من يتكرم بارسال برامج لرسم الدوائر الكهربية والالكترونية
النتائج 1 إلى 10 من 15
    Dr mom
    Dr mom غير متواجد حالياً
    السلام عليكم ورحمته وبركاته
    انى منتظر الرد " من يتكرم بارسال برامج لرسم الدوائر الكهربية والالكترونية" وساكون شاكرا له هذا الصنيع
    ماجد عباس محمد
    Received: 152
    قم بالبحث عن
    PCB software
    Schematic Capture
    وستجد كثير من البرامج اختر ارخصها
    أهل الحديث
    أهل الحديث غير متواجد حالياً
    Received: 206
    Given: 261
    Protel Schematic 1.0
    First our schematic capture package captures the circuit schematics. From the schematics, it will generate a netlist. This netlist will be used as an input to the PCB layout package. The use of an integrated package makes it possible to link the circuit schematic with the final layout; and this allows us to run a Design Rule Check to verify that the final PCB matches the original schematics
    In case you have not entered your circuit diagram in a schematic capture software, but have it available hand-drawn on paper or as graphic file, our layout designers will capture your schematics on our schematics capture package.
    http://www.tretek.ca/schematic_capture.htm
    التحميل :
    ftp://217.219.86.36/Engineering/Prot...01.0/Setup.exe
    { الَّذِينَ آتَيْنَاهُمُ الْكِتَابَ يَعْرِفُونَهُ كَمَا يَعْرِفُونَ أَبْنَاءَهُمُ }
    أهل الحديث
    Received: 206
    Given: 261
    Proteus PCB Design Packages
    Proteus PCB design combines the ISIS schematic capture and ARES PCB layout programs to provide a powerful, yet easy to use suite of tools for designing printed circuit board.
    Whilst the ARES package can be used as a 'computerized light box', the usual approach is to draw the circuit diagram in ISIS, and then to create a PCB from it using ARES. The netlist integration between the two packages ensures that the connectivity of the PCB exactly matches that drawn on the schematic.
    All Proteus PCB design products also include a basic SPICE simulation capability which can be extended by purchasing the Advanced Simulation option
    The products are offered at a number of levels which offer increasing levels of functionality and design capacity:
    Proteus Professional Starter Kit
    Full feature ISIS schematic capture with support for hierarchical design, bus pins, configurable bill of materials and much, much more
    Netlist based ARES PCB layout with support of up to 16 copper layers, 10nm resolution, any angle component placement, full electrical and physical design rule checks and much more.
    Standard version of our integrated auto-router.
    Support for one shaped based ground plane per layer.
    Component libraries containing over 8000 schematic parts and 1000 PCB footprints.
    Includes ProSPICE mixed mode simulator with 6000 models and 9 virtual instruments.
    500 pin capacity for PCB design
    Please note that the Starter Kit is limited to netlists of 500 physical pins and does not support automatic component placement, gate-swap optimization, partial power planes (including cut-outs) or rip-up and retry autorouting. These features are only available in Level 2 and above.
    Proteus PCB Design Level 1 and Level 1+
    These products offer exactly the same functionality as the Starter Kit but offer more realistic design capacities of 1000 or 2000 pins
    1000 pin capacity in Level 1; 2000 pin capacity in Level 1+
    Please note that Level 1/1+ is limited to netlists of 1000/2000 physical pins and does not support automatic component placement, gate-swap optimization, partial power planes (including cut-outs) or rip-up and retry autorouting. These features are only available in Level 2 and above.
    Proteus PCB Design Level 2 and Level 2+
    These products are restricted in terms of pin count only, and same set of features as the top of the range Level 3. Extra functionality over Level 1 includes:
    Automatic component placement – this tool will automatic place the component specified in the netlist onto the board.
    Rip up and retry autorouting. This enables the router achieve 100% completion on many boards.
    Electra Shape Based Autorouter Interface - allows export and import of designs from the Electra Autorouter.
    Unlimited shape based power planes per layer.
    Automatic gateswap optimization.
    1000 pin capacity in Level2; 2000 pin capacity in Level 2+.
    Proteus PCB Design Level 3
    This is the top of the range package and offers all system features as above plus unlimited design capacity
    Down
    http://rapidshare.de/files/31703498/...ional.rar.html
    Tutorial
    http://rapidshare.de/files/31702140/...EUS--.rar.html
    password : agi82
    أهل الحديث
    Received: 206
    Given: 261
    هذا الموقع يفيدك :
    http://www.discovercircuits.com/index.htm
    أهل الحديث
    Received: 206
    Given: 261
    Electronics Workbench Multisim v9.0.155
    Multisim, the world’s only interactive circuit simulator, allows you to design better products in less time.
    Multisim includes a completely integrated version of Multicap, making it the ideal tool for creating and then instantly simulating circuits.
    Multisim 9 also offers integration with National Instruments LabVIEW and SignalExpress, allowing you to tightly integrate design and test.
    Featuring unparalleled ease-of-use and packed with unique and powerful functions, Multisim boasts an impressive history that has made it the most successful simulator in the industry with over 180,000 users worldwide. Combined with Multisim’s aggressive price, there is now no reason not to simulate every design.
    TIME-SAVING PRODUCT INNOVATIONS:
    * Integration with National Instruments LabVIEW and SignalExpress
    * A 67% increase in simulation speed
    * Simulated “real” Tektronix® instruments
    * Robust measurement probes annotate circuit with dynamic values
    * Support for design variants
    * Simulation profiles (save and reuse SPICE parameter sets)
    * New Circuit Wizards and Model Makers
    * Powerful new Worst-Case Analysis
    * Significantly enhanced schematic capture, including industry-leading bus support
    * Full support for hierarchical designs
    * Comprehensive circuit-annotation capabilities
    http://rapidshare.de/files/26737032/ewb9.part1.rar.html
    http://rapidshare.de/files/26739397/ewb9.part2.rar.html
    http://rapidshare.de/files/26801466/ewb9.part5.rar.html
    http://rapidshare.de/files/26802764/ewb9.part3.rar.html
    http://rapidshare.de/files/26803979/ewb9.part4.rar.html
    password: www.cmsz.org
    أهل الحديث
    Received: 206
    Given: 261
    CadSoft Eagle v4.16
    http://rapidshare.de/files/23497138/EA.rar
    pass: asdfghjkl1
    ftp://85.10.203.38/eagle/program/4.1...n-eng-4.16.zip
    الكراك :
    http://www.crackserver.com/0day_crac...AGLE.v4.16.htm
    اقرأ المزيد عن البرنامج بالمرفقات :)
    أهل الحديث
    Received: 206
    Given: 261
    ان احتجت كتب بالمجال اخبرنى
    ماجد عباس محمد
    Received: 152
    بالمناسبة EWB ليس هو الوحيد هناك Circuit Maker وغيرة
    من قيود EWB أنه يستخدم أجهزة مماثلة للأجهزة الفعلية مثلا أوسيلوسكوب و يجب أن توصله كما توصل الجهاز الحقيقى ثم يقيدك برسمين لأن الجهاز الحقيقى Dual Channel وعند التغيير يجب أن تعيد التوصيل ثم تقييم الدائرة مرة أخرى الذى قد يستغرق وقت فى الدوائر الكبيرة
    Circuit Maker يضع علامه بحرف T حيث تريد أن تستخدم اوسيلوسكوب وبعد أن يتم حساب الدائرة يمكنك إضافة أى عدد من الرسوم فورا دون تأخير أو إعادة توصيل أو إضاعة وقت ويمكنك نقل نقطة المرجع (ارضى) لأى نقطة لرسم القيم النسبية كعلاقة الخرج بالدخل ولكن الدعاية الأنجح هى التى تسوق المنتج الأقل وتخفى عيوبه وتظهر حسناته
    TariqFarrah
    TariqFarrah غير متواجد حالياً
    Thanks Man
