كتب رائعة جدا
صفحة 3 من 7 الأولىالأولى 1 2 34 5 6 7 الأخيرةالأخيرة
النتائج 21 إلى 30 من 68
  1. [21]
    م.مجدي عليان
    م.مجدي عليان غير متواجد حالياً
    عضو تحرير المجلة
    الصورة الرمزية م.مجدي عليان
    Received: 24
    Practical Machinery Vibration Analysis and Predictive Maintenance, First Edition
    (Practical Professional)
    Author: Cornelius Scheffer, Paresh Girdhar,
    Publisher: Newnes
    Publication Date: 2004-09-09
    Number Of Pages: 272
    http://rapidshare.de/files/29909151...Maintenance.pdf
  2. [22]
    م.مجدي عليان
    عضو تحرير المجلة
    Received: 24
    Standard Handbook of Engineering Calculations
    Author: Tyler G. Hicks Tyler Hicks
    Publisher: McGraw-Hill Professional
    Publication Date: 2004-08-01
    Number Of Pages: 1200
    Complying with the latest environmental regulations Design code changes LEED design considerations HVAC procedures Mobile and in-the-field methods "A classic compendium of step-by-step calculations for solving the most frequently encountered engineering problems in many engineering disciplines." -;dianahacker.com 5000 Essential Calculations for Engineers Packed with new data and methods, this invaluable handbook provides professionals with more than 5000 direct and related calculation procedures for solving common engineering problems quickly and easily. Now thoroughly revised and updated, Standard Handbook of Engineering Calculations, Fourth Edition covers seven engineering disciplines: civil, architectural, mechanical, electrical, chemical and process plant, sanitary, and environmental. Written in the popular "cookbook" format, the handbook describes each problem to be solved; provides numbered calculation procedures to be followed; works out an actual problem; and presents related calculations in most instances. This fourth edition features numerous new topics from design code changes in civil engineering to composite usage in engineering design. Inside, you'll find new problem-solving coverage of: Anti-terrorism structural building changes Power-plant cost-cutting Efficient compliance with environmental regulations Wind energy systems LEED considerations in building design Developments in pumps and related calculations Freon-replacing refrigerants Computer programs that automate repetitive calculations Finite element analytic methods The fourth edition of Standard Handbook of Engineering Calculations is a reference engineers will thank for answers time after time
    Open this book for all the calculations you need in
    *Civil Engineering
    * Architectural Engineering
    * Mechanical Engineering
    * Electrical Engineering
    * Chemical and Process Plant Engineering
    * Sanitary Engineering
    * Environmental Engineering
    http://z11.zupload.com/download.php...&filepath=39452
  3. [23]
    م.مجدي عليان
    عضو تحرير المجلة
    Received: 24
    Text offers an introduction to turbomachinery for senior undergraduate and beginning graduate students in mechanical, aerospace, chemical, design, and manufacturing engineering. Includes chapter problems. Useful as a reference to practicing engineers in the fields of propulsion and turbomachinery
    http://www.mytempdir.com/397676
  4. [24]
    م.مجدي عليان
    عضو تحرير المجلة
    Received: 24
    The Diesel Engine Reference Book
    Author: Bernard Challen
    Publisher: Butterworth-Heinemann
    Publication Date: 1999-05
    Number Of Pages: 682
    Chapter 1 The theory of compression ignition engines Chapter 2 The theory of turbocharging Chapter 3 Compound and other engine systems Chapter 4 Diesel combustion and fuels Chapter 5 Thermal loading Chapter 6 Thermodynamic mathematical modelling Chapter 7 Computational fluid dynamics Chapter 8 Modern control in diesel engine management Chapter 9 Inlet and exhaust systems Chapter 11 Fuel injection systems Chapter 12 Lubrication and lubricating oils Chapter 13 Bearings and bearing metals Chapter 14 Pistons, rings and liners Chapter 15 Auxiliaries Governors and Governor Gear Starting Gear and Starting Aids Heat Exchangers Chapter 16 Aircooled engines Chapter 17 Crankcase explosions Chapter 18 Exhaust smoke, measurement and regulation Chapter 19 Exhaust emissions Chapter 20 Engine noise Chapter 21 Larger engine noise and vibration control Chapter 22 Passenger car engines Chapter 23 Trucks and buses Chapter 24 Locomotives Chapter 25 Dual fuel engines Chapter 26 Marine engine applications Chapter 27 Condition monitoring
    http://rapidshare.de/files/4562650/....part1.rar.html
    http://rapidshare.de/files/4563208/....part2.rar.html
    Password:rafcm
  5. [25]
    م.مجدي عليان
    عضو تحرير المجلة
    Received: 24
    Computational Methods for Fluid Dynamics
    Author: Joel H. Ferziger
    Publisher: Springer
    Publication Date: 2001-12-12
    Number Of Pages: 423
    In this 3rd revised and extended edition the book offers an overview of the techniques used to solve problems in fluid mechanics on computers and describes in detail those most often used in practice. Included are advanced methods in computational fluid dynamics, like direct and large-eddy simulation of turbulence, multigrid methods, parallel computing, moving grids, structured, block-structured and unstructured boundary-fitted grids, free surface flows. The 3rd edition contains a new section dealing with grid quality and an extended description of discretization methods. The book shows common roots and basic principles for many different methods. The book also contains a great deal of practical advice for code developers and users; it is designed to be equally useful to beginners and experts.The issues of numerical accuracy, estimation and reduction of numerical errors are dealt with in detail, with many examples
    http://tinyurl.com/8ayl9
  6. [26]
    م.مجدي عليان
    عضو تحرير المجلة
    Received: 24
    An Introduction to Computational Fluid Dynamics
    The Finite Volume Method Approach
    Author: H. Versteeg W. Malalasekra
    Publisher: Prentice Hall
    Publication Date: 1996-02-13
    This book presents some of the fundamentals of computational fluid dynamics for the novice. It provides a thorough yet user-friendly introduction to the governing equations and boundary conditions of viscous fluid flows, turbulence and its modelling and the finite volume method of solving flow patters on a computer
    http://rapidshare.de/files/14183512...d_dynamics.djvu
  7. [27]
    م.مجدي عليان
    عضو تحرير المجلة
    Received: 24
    Process Engineering Equipment Handbook
    The first practical guide for process engineers, covering nearly every type of process-related equipment, Process Engineering Equipment Handbook is the fastest way to master process environments. This hands-on reference helps you-- *Understand and specify all types of auxiliary process equipment and materials. *Provide engineering and operating expertise on machinery that is of prime importance in process engineering, including compressors and pumps, gas and steam turbines, fans, blowers and motors-;both as individual components and as part of a supplied total package. *Explore various applications, such as mechanical drive and direct drive (power generation service) for gas turbines, major support systems including instrumentation, and key components such as bearings and seals, all with reference to practical applications. *Troubleshoot and solve problems in unfamiliar machines and components *Work effectively with control, environmental, mechanical, civil, and other technical specialists. *Handle issues with filters, seals, fans, dryers, nozzles, gaskets, elements made of unusual materials, blowers, connectors, gas and steam turbines, conveyors, feeders, joints, mills, controls, and many other categories of process equipment. *Gain valuable insight into the topics of vibration analysis and life-cycle assessment. *Perform major and minor audits of existing plants and machinery trains. The best source of on-the-job guidance for process engineers, Process Engineering Equipment Handbook provides the answers you seek, in quick-access alphabetical order.
    Product Details
    * Hardcover: 1008 pages
    * Publisher: McGraw-Hill Professional; 1 edition (December 26, 2001)
    * Language: English
    * ISBN: 007059614X
    * Size : 40 MB
    * Format : pdf
    http://rapidshare.de/files/25253906....part1.rar.html
    http://rapidshare.de/files/25255930....part2.rar.html
    http://rapidshare.de/files/25256051....part3.rar.html
  8. [28]
    م.مجدي عليان
    عضو تحرير المجلة
    Received: 24
    Elements of Gas Turbine Propulsion
    Author: Jack Mattingly
    Publisher: McGraw-Hill Science/Engineering/Math
    Publication Date: 1996-01-01
    Number Of Pages: 960
    Average Amazon Rating: 4.5
    This text provides an introduction to the fundamentals of gas turbine engines and jet propulsion for aerospace or mechanical engineers. The book contains sufficient material for two sequential courses i propulsion (advanced fluid dynamics) an introductory course in jet propulsion and a gas turbine engine components course. The text is divided into four parts introduction to aircraft propulsion; basic concepts and one-dimensional/gas dynamics; analysis and performance of air breathing propulsion
    http://rapidshare.de/files/22503702..._Propulsion.pdf
  9. [29]
    م.مجدي عليان
    عضو تحرير المجلة
    Received: 24
    Jet Engines: Fundamentals of Theory
    Design and Operation
    1997-12
    Author: Klaus Hunecke
    Publisher: Zenith Press
    Publication Date: 1997-12-21
    Number Of Pages: 256
    Broaden your knowledge of jet engine technology and its associated subjects. This is a technically comprehensive study of the components that constitute a gas turbine aero-engine and examines each part's design and function in practice. Concentrates on turbojet, turboprop and turbofan designs, and is applicable to civilian and military usage. Contains an overview of the main design types and fundamentals, and looks at air intakes, compressors, turbines and exhaust systems in great detail
    http://rapidshare.de/files/29006958..._FOTDO.rar.html
  10. [30]
    م.مجدي عليان
    عضو تحرير المجلة
    Received: 24
    Gas Turbine Engineering Handbook, 2nd Edition
    This important handbook comes to us from an experienced engineer at a most opportune time. Never has the cost of energy been greater, nor is there a promise that it has reached its price ceiling. Dr. Boyce is aware of these concerns, and through this handbook he has provided the guide and means for optimum use of each unit of energy supplied to a gas turbine. The handbook should find its place in all the reference libraries of those engineers and technicians who have even a small responsibility for design and operation of gas turbines
    http://rapidshare.de/files/7057666/...atriks.rar.html
    Password: Mat.Riks.Info
