Hiren's BootCD 8.5 أقوى سيديات الصيانة ... للمهندسيين
النتائج 11 إلى 20 من 22
    nidal_rifai
    nidal_rifai غير متواجد حالياً
    Thumbs up سي دي بوت وتصليح كل شيء
    اعزائي اقدم لكم الرابط الجديد هنا وجدته وانا ابحث عن السي دي المذكور
    مع تحيات الخيّال وعلى كلاً انا هلا نزلته بس يكمل البرنامج تنزيل راح ارفعه كرابط ومضغوط
    موجود الداونلود في اخر الصفحه بعد ان تفتحها
    http://www.9down.com/downloads.php?fileid=410
    nidal_rifai
    كل هذه الادوات في سي دي واحد فقط نزل السي دي وتمتع مع تحيات الخيّال
    الرابط هو
    All in one Dos Bootable CD which has all these utilities.
    Partition Tools
    Partition Magic Pro 8.05
    Best software to partition hard drive
    Acronis Disk Director Suite 9.0.554
    Popular disk management functions in a single suite
    Paragon Partition Manager 7.0.1274
    Universal tool for partitions
    Partition Commander 9.01
    The safe way to partition your hard drive,with undo feature
    Ranish Partition Manager 2.44
    a boot manager and hard disk partitioner.
    The Partition Resizer v1.3.4
    move and resize your partitions in one step and more.
    Smart Fdisk 2.05
    a simple harddisk partition manager
    SPecial Fdisk 2000
    SPFDISK a partition tool.
    eXtended Fdisk 0.9.3
    XFDISK allows easy partition creation and edition
    GDisk 1.1.1
    Complete replacement for the DOS FDISK utility and more.
    Disk Clone Tools
    ImageCenter 5.6 (Drive Image 2002)
    Best software to clone hard drive
    Norton Ghost 8.3
    Similar to Drive Image (with usb/scsi support)
    Acronis True Image 8.1.945
    Create an exact disk image for complete system backup and disk cloning.
    Partition Saving 3.20
    A tool to backup/restore partitions. (SavePart.exe)
    COPYR.DMA Build013
    A Tool for making copies of hard disks with bad sectors
    Antivirus Tools
    F-Prot Antivirus 3.16f (0410)
    Very good virus scanner (with ntfs support and easy to use menu)
    McAfee Antivirus 4.40 (0410)
    a virus scanner (with ntfs support and easy to use menu)
    Recovery Tools
    Active Partition Recovery 3.0
    To Recover a Deleted partition.
    Active Uneraser 3.0
    To recover deleted files and folders on FAT and NTFS systems.
    Ontrack Easy Recovery Pro 6.10
    To Recover data that has been deleted/virus attack
    Winternals Disk Commander 1.1
    more than just a standard deleted-file recovery utility
    TestDisk 6.5b
    Tool to check and undelete partition.
    Lost & Found 1.06
    a good old data recovery software.
    DiyDataRecovery Diskpatch 2.1.100
    An excellent data recovery software.
    Prosoft Media Tools 5.0 v1.1.2.64
    Another excellent data recovery software with many other options.
    PhotoRec 6.5b
    File and pictures recovery Tool.
    Testing Tools
    System Speed Test 4.78
    it tests CPU, harddrive, ect.
    PC-Check 6.0
    Easy to use hardware tests
    Ontrack Data Advisor 5.0
    Powerful diagnostic tool for assessing the condition of your computer
    The Troubleshooter 7.02
    all kind of hardware testing tool
    PC Doctor 3.0
    a benchmarking and information tool
    Test Cpu/Video/Disk 5.6
    a tool to test cpu, video, and disk
    Test Hard Disk Drive 1.0
    a tool to test Hard Disk Drive
    RAM (Memory) Testing Tools
    DocMemory 3.1b
    RAM Test utility
    GoldMemory 5.07
    RAM Test utility
    Memtest86+ 1.65
    PC Memory Test
    Hard Disk Tools
    Hard Disk Diagnostic Utilities
    Seagate Seatools Desktop Edition 3.02
    Western Digital Data Lifeguard Tools
    Western Digital Diagnostics (DLGDIAG) 5.04f
    Maxtor PowerMax 4.23
    Maxtor amset utility 4.0
    Maxtor(or any Hdd) Low Level Formatter 1.1
    Fujitsu HDD Diagnostic Tool 6.61
    Fujitsu IDE Low Level Format 1.0
    Samsung HDD Utility(HUTIL) 2.02
    Samsung Disk Diagnose (SHDIAG) 1.28
    IBM/Hitachi Drive Fitness Test 4.08
    IBM/Hitachi Feature Tool 2.03
    Gateway GwScan 3.15
    ExcelStor's ESTest 3.80
    MHDD 4.6
    WDClear 1.30
    Toshiba Hard Disk Diagnostic 2.00b
    HDD Regenerator 1.51
    to recover a bad hard drive
    Ontrack Disk Manager 9.57
    Disk Test/Format/Maintenance tool.
    Norton Disk Doctor 2002
    a tool to repair a damaged disk, or to diagnose your hard drive.
    Norton Disk Editor 2002
    a powerful disk editing, manual data recovery tool.
    Active Kill Disk 1.1
    Securely overwrites and destroys all data on physical drive.
    HDAT2 4.5.2
    main function is testing and repair (regenerates) bad sectors for detected devices
    SmartUDM 2.00
    Hard Disk Drive S.M.A.R.T. Viewer.
    Victoria 3.33
    a freeware program for low-level HDD diagnostics
    System Information Tools
    Aida16 2.14
    a system information tool, extracts details of all components of the PC
    PCI and AGP info Tool (0410)
    The PCI System information & Exploration tool.
    System Analyser version 5.3o
    View extensive information about your hardware
    Navratil Software System Information 0.59.9
    High-end professional system information tool
    Astra 5.21
    Advanced System info Tool and Reporting Assistant
    HwInfo 5.0.3
    a powerful system information utility
    PC-Config 9.33
    Complete hardware detection of your computer
    SysChk 2.46
    Find out exactly what is under the hood of your PC
    CPU Identification utility v1.12
    Detailed information on CPU (CHKCPU.EXE)
    CTIA CPU Information
    another CPU information tool
    MBR (Master Boot Record) Tools
    MBRWork 1.07b
    a utility to perform some common and uncommon MBR functions
    MBR Tool 2.2.100
    backup, verify, restore, edit, refresh, remove, display, re-write...
    DiskMan4
    all in one tool for cmos, bios, bootrecord and more
    BootFix Utility
    Run this utility if you get 'Invalid system disk'
    MBR SAVE / RESTORE 2.1
    BootSave and BootRest tools to save / restore MBR
    Boot Partition 2.60
    add Partition in the Windows NT/2000/XP Multi-boot loader
    Partition Table Doctor 3.0
    a tool to repair/modify mbr, bootsector, partition table
    Smart Boot Manager 3.7.1
    a multi boot manager
    Bootmagic 8.0
    This tool is for multi boot operating systems
    MBRWizard 2.0b
    Directly update and modify the MBR (Master Boot Record)
    BIOS / CMOS Tools
    CMOS 0.93
    CMOS Save / Restore Tool
    BIOS Cracker 4.8
    BIOS password remover (cmospwd)
    BIOS Cracker 1.4
    BIOS password remover (cmospwc)
    BIOS Utility 1.35.0
    BIOS Informations, password, beep codes and more.
    !BIOS 3.20
    a powerfull utility for bios and cmos
    DISKMAN4
    a powerful all in one utility
    UniFlash 1.40
    bios flash utility
    Kill CMOS
    a tiny utility to wipe cmos
    MultiMedia Tools
    Picture Viewer 1.94
    Picture viewer for dos, supports more then 40 filetypes.
    QuickView Pro 2.57
    movie viewer for dos, supports many format including divx.
    MpxPlay 1.54
    a small Music Player for dos
    Password Tools
    Active Password Changer 3.0
    To Reset User Password on windows NT/2000/XP/2003 (FAT/NTFS)
    Offline NT/2K/XP Password Changer
    utility to reset windows nt/2000/xp administrator/user password.
    Registry Viewer 4.2
    Registry Viewer/Editor for Win9x/Me/NT/2K/XP
    Registry Reanimator v1.02
    check and restore structure of the damaged registry files of NT/2K/XP
    NTPWD
    ATAPWD 1.2
    Hard Disk Password Utility
    NTFS Ext2FS, Ext3FS (FileSystems) Tools
    NTFS Dos Pro 5.0
    To access ntfs partitions from Dos
    NTFS 4 Dos 1.4
    Paragon Mount Everything 3.0
    To access NTFS, Ext2FS, Ext3FS partitions from dos
    NTFS Dos 3.02
    EditBINI 1.01
    to Edit boot.ini on NTFS Partition
    Dos File Managers
    Volkov Commander 4.99
    Dos File Manager with LongFileName/ntfs support
    (Similar to Norton Commander)
    Dos Command Center 5.1
    Classic dos-based file manager.
    File Wizard 1.35
    a file manager - colored files, drag and drop copy, move, delete etc.
    File Maven 3.5
    an advanced Dos file manager with high speed PC-to-PC file
    transfers via serial or parallel cable
    FastLynx 2.0
    Dos file manager with Pc to Pc file transfer capability
    LapLink 5.0
    the smart way to transfer files and directories between PCs.
    Dos Navigator 5.9.0
    Dos File Manager, Norton Commander clone but has much more features
    Mini Windows 98
    Can run from Ram Drive, with ntfs support,
    Added 7-Zip which supports .7z .zip .cab .rar .arj .gzip,
    .bzip2 .z .tar .cpio .rpm and .deb
    Disk Defragmenter, Notepad / RichText Editor,
    Image Viewer, .avi .mpg .divx .xvid Movie Player, etc...
    Other Tools
    Ghost Walker 2003.793
    utility that changes the security ID (SID) for Windows NT, 2000 and XP
    DosCDroast beta 2
    Dos CD Burning Tools
    Universal TCP/IP Network 5.8
    MSDOS Network Client to connect via TCP/IP to a Microsoft based
    network. The network can either be a peer-to-peer or a server based
    network, it contains 85 different network card drivers
    Dos Tools
    USB CD-Rom Driver 1
    Standard usb_cd.sys driver for cd drive
    Universal USB Driver 2
    Panasonic v2.20 ASPI Manager for USB mass storage
    SCSI Support
    SCSI Drivers for Dos
    1394 Firewire Support
    1394 Firewire Drivers for Dos
    Interlnk support at COM1
    To access another computer from COM port
    Interlnk support at LPT1
    To access another computer from LPT port
    and too many great dos tools
    very good collection of dos utilities
    extract.exe pkzip.exe pkunzip.exe unrar.exe rar.exe
    ace.exe lha.exe gzip.exe uharcd.exe mouse.com
    attrib.com deltree.exe xcopy.exe diskcopy.com imgExtrc.exe
    undelete.com edit.com fdisk.exe fdisk2.exe fdisk3.exe
    lf.exe delpart.exe wipe.com zap.com format.com
    move.exe more.com find.exe hex.exe debug.exe
    split.exe mem.exe mi.com sys.com smartdrv.exe
    xmsdsk.exe killer.exe share.exe scandisk.exe scanreg.exe
    guest.exe doskey.exe duse.exe biosdtct.exe setver.exe
    ntersvr.exe interlnk.exe loadlin.exe lfndos.exe doslfn.com
    Windows Tools
    SpaceMonger 1.4
    keeping track of the free space on your computer
    Drive Temperature 1.0
    Hard Disk Drive temperature meter
    Disk Speed 1.0
    Hard Disk Drive Speed Testing Tool
    MemTest 1.0
    a Memory Testing Tool
    PageDfrg 2.32
    System file Defragmenter For NT/2k/XP
    WhitSoft File Splitter 4.5a
    a Small File Split-Join Tool
    Ghost Image Explorer 8.3
    to add/remove/extract files from Ghost image file
    DriveImage Explorer 5.0
    to add/remove/extract files from Drive image file
    Drive SnapShot 1.37
    creates an exact Disk Image of your system into a file while windows is running.
    Active Undelete 5.1.010
    a tool to recover deleted files
    Restoration 2.5.14
    GetDataBack for FAT 2.31
    Data recovery software for FAT file systems
    GetDataBack for NTFS 2.31
    Data recovery software for NTFS file systems
    Startup Control Panel 2.8
    a tool to edit startup programs
    Startup Monitor 1.02
    it notifies you when any program registers itself to run at system startup
    IB Process Manager 1.04
    a little process manager for 9x/2k, shows dll info etc.
    Pocket KillBox 2.0
    can be used to get rid of files that stubbornly refuse to allow you to delete them
    HijackThis 1.99
    a general homepage hijackers detector and remover and more
    RootkitRevealer 1.7
    Rootkit Revealer is an advanced patent-pending root kit detection utility.
    Silent Runners Revision 48
    A free script that helps detect spyware, malware and adware in the startup process
    Autoruns 8.53
    Displays All the entries from startup folder, Run, RunOnce, and other Registry keys,
    Explorer shell extensions,toolbars, browser helper objects, Winlogon notifications,
    auto-start services, Scheduled Tasks, Winsock, LSA Providers, Remove Drivers
    and much more which helps to remove nasty spyware/adware and viruses.
    CurrPort 1.07
    displays the list of all currently opened TCP and UDP ports on your computer
    Unknown Devices 1.2 (0410)
    helps you find what those unknown devices in Device Manager really are
    PCI 32 Sniffer 1.1 (0410)
    device information tool (similar to unknown devices)
    NewSID 4.10
    Double Driver 1.0
    Driver Backup and Restore tool
    CPU-Z 1.37
    It gathers information on some of the main devices of your system
    CWShredder 2.19
    Popular CoolWebSearch Trojan Remover tool
    Winsock 2 Fix for 9x
    to fix corrupted Winsock2 information by poorly written Internet programs
    XP TCP/IP Repair 1.0
    Repair your Windows XP Winsock and TCP/IP registry errors
    CCleaner 1.33.382
    Crap Cleaner is a freeware system optimization and privacy tool
    EzPcFix 1.0.0.16
    Helpful tool when trying to remove viruses, spyware, and malware
    ******* Advisor Password Remover 1.0
    It Removes ******* Advisor Password from Internet Explorer
    Spybot - Search & Destroy 1.4 (0410)
    Application to scan for spyware, adware, hijackers and other malicious software.
    SpywareBlaster 3.5.1 (0410)
    Prevent the installation of spyware and other potentially unwanted software.
    Ad-Aware SE Personal 1.06 (0410)
    find and remove spyware, adware, dialers etc. (a must have tool)
    Download Mirror
    engramy
    engramy غير متواجد حالياً
    الصورة الرمزية engramy
    Received: 12
    مشكور أخي الكريم
    م/محترف
    م/محترف غير متواجد حالياً
    1000 1000 شكرا لك :) :)
    nidal_rifai
    الى الاخ العزيز م/محترف
    هل جربته ونسخته على سي دي حتى يبوت من الدوس اذا جربته ونجحت الطريقه وضهر عندك كل الخيارات احكيلي الطريقه معلش انا ناشر الموضوع
    احمد شوملي
    احمد شوملي غير متواجد حالياً
    الى الاخوه الاعزاء :
    لقد قمت بتنزيل Cd ولكن واجهة مشكله وهي عند القيام بفك ظغط الملف يطلب باسوارد
    فاذا سمحتو انا بحاجة الباسوارد وشكراً لكم
    مشكورييييييييييييييين
    engramy
    Received: 12
    اقتباس المشاركة الأصلية كتبت بواسطة احمد شوملي مشاهدة المشاركة
    أخي الكريم إليك الباسورد
    UnRAR Password: www.9down.com
    engramy
    Received: 12
    اقتباس المشاركة الأصلية كتبت بواسطة nidal_rifai مشاهدة المشاركة
    أخي الكريم
    يجب نسخ الـCD بطريقة Copy CD 1 to 1 وليس عن طريق copy و Past أو أي طريقة أخرى
    ضع الإسطوانة في أي برنامج إسطوانات وهمية Virtual CD وأنصحك ببرنامج Virtual CD v7 وشغل برنامج الـNero وإختار copy cd وتابع العملية إلي النهاية
    وإن شاء الله الإسطوانة هتشتغل 100 %
    memo star
    memo star غير متواجد حالياً
    جزاكم الله خير اخى وبارك فيك
    علاء الدين2
    علاء الدين2 غير متواجد حالياً
    شكرا جاري التحميل.............
    الحمد لله الذي هدانا لهذا وما كنا لنهتدي لولا ان هدانا الله
