برنامج Risa 3d_v6.0
النتائج 1 إلى 2 من 2
    مفاعل_نووي
    مفاعل_نووي غير متواجد حالياً
    زائر
    برنامج Risa 3d_v6.0
    السلام عليكم، :)
    برنامج RISA 3D_V6.0:
    RISA-3D - Easy 3D Structural Engineering Analysis & Design Software for general frame, truss, and plate/shell structures. Concrete Designs with Rock Solid Results
    RISA-3D is so popular among structural engineers for one simple reason: ease of use. We designed our flagship product with the daily use of structural engineers in mind. User friendliness is what makes RISA-3D such a powerful tool for analysis, design and optimization of all types of structures and all common structural materials. RISA-3D is a tool that no structural engineer should be without.
    Powerful Integration with the RISA Building System:
    RISA-3D’s full integration within the RISA Building System enables you to manage all aspects of your project within the same environment.
    Quality & Support:
    Optimized for Windows 95/98/2000/NT/ME/XP
    Extensive customization options & user defaults
    Comprehensive printed reference manual & tutorials
    Encyclopedic online help with index and cross-reference
    Instant online program updates via WebUpdate
    60-day unconditional trial period
    State-of-the-Art Modeling:
    Comprehensive graphic editing capabilities that let you draw, modify and load elements as well as snap, move, rotate, copy, mirror, scale, split, merge, sub-mesh, delete, apply, etc.
    Versatile drawing grids (orthogonal, radial and skewed)
    Universal snaps and object snaps allow drawing without grids
    Powerful graphic selection tools including box, line, polygon, invert, property criteria and locking or select from sorted spreadsheet data
    Saved selections to quickly recall desired selections
    Modification tools that modify single items or entire selections
    Real spreadsheets with cut, paste, fill, math, sort, find, etc
    Dynamic synchronization between spreadsheets and views so you can edit or view any data in the plotted views or in the spreadsheets
    Simultaneous view of multiple spreadsheets
    Constant in-stream error checking and data validation
    Unlimited undo/redo capability
    Generation templates for grids, disks, cylinders, cones, arcs, trusses, tanks, hydrostatic loads, etc.
    Automatic data backup
    Support for all units systems & conversions at any time
    Read RISA-2D and STAAD files
    Automatic interaction with RISASection libraries
    Import DXF, RISA-2D, STAAD and ProSteel 3D files
    Export DXF, SDNF and ProSteel 3D files
    لتنزيل البرنامج مجانا :47Mb
    انقر هنا باسم الله..<<
    تم تحرير الرابط بواسطة المشرف Mu7ammad
    Mu7ammad
    Mu7ammad غير متواجد حالياً
    Received: 8
    تم غلــق الموضوع
    ... دعائية للاعلان عن موقع شخصى ...
    مع الشكر والتقدير
    والله ولى التوفيق
    .... فهــــــــــــرس ملتقــــــــــى البرامـــــــــج ....
    ... اعتــــــذر عن عدم التواجد ...
    ... العين تقراء السطور ... والعقل يقراء ما بين السطور ...
