عطل في جهاز الاشعه السينيه xry
صفحة 2 من 2 الأولىالأولى 1 2
النتائج 11 إلى 17 من 17
    فؤاد ابو زيد
    فؤاد ابو زيد غير متواجد حالياً
    الاخ ابا ايه المحترم
    ما ذكرته صحيح واضيف سبب اخر هو عدم جهوزية اقسام اخرى في الجهاز ذات علاقه باكتمال دائرة التشغيل, عدم الجهوزيه هذا ناتج عطل ما في قطعة غيار او ارتفاع حرارة التيوب او اسباب اخرى الاجهزه الحديثه تدلك عليها من نفسها
    fomari6
    fomari6 غير متواجد حالياً
    Dear all
    Jazak Al ahal Kher.Indeed ,when the tempreture of the tube reaches a specific limit there is many protection for that .
    For all ,always when there is a problem try to think about the simplest one ,like defictive bottom,or cabels,or electronic components.But the last think is x-ray tube .Because before the shipment ,it is tested in the factory(Sure I am talking a bout Giants in the markets like Shimadzu,Siemens,Philips,GE,Varian,and Toshiba).For your information the cost of x-ray tube for general radiography is around 5000 Dollar approximatelly.All what I said depends on the equipment,manufaturer,country of origin,working hours,...
    wllelah Alhamed wal shuker
    عامر
    عامر غير متواجد حالياً
    ارجو اجابتي عن جهاز اشعه نوع كوري المنشأ تكون الاشعه فيه غير واضحه الا اذا استخدمنا دبل اكسبوجر مالسبب في ذلك ارجو الاجابه مع التقدير
    fomari6
    Dear Mr.Amer,
    Actually it depend on the equipment itself .It is very difficult to maintain an x-ray equipment through website or emails ,but I do as the other sevice center do if there is a problem in other country .
    There are many reasons :
    Firstly you should strat from the basics
    1. You should sheck the amount of rays coming out from the tube by KV meter
    1. if it is OK,use other filmes from another clinic or origin.
    2. if it is the same ,so check the developers and fixers in the x-ray film processor.
    3. I do not know the tube itself if there is small and large filement or not .mabye the tube is dying !
    4. What do you mean by double exposure. Try to see that the filement is lument when you press the first step.
    The all last steps as I said just simple but impotant and depend of the device itself but I recommend to read the manual (first operation and then the service one ,and contact the
    Company who is in charge of that if they can give you a hand in this .
    Indeed ,the x-ray equipment have so far different way to maintane than other equipment in the medical field .
    Wlleh alhamd welshuker
    ابو ايه
    ابو ايه غير متواجد حالياً
    الصورة الرمزية ابو ايه
    Given: 12
    ابو محمد المحترم
    انته لازم اتوضح انك انطيت كبسة التسخين حتى ايصير الجواب شافي / بس عموما العطل هوه التيوب يكمن شحنه وهذا ايفض بوجبة عشاء او غداء (دسمه ) اخوك ابو ايه
    م عامر الرحبي
    م عامر الرحبي غير متواجد حالياً
    الاخ ابو ايه المحترم
    شكرا لك على تو ضيحاتك لكن مااود ذكره ان الجهاز جديد فهل من الممكن ان التيوب يحتاج الى شحن ام الى عشاء ارجو توضيح ذلك اما عن الوجبه فانت ومن معك على الرحب والسعه في اي لحظه حتى ولو في المانيا عند السفر انشاء الله وشكرا لك على الاجابه 0
    ابو ايه
    Given: 12
    استاذ عامر المحترم
    يوجد ربط قوي بين التيوب والعشاء لان العشاء لا يؤكل الى بعد ان يسخن وانبوبة الاشعه (التيوب ) لا تصور الا بعد التسخين اذن التسخين وارد في الحالتين ومع ذالك انا ممتن لك لكرمك لانكم اهل للكرم
    وانا اشكر لك جهودك وانشاء الله نلتقي في بلد اخر وليس بالضروره المانيا ولك مني فائق الامتنان والتقدير $$$$$$$
