Oracle9i - The Complete Reference
النتائج 1 إلى 7 من 7
    الصورة الرمزية عمروعلى3
    عمروعلى3
    عمروعلى3 غير متواجد حالياً
    Oracle9i: The Complete Reference
    ISBN 0072225211 | Oracle Press | August 2002 |1256
    pages | pdf | 23 MB
    Table of *******s
    PART I: Critical Database Concepts
    1: Sharing Knowledge and Success
    2: The Dangers in a Relational Database
    3: The Basic Parts of Speech in SQL
    4: The Basics of Object-Relational Databases
    5: Introduction to Web-Enabled Databases
    PART II: SQL and SQL*PLUS
    6: Basic SQL*PLUS Reports and Commands
    7: Getting Text Information and Changing It
    8: Playing the Numbers
    9: Dates: Then, Now, and the Difference
    10: Conversion and Transformation Functions
    11: Grouping Things Together
    12: When One Query Depends upon Another
    13: Some Complex Possibilities
    14: Building a Report in SQL*PLUS
    15: Changing Data: insert, update, merge, and delete
    16: Advanced Use of Functions and Variables
    17: DECODE and CASE: if, then, and else in SQL
    18: Creating, Dropping, and Altering Tables and Views
    19: By What Authority?
    20: Changing the Oracle Surroundings
    21: Using SQL*Loader to Load Data
    22: Accessing Remote Data
    23: Using Materialized Views
    24: Using Oracle Text for Text Searches
    25: Using External Tables
    26: Using Flashback Queries
    PART III: PL/SQL
    27: An Introduction to PL/SQL
    28: Triggers
    29: Procedures, Functions, and Packages
    PART IV: Object-Relational Databases
    30: Implementing Types, Object Views, and Methods
    31: Collectors (Nested Tables and Varying Arrays)
    32: Using Large Objects
    33: Advanced Object-Oriented Concepts
    PART V: Java in Oracle
    34: An Introduction to Java
    35: JDBC and SQLJ Programming
    36: Java Stored Procedures
    PART VI: Hitchhiker’s Guides
    37: The Hitchhiker’s Guide to the Oracle9i Data Dictionary
    38: The Hitchhiker’s Guide to the Oracle Optimizer
    39: The Hitchhiker’s Guide to Oracle9iAS
    40: The Hitchhiker’s Guide to Database Administration
    41: The Hitchhiker’s Guide to XML in Oracle
    PART VII: Alphabetical Referenc
    التحميل
    http://rapidshare.de/files/30929109/...rence.zip.html
    من مواضيع عمروعلى3 :
    أخوانى فى الله اعضاء الملتقى الكرام
    كنت قد انقطعت لفترة كبيرة عن التواصل معكم
    ووجدت رسائل على الخاص كثيره يطلب فيها راسليها المساعده
    لذلك اعتذر لكم جميعا عن عدم التواصل والرد عليها فى حينها
    كن صديق على الفيس بوك
    Eng_Mido
    Eng_Mido غير متواجد حالياً
    جزاك الله خير
    rudhf
    rudhf غير متواجد حالياً
    بارك الله فيك لكن الرابط لا يعمل
    Ahmed Abdel raouf
    Ahmed Abdel raouf غير متواجد حالياً
    جزاك الله خيرا ..........أرجو إعادة رفع الملف لأنه حذف من علي الـ rapidshare
    إليكم هذه المحاضرة الرائعة للشيخ محمد الصاوي بعنوان أنا وحبيبتي يروي علينا قصصا" من واقع الحياة لا للتسلية ولكن للعبرة والعظة ...................
    أسأل الله أن ينفعني وإياكم ...
    لحفظ المحاضرة
    http://rapidshare.com/files/29213437...78___1610_.rar
    طالبة ماجستير
    طالبة ماجستير غير متواجد حالياً
    No File :(
    زماليلطفي
    زماليلطفي غير متواجد حالياً
    ORCALE 10g
    أبحث عن كتب متعلقة ب ORCALE 10g باللغة الفرنسية
    شكرا
    ادور
    ادور غير متواجد حالياً
    عضو متميز جداً
    الصورة الرمزية ادور
    Given: 5
    مشكورررررررررررر جدا لك
    وكل التقدم والنجاح
