ملتقى الإتصالات
صفحة 2 من 9 الأولىالأولى 1 23 4 5 6 ... الأخيرةالأخيرة
النتائج 11 إلى 20 من 82
    هبة محمود
    هبة محمود غير متواجد حالياً
    Amplitude modulation (AM) is a technique used in electronic communication, most commonly for transmitting audio signals. It works by varying the strength of the transmitted signal in relation to the information being sent, for example, changes in the signal strength can be used to reflect sounds being reproduced. (Contrast this with frequency modulation, in which the transmitting frequency is varied; and phase modulation, in which the phase is varied.)
    Frequency modulation (FM) is a form of modulation which represents information as variations in the instantaneous frequency of a carrier wave. (Contrast this with amplitude modulation, in which the amplitude of the carrier is varied while its frequency remains constant.) In analog applications, the carrier frequency is varied in direct proportion to changes in the amplitude of an input signal. Digital data can be represented by shifting the carrier frequency among a set of discrete values, a technique known as frequency-shift keying.
    FM is commonly used at VHF radio frequencies for high-fidelity broadcasts of music and speech (see FM broadcasting). Normal (analog) TV sound is also broadcast using FM. A narrowband form is used for voice communications in commercial and amateur radio settings. The type of FM used in broadcast is generally called wide-FM, or W-FM. In two-way radio, narrowband narrow-fm (N-FM) is used to conserve bandwidth. In addition, it is used to send signals into space.
    FM is also used at intermediate frequencies by most analog VCR systems, including VHS, to record the luminance (black and white) portion of the video signal. FM is the only feasible method of recording video to and retrieving video from magnetic tape without extreme distortion, as video signals have a very large range of frequency components — from a few hertz to several megahertz, too wide for equalisers to work with due to electronic noise below -60 dB. FM also keeps the tape at saturation level, and therefore acts as a form of noise reduction, and a simple limiter can mask variations in the playback output, and the FM capture effect removes print-through and pre-echo. A continuous pilot-tone, if added to the signal — as was done on V2000 and many Hi-band formats — can keep mechanical jitter under control and assist timebase
    هبة محمود
    كنت أريد لو سمحتم لي أن أسأل عن حسنات وسيئات كل من
    analog and digital modulation
    ولكم جزيل الشكر
    eng_hazem123
    eng_hazem123 غير متواجد حالياً
    الصورة الرمزية eng_hazem123
    شكرا أخى ماجد على الافادة الطيبة وجزاك الله خيرا ، ولكن عندى استفسار أخير وهو لماذا بعض الهواتف الارضية تقوم بالتقاط بعض الاذاعات مما يشوش على عملية الاتصال؟وهل يمكن معالجتها؟ /هل يمكن عمل أى جهاز لاسلكى بحيث لا يشوش أو يلتقطه جهاز آخر؟وشكراوشكراوشكرا
    ماجد عباس محمد
    Received: 151
    Smile
    اقتباس المشاركة الأصلية كتبت بواسطة هبة محمود مشاهدة المشاركة
    ولكم جزيل الشكر
    اختى هبة ، هذا ما تمكنت من الحصول علية حتى الأن
    Analog modulation
    advantages and disadvantages are those of particular method used
    If you like I can post a comparison between AM and FM modulation as an example
    Digital modulation
    advantages
    Suitable for digital data transmission
    If digital data is transmitted, security protocols can be performed to prevent spying and monitoring
    Scrambling with complex keys to avoid unwanted signal decoding (sending classified info over internet)
    More data can be sent over the same line unlike analog methods.( modem speed of 56K bps over a limited bandwidth telephone line of 4 kHz)
    Using compression techniques can be used to further sending more data
    Error check – correction can be utilized
    Audio digital modulation allow packet transmission so you can address several devices using the same frequency etc like in the case of cell phone
    Packets can be received out of sequence or even from multiple sources (such as different relaying stations) and still be assembled into the original message by the receiving station. Example large file e-mails or downloads
    Disadvantage is complex circuits
    هنا بعض الصفحات
    وهنا ملف يمكن انزالة
    أرجو أن تكون مفيدة
    وشكرا للمشاركة:)
    ماجد عباس محمد
    Received: 151
    Smile
    اقتباس المشاركة الأصلية كتبت بواسطة eng_hazem123 مشاهدة المشاركة
    أخى لماذا الأخير؟
    التليفونات الأرضية تعمل على خطوط ذات مقاومة نوعية Characteristic Impedance قدرها 400 أوم وهى غالبا لا تصلح لاستقبال أى إرسال لاسلكى و لكن عند حدوث أمر من اثنين يحدث الغير متوقع ، وهما
    1- أجهزة التليفون الإلكترونية الحديثة قد لا يراعى فى أحدها الحفاظ على نهاية الخط Termination مما يتسبب فى ظهور خط ذو معاوقة كبيرة تسمح بالتقاط الإذاعة القوية وبالتالى يتم التقويم (التوحيد) Detection عند أول مرحلة تحتوى خواص غير خطية Non Linear ويظهر الصوت
    2- وجود محطة إذاعة قريبة تفرض إرسالها على الأجهزة المحيطة ويتم الكشف كما سبق
    لاحظ أن هذا يحدث فقط مع إذاعات تعديل الاتساع AM وليس الترددى FM
    وفى انظار اى استفسارات اخرى:)
    eng_hazem123
    شكرا ، وعندى طلب أخى ماجد وهو عندما أقوم بعملFM transmitter أجد فى الدائرةغالبا مكثف متغيرسعته مثل10pf او 40pfاو60pf وهذه المكثفات غير موجودة بمحل بيع القطع الالكترونية.فماذا أفعل؟/ ويوجد ايضا ملفات ذات سعه مثل1uH أو1nH .كيف أقوم بعمل هذه الملفات؟وخاصة أنه لم يكن عندى جهاز لقياسها.
    ماجد عباس محمد
    Received: 151
    أخى لا أعلم أين تقيم ولكن هنا فى القاهرة تباع هذه المكثفات تحت اسم ترم أو ترمر Trim , Trimmer من استخدامها فى ضبط التردد ألدقيق
    إن لم تجد فعادة المكثف مصاحب لملف فى دائرة الرنين استخدم مكثف ثابت بقيمة متوسطة (مثلا 60 عادة يتغير من 10 الى 60 اختر 30-40 ) واستخدم ملف متغير
    أيضا يمكنك استخدام فاراكتور وهو دايود يعمل كمكثف متغير حتى 70 بف
    أما الملفات فعادة لا يمكن عملها بدون قياس لكن من الجداول يمكنك أن يحدد أين تبدأ وبع التجربة تستطيع أن تعدل عدد اللفات لتصل إلى المطلوب فقط تذكر أن نسبة التردد هى نسبة اللفات
    لو أرسلت لى الدائرة فقد أستطيع المساعدة أكثر حيث ما سبق ينطبق على 1 ميكرو هنرى لكن 0.1نانو غالبا سيكون ملف خانق حتى يمنع انتقال التردد أو التحميل على خرج ترانزيستور مثلا وهنا يكون المقصود كذا أو أكثر فيمكنك مثلا لف 10 لفات على قلب Ferrite أو حسب ما قد يذكر فى شرح الدوائر- وجرب - وبعلم وظيفته يمكنك أن تعلم هل تزيد أم تقلل عدد اللفات
    أحاول أن أقدم سلسلة عن تصميم الدوائر الإلكترونية فى موضوع
    محاولة للرد على كيفية تصميم الدوائر الإلكترونية
    ومثل هذه الأسئلة تساعدنى فى إضافة المواضيع التى تهم رواد المنتدى
    انوى إن شاء الله أن أقدم
    المقاومات واستخدام كل نوع
    المكثفات واستخدام كل نوع
    الملفات واستخدام كل نوع
    الموحدات واستخدام كل نوع
    الترانزستورات وبعض الدوائر البسيطة
    الدوائر المتكاملة عدة مقالات
    شكرا جزيلا وأرجو أن تتابع معى دائما وتقول لى رأيك عندما يتيسر
    eng_hazem123
    شكرا أخى؛ أنا أقيم بالاسكندرية ولم أجد سوى مكثف متغير واحد .هل يمكن أن استخدمه أم لا؟/وعندى سؤال آخر.هل بالضرورة أن يكون بداخل الملف قضيب من مادة معينة أم؟/وعندى استفسار آخر وهو أن هناك قانون للتحكم فى مدىارسالFM transmitter وهوE= √30pt ÷dولم استطيع الاستفاده منه وتطبيقه على الدوائر.أرجو الافاده/
    ماجد عباس محمد
    Received: 151
    أخى
    بالتأكيد يمكن لو كان فى النطاق المطلوب ، أما إذا كان بعيد يمكنك تعديل الملف حتى يتناسب طبقا لمعادلة الرنين والتى يمكن إختصارها إلى س × ل = ثابت أى بنفس النسبة التى ضرب بها الكثف يقسم عليها الملف والعكس
    المعادلة المذكورة يستفاذ بها فى من المدى المطلوب تحدد طاقة الإرسال ومنها تحدد كيف تصمم مرحة الخرج لتعطيك هذه القدرة
    أبو معاذ الفلسطيني
    أبو معاذ الفلسطيني غير متواجد حالياً
    وانا ايضا كذلك بل انني كنت افضل من قبل عمل منتدى للاتصالات
