that can be rolled back to previous states in case something must be changed or multiple configurations of the same part must be handled. To assemble components, mates are created, which define the relative positions of the components to each other
    Solidworks 2006 official Engineering drawing training
    http://rapidshare.de/files/35909874/...Prerelease.zip 91.83 MB
    Solidworks 2006 official Advanced assembly modeling training
    http://rapidshare.de/files/35909225/...Prerelease.zip 91.62 MB
    Solidworks 2006 official Essential parts and assemblies trainig
    http://rapidshare.de/files/35903457/...Prerelease.zip 55.66 MB
    Solidworks 2006 official File management training
    http://rapidshare.de/files/35901416/...Prerelease.zip 61.51 MB
    Solidworks 2006 official Advanced part modeling training
    http://rapidshare.de/files/35899058/...Prerelease.zip 75.01 MB
    SOLIDWORKS OFFICIAL 2006 API TRAINING
    http://rapidshare.de/files/35898900/...Prerelease.zip 39.19 MB
    Solidworks 2006 official Sheet ****l and weldments training
    http://rapidshare.de/files/35898835/...Prerelease.zip 19.05 MB
    abo_slaim
    abo_slaim غير متواجد حالياً
    جزاك الله خير وغفر الله لك ولوالديك
    وجعله في ميزان حسناتك
    MDREAM
    MDREAM غير متواجد حالياً
    الف شكر لك
    و كل عام وانت بخير
    رمضان كريم
    تحياتي
    Mdream
    MDREAM
    ملتقى المهندسين العرب
    منتدى التحكم الرقمى بإستخدام الحاسب (CNC)
    MDREAMES*YAHOO.CO.UK
    badreco_73
    badreco_73 غير متواجد حالياً
    شكرا ولكن اريد كراك للبرنامج
    productique
    productique غير متواجد حالياً
    الصورة الرمزية productique
    أرجو تعديل الروابط...
    و شكرااااااااااااا
    productique
    الله الله عليك
    هذه قنبلة
    بورك فيك فقد كنت في امس الحاجة للapi من اجل مشروع التخرج
    productique
    Lightbulb crack solidworks2006
    mohamedhassan20
    mohamedhassan20 غير متواجد حالياً
    شكــــــــــــــــرا جزيلا
    الدبووور
    الدبووور غير متواجد حالياً
    يارك الله فيك يا أخى على هذا الجهد الكبير وجعله فى ميزان حسناتك.
    taherispeng
    taherispeng غير متواجد حالياً
    جزاكم الله خيرا
