Autodesk Building Systems v2007
النتائج 1 إلى 10 من 11
    youcef_dz
    youcef_dz غير متواجد حالياً
    "We have saved a significant amount of time where design revisions are required. There have been several circumstances where we would have needed a day or two to make some design changes using our old drafting system. Using Autodesk Building Systems, we made those same changes in 15 minutes.”
    —Chris Shoemaker, Electrical Engineer
    Lizardos Engineering Associates, P.C.
    Connect it all—from conceptual design through construction documentation. Maximize the efficiency of your AutoCAD® software-based engineering workflow. Increase productivity, accuracy, and coordination with Autodesk® Building Systems—the AutoCAD-based building design and construction documentation software application for mechanical/electrical/plumbing (MEP) engineers, designers, and drafters.
    Productivity: Increase Efficiency by Reducing Tedious Drafting Tasks
    Reduce drafting time by working with tools designed specifically for MEP engineers, designers, and drafters. Adapt and easily customize Autodesk Building Systems to existing AutoCAD-based A&E (architectural and engineering) workflows and flexibly implement it where appropriate to improve the design process. Use enhanced single-line and double-line system design and layout productivity tools. Work in a familiar AutoCAD-based environment to easily implement new design tools at your own pace.
    Accuracy: Streamline the Design Process by Reducing Errors
    Move from design to documentation faster through the automated production of construction documents with discipline-specific AutoCAD-based tools. Increase the efficiency of the design development and construction documentation process with actual industry-based content. Reuse design data by linking into industry-leading analysis, cost estimation, and fabrication software applications.
    Coordination: Work Effectively with the Extended Design Team for Increased Coordination
    Minimize documentation coordination errors between mechanical, electrical, and plumbing engineering design teams as well as with architects and structural engineers within an AutoCAD-based A&E workflow. Reduce requests for information (RFIs) and costly design changes in the field by working with more accurate and consistent construction documents. Collaborate seamlessly by taking advantage of architectural base plans developed using AutoCAD-based software applications. Share work using the industry-leading DWG™ technology.
    http://rapidshare.de/files/30183714/....v2007-TBE.rar
    youcef_dz
    20 زيارة ة لا تعليق ?
    لا حول ة لا قوة إلا بالله.....
    عمروعلى3
    عمروعلى3 غير متواجد حالياً
    الصورة الرمزية عمروعلى3
    [FRAME="1 80"]
    احيانا يكون الصمت افضل من الكلام
    فأعتقد ان من يدعو لك بظهر الغيب افضل ممن يلصق كلمة شكرا او غيرها
    وعلى العموم فهذا حقك ان ترى تفاعل الاعضاء مع موضوعك وطرحك
    ولن ابالغ اذا قلت لك
    [/FRAME]
    أخوانى فى الله اعضاء الملتقى الكرام
    كنت قد انقطعت لفترة كبيرة عن التواصل معكم
    ووجدت رسائل على الخاص كثيره يطلب فيها راسليها المساعده
    لذلك اعتذر لكم جميعا عن عدم التواصل والرد عليها فى حينها
    كن صديق على الفيس بوك
    bolbol
    bolbol غير متواجد حالياً
    Given: 30
    أخى العزيز أولاً شكراً لمساهمتك ولكننى لا أعتقد أن هذه هى نسخة كملة لأننى نزلت النسخة 2006 منه وكان حجمه حوالى 2 جيجا
    eng.ekramy
    eng.ekramy غير متواجد حالياً
    مشكووووووووووووووووووووووووووووووووووووووور جدا
    ushamad
    ushamad غير متواجد حالياً
    شكرا على الجهد ولكن المساحة الفعلية للبرنامج2.7 جيجا
    أرجو الإفادة
    BerkaniSamir
    BerkaniSamir غير متواجد حالياً
    à Monsieur et frère Bolbol j'ai besoin de la version 2006 de 2 Go alors svp envoie moi liens pour la télécharger à : berkanisamir*yahoo.fr et merci frère
    ushamad
    جزاك الله خيرا على الرد ولكن أنا لا أفهم فرنساوي جيدا
    أرجو الترجمة
    ahmad_s
    ahmad_s غير متواجد حالياً
    Assalamo alaikom. i tried many times to link the site mentiond above but there is a message appears " files not found " please advise me.thanks a lot WA JAZEKA ALLAH KOL KHEIR.
    ushamad
    التورنت الجديد لـAutocad Building System 2007
    بعد جهد طويل
    أقدم لكم
