types of valves (presentation with pictures)
صفحة 6 من 7 الأولىالأولى ... 2 3 4 5 67 الأخيرةالأخيرة
النتائج 51 إلى 60 من 65
  1. [51]
    فيصل العزو
    فيصل العزو غير متواجد حالياً
    شكرررررررررررررررررررررررررررررررررررأ جزيلاً
  2. [52]
    سامح صفى الدين
    سامح صفى الدين غير متواجد حالياً
    الصورة الرمزية سامح صفى الدين
    شكرا
    شكراشكرا
    شكراشكراشكرا
    شكراشكراشكراشكرا
    شكراشكراشكراشكراشكراشكراشكرا
    شكراشكراشكراشكرا
    شكراشكراشكرا
    شكراشكرا
    شكرا
  3. [53]
    الهندي30
    الهندي30 غير متواجد حالياً
    1Heat Exchangers:
    it's a device at which heat transfers between two fluids at different temperatures(cold fluid and hot fluid).
    2Applications of Heat Exchangers:
    1)Heating and Air-Conditioning Systems
    2) Power Plants
    3)Radiator in Cars
    4)Boilers
    5)Oil Coolers
    Heat transfers in Heat Exchangers by Convection through the fluid,, and by Conduction through the wall separating the two fluids.
    3Classifications of Heat Exchangers:
    Heat Exchangers may be classified according to:
    1) Flow Arrangement 2)Construction
    3.11)Classification according to Flow Arrangement:
    Three types of flow arrangements may be found in heat exchangers:
    1)Parallel Flow 2)Counter Flow 3)Cross Flow
    3.1.1)Parallel Flow:
    Both Hot and Cold fluids enter the heat exchanger at the same end and move in the same direction.
    3.1.2)Counter Flow:
    Hot and Cold fluid enter the heat exchanger at opposite directions.
    3.1.3)Cross Flow:
    The two fluids moves perpendicular to each others.
    3.21)Classification according to Construction:
    Four types of Construction may be found in heat exchangers:
    3.2.1)Tubular:
    In this type of heat exchanger the hot and cold fluids are separated by a wall and the heat is transfered by a combination of convection to and from the wall and conduction through the wall.
    the wall can include extended surfaces(fins)
    3.2.1.1 Double Pipe(concentric pipe)
    it's the simplest type of heat exchangers,, consists of two concentric pipes of different diameters
    one fluid in a double pipe heat exchanger flow through the smaller pipe while the other fluid flows through the annular space between the two pipes(parallel and counter flow are possible here)
    3.2.1.2 Shell and Tube
    a common type of heat exchanger that s widely used used in chemical processes,
    it contains a large number of tubes(several hundreds some times!!) which are packed in a shell with their axes parallel to that of the shell.
    heat transfer takes place as one fluid flows outside the tubes through the shell
    baffles are commonly placed in the shell to force the shell side fluid to flow across the shell to enhance heat transfer and to maintain uniform spacing between the tubes,
    baffles also provide turbulence which increases heat transfer between the fluids.
    3.2.2)Plate-Type
    it consists of a metal frame in which a variable number of corrugated metal sheets are clamped together
    adjoining plates are spaced apart and sealed against leakage and intermixing by a gasket
    the two fluids flow in a counterflow directions, and corrugations produce turbulence and an increase in the total surface area which increases heat transfer coefficient and effectiveness.
    3.2.3)Extended Surfaces:
    3.2.3.1 Plate fin
    3.2.3.2 Tube fin
    3.2.4)Regenerative:
    It depends on storing the thermal heat exists in the hot fluid in a porous material with high heat capacity,, then the cold fluid pass through this material to absorb this stored heat
    3.2.4.1 Rotary
    3.2.4.2 Fixed matrix
    Rotating hoods3.2.4.3
    Hope it was a usful topic...
    Ayman Hassan
  4. [54]
    حافظ عميته جارالله
    حافظ عميته جارالله غير متواجد حالياً
    شكرا جزيلا على هذا العرض المفيد والمهم
  5. [55]
    حافظ عميته جارالله
    كيف يمكننا احتساب كفاءة المراوح الهوائيه بالمعادلات
  6. [56]
    مهندس المحبة
    مهندس المحبة غير متواجد حالياً
    Received: 157
    عاشت الأيادي أخي العزيز الهندي30 على هذا المجهود المبارك وننتظر المزيد من مشاركاتك المميزة ........
  7. [57]
    eng.sanoo
    eng.sanoo غير متواجد حالياً
    thank
  8. [58]
    مهندس احمد هانى
    مهندس احمد هانى غير متواجد حالياً
    مشكوووووووووووووووووووووووووووووووووووووور
  9. [59]
    Mechaniky_Methanex
    Mechaniky_Methanex غير متواجد حالياً
    الصورة الرمزية Mechaniky_Methanex
    لك جزيل الشكر
  10. [60]
    احمد البدوي يعقوب
    احمد البدوي يعقوب غير متواجد حالياً
    مشكور يا باشمهندس ... جزاك الله عنا كل خير
