Cable Selection
النتائج 1 إلى 10 من 10
    s028809
    s028809 غير متواجد حالياً
    Cable Selection
    Al-Salam Alikm
    Kol A'am Wa Antom Bekhayer
    Ramadan Kareem
    I need help in how to select cable for a motor and transformer and I appreciate if the answer is in english.
    links, Pdf, or Doc ... ets.
    thank you for this great website
    من مواضيع s028809 :
    ماجد عباس محمد
    Received: 152
    For motors,
    1- determine is it a single or 3phase and find the current per wire
    2- as a rule of thumb , use 1mm squared per 4 amperes
    3- once you get the area needed, select the next larger standered cross section cable available
    For transformers,mostly it is 3 phase
    use the above technique but also see that the cable can handle the voltage involved as it is expected to be a high voltage transformer
    s028809
    Thank you Mr. Majed.. i appreciate your Corroboration but i need more details with equations and stuff .. I am in the middle of a project, i have to choose a cable for a submersable motor
    ماجد عباس محمد
    Received: 152
    power dissipated in cable=I^2 x r where r =cable ohmic resistance per unit length
    apply in temperature equation involving the mass of cable and heat dissipated in cable insulation to find temperature rise
    assume a safe heat rise in cable teperature then work the equations back to get the safe current allowed per unit area
    people have done that and come up with around 3-4 ampere per 1 mm squared, you can find that any power text book
    Also you can search google http://www.google.com for cable current
    this site http://www.tlc-direct.co.uk/Book/4.3.9.htm has some information
    s028809
    Thank you very much Mr. Majid
    SAAD RASHED
    SAAD RASHED غير متواجد حالياً
    الصورة الرمزية SAAD RASHED
    الكابلات يتم تحديد مواصفاتها بنائا على عوامل كثيرة ويمكن الجوع الى كتيبات الشركات المنتجة للحصول على المعلومات
    حازم فايد
    حازم فايد غير متواجد حالياً
    for motors u have to know the how it will start below 10 kw u can make direct online start DOL with starting current Ist = 2.5 IN so u have to calculate the cable on that base , for motors greater than 10 kw you can build ur calculations on IST = 1.25 IN
    يوسف حميض
    يوسف حميض غير متواجد حالياً
    الصورة الرمزية يوسف حميض
    Received: 8
    D.O.L. starting: Maximum starting current:
    x rated current Maximum
    starting time: 5 sec.
    y
    /d starting: Maximum starting current:
    starting time: 15 sec.
    Motor overload relay in
    phase current: set to 0.58
    x
    rated current.
    الله اكبر الله اكبر لا إله إلا الله
    الله اكبر الله اكبر و لله الحمد
    يوسف حميض
    Received: 8
    y
    x
    rated current.
    wadei
    wadei غير متواجد حالياً
    شكرا جزيلا جزيلا أخي العزيز
