API Standard
صفحة 22 من 73 الأولىالأولى ... 1218 19 20 21 2223 24 25 26 3272 ... الأخيرةالأخيرة
النتائج 211 إلى 220 من 723
  1. [211]
    م.مجدي عليان
    م.مجدي عليان غير متواجد حالياً
    عضو تحرير المجلة
    الصورة الرمزية م.مجدي عليان
    Received: 24
    Best Regards
    Majdi N. Elyyan
  2. [212]
  3. [213]
  4. [214]
  5. [215]
    م.مجدي عليان
    عضو تحرير المجلة
    Received: 24
    الروابط جميعها منقولة للفائدة
    تحياتي
    مجدي عليان
    1 Not allowed!
    Best Regards
    Majdi N. Elyyan
  6. [216]
    م.مجدي عليان
    عضو تحرير المجلة
    Received: 24
    Wink API amirican petroleum institute
    API 06AM 2nd ed 09 95 Material Toughness
    API 006D Pipeline Valves
    API 510 8th Ed Incl Add3 Dec 2001 Pres Vessel Inspection Code
    API 526 flanged steel pressure Relief valves
    API 527 for seat tightness of pressure relife valves
    API 560 3rd Ed May 2001 Fired Heaters for general Refinery Services
    API 594 Check Valves 5th ed 1997
    API 598 7th ED Oct 1996 Valve Inspection and Testing
    API 610 8th Ed, Aug 1995 Cent Pumps
    API 611 4th Ed, Jun 1997 Steam Turb
    API 612 4th Ed, Jun 1995 Spec Purp Steam Turb
    API 613 4th Ed, Jun 1995 Spec Purp Gear Units
    API 614 4th Ed, Apr 1999 Lub, Shaft Seal, Control Oil Sys and aux
    API 616 4th Ed, Aus 1998 Gas Turbines
    API 617 6th Ed, Feb 1995 Centrifugal Compressors
    API 618 4th Ed, Jun 1995 Recip Compressors
    API 619 3rd Ed, Jun 1997 Pos Disp Compressor
    API 620 10th ed Feb 02 Design and Construction of Large Welded LP Storage Tanks
    API 650 Welded Tanks for Oil Storage 10th Ed Add1 Mar 2000
    API 653 3rd Ed Dec 01 Tank Insp Repair Alteration and Reconstruction
    API 660 Feb 2001 6th Ed Shell and Tube Heat Exchangers
    API 661 Nov 1997 4th ed Air Cooled Heat Exchangers
    API 670 4th Ed Dec 2000 Machinery Prot Sys
    API 530 4th ed Ocy 1996 Calc of Heater Tube Thickness
    API 671 3rd Ed Oct 1998 Spec Purp Couplings
    API 672 3rd Ed Sep 1996 Integ Geared Centrif Air Comp
    API 674 2nd Ed Jun 1995 Pos Disp Pumps
    API 675 2nd Ed Oct 1994 Pos Disp Pumps Controlled Vol
    API 677 2nd Ed Jul 1997 Gear Units
    API 681 1st Ed Feb 1996 Liq Ring Vac Pumps and Compressors
    API 682 1st Ed Oct 1994 Shaft Sealing Sys for Cent and Rotary Pumps
    API 683 1st Ed Sep 1993 Quality Improvement Manual for Mech Equipment
    API 2510 8th Ed May 2001 Design and Construction od LPG Facilities
    API 2510a 2nd Ed May 2001 Fire Protection of LPG FacilitiesAPI
    API PUB 534 1st Ed Jan 95 Heat Recovery Steam Generators
    API PUB 684 1st Ed Feb 1996 Rotoro Dynamics and Balancing
    API PUB 760 2nd Ed Jun 1998 Model Risk Management Plan
    API Pub 938 May 1996 1 1 4 Cr 1 2 Mo Crack Repairs
    API Pub 959 May 1982 Temper Embrittlement of Cr Mo Steels
    API RP 500 2nd Ed 1997 Area Classification
    API RP 505 1st Ed 1997 Area Classification
    API RP 521 4th Ed Mar 97 Guide for Pres Rel and Depres Sys
    API RP 540 4th Ed Apr 99 Electrical Inst
    API RP 572 Management of Hazards Associated with Location of Process PLants and Buildings
    API RP 573 1st Ed Oct 91 Inspection of Fired Boilers and Heaters
    API RP 574 2nd Ed Jun 98 Inspection Practices for Piping System Components
    API RP 576 2nd Ed Dec 00 Inspection of Pressure Relieving devices
    API RP 579 1st Ed Mar 00 Fitness for Service
    API RP 686 1st Ed Apr 1996 Machinery Inst Guide
    API RP 934 1st Ed Dec 2000
    API RP 945 2nd Ed Oct 97 Avoiding Environment Cracking In Amine Units
    API RP 1104 19tht Ed Oct 01 Welding of pipelines and related facilities
    API RP 2028 3rd Ed Feb 02 Flame Arrestors in Piping Systems
    API 579 1st Ed Revised Mar 2000 Fitness for service 1 - 100
    API RP 2350 2nd Ed 1996 Overfill Prot For Storage Tanks
    1 Not allowed!
    Best Regards
    Majdi N. Elyyan
  7. [217]
    Slim7
    Slim7 غير متواجد حالياً
    Thank you very much. please
    I WANT API 421
    oil watter separator
    1 Not allowed!
  8. [218]
    رضا وهبه
    رضا وهبه غير متواجد حالياً
    الصورة الرمزية رضا وهبه
    بعد التحيه
    الله يكرمك ممكن المساعده من فضلك
    انا عارف ان الحمل عليك كتير
    ربنا يكون في عونك
    محتاج هزه المواصفه من فضلك
    V13A: Drilling FluidsSpec 13A Drilling Fluid MaterialsRP 13B-1 Standard Procedure for Field Testing Water-Based Drilling FluidsRP 13B-2 Standard Procedure for Field Testing Oil-Based Drilling FluidsRP 13B-2-A1 Addendum 1 to Standard Procedure for Field Testing Oil-based Drilling FluidsRP 13D Rheology and Hydraulics of Oil-well Drilling FluidsRP 13I Standard Procedure for Laboratory Testing Drilling FluidsRP 13L Recommended Practice for Training and Qualification of Drilling Fluid TechnologistsRP 13K Chemical Analysis of Barite V13C: Drilling Fluid Processing SystemsRP 13C Drilling Fluid Processing Systems Evaluation V13J: Testing of Heavy BrinesRP 13J Testing of Heavy Brines V13M: Completion & Facturing FluidsRP 13M Measuring the Viscous Properties of Cross-linked Water-Based Fracturing Fluid
    الله يكرمك أهتم بطلبي
    جزاك الله خيرا
    أخوك رضا وهبه
    1 Not allowed!
  9. [219]
    لاخعلاه
    لاخعلاه غير متواجد حالياً
    هل من الممكن الحصول على Api 1156
    مشكور مقدما
    1 Not allowed!
  10. [220]
    azerty2007
    azerty2007 غير متواجد حالياً
    thanks for all
    1 Not allowed!
