برنامجhspice 2006.03-sp1..
النتائج 1 إلى 4 من 4
    مفاعل_نووي
    مفاعل_نووي غير متواجد حالياً
    زائر
    السلام عليكم،
    صيد اليوم برنامجHSPICE 2006.03-SP1
    The golden standard for Accurate Circuit Simulation
    للمهندسين و المحترفين و التقنيين..:
    HSPICE is the industry’s “gold standard” for accurate circuit simulation and
    offers foundry certified MOS device models with state-of-the-art simulation and
    analysis algorithms. With over 20+ years of successful design taped
    outs, HSPICE is the industry’s most trusted and comprehensive circuit
    simulator. HSPICE is an integral component of Synopsys high-performance
    mixed-signal verification solution, Discovery AMS, which enables designers to
    achieve the highest throughput and accuracy for even the largest mixed-signal SoC’s.
    Design Challenges
    As IC geometries continue to shrink, the need for an accurate circuit simulator is
    critical. Designers require a highly accurate circuit simulator to precisely predict
    the timing, power consumption, and functionality of their designs.
    Solution
    HSPICE provides the industry's most trusted and comprehensive circuit simulator
    engine and device models. HSPICE's simulator engine has been successfully used to
    design over one-million integrated circuits. Its advanced circuit simulation algorithms
    provide HSPICE with convergence characteristics that are superior to other tools.
    Key Benefits
    * Gold standard for accurate circuit simulation.
    * Extensive model support of the most accurate and expansive set
    of industry-standard and proprietary simulation models.
    * Performance
    o Significant speed up for cell characterization applications, large
    extracted netlists and 65 nm designs.
    * Design for Yield - Simulating Variability
    o Variation Block - powerful and flexible mechanism for defining process variation effects
    o DCMatch - efficient statistical simulation for local parameter mismatch effects
    o Monte Carlo - all purpose statistical simulation
    * Signal Integrity Analysis
    o Enhanced W – Elements and S – Parameters to model signal integrity issues and support SI Analysis.
    * RF and High Speed Digital Simulation
    o Best RF Simulator for PLL & VCO applications
    o Accurate RF Simulation
    + Run state-of-the-art linear, noise, and large-signal steady-state RF simulation.
    + Use the same foundry approved IC device models for analog, RF, and mixed-signal simulations.
    o High Capacity & High Performance RF Simulation
    + New harmonic balance engine can simulate 10,000 or more active elements quickly.
    o Characterize RF Designs
    + Built in features to help fully characterize analog and RF circuit-transfer functions, noise
    properties, spectral responses, distortion, and parasitic effects.
    o RFIC Applications
    + A comprehensive set of analysis algorithms helps you design most RFIC blocks: low noise
    amplifiers, power amplifiers, filters, AGC circuits, oscillators, mixers, multipliers, modulators, demodulators, and VCOs.
    * Industry standard formats and Integration
    o Comprehensive support for industry-standard formats eases adoption and integration issues.
    * Discovery AMS Simulation Interface
    o Simulation environment and netlister that supports ALL HSPICE analysis and options
    o Direct integration with Cadence Composer
    o Tightly integrated with CosmosScope
    لتنزيل البرنامج :49 Mb
    http://************************/forumdisplay.php?f=35
    للمزيد من المعلومات:
    http://www.synopsys.com/
    تم تحرير الرابط بواسطة المشرف Mu7ammad
    roboman
    roboman غير متواجد حالياً
    thank you very much. but how to get rid of the licence manager window asking for the licence file?
    مفاعل_نووي
    زائر
    please we write in arabic and answer in arabic!!!...
    Mu7ammad
    Mu7ammad غير متواجد حالياً
    Received: 8
    تم غلــق الموضوع
    ... دعائية للاعلان عن موقع شخصى ...
    مع الشكر والتقدير
    والله ولى التوفيق
    .... فهــــــــــــرس ملتقــــــــــى البرامـــــــــج ....
    ... اعتــــــذر عن عدم التواجد ...
    ... العين تقراء السطور ... والعقل يقراء ما بين السطور ...
