صناعة المخلل
النتائج 1 إلى 8 من 8
    mahmoudxx
    mahmoudxx غير متواجد حالياً
    صناعة المخلل
    ياريت حدا يشرحلنا عن بنزوات الصوديوم كمادة حافظة
    E210 و كيف تستخدم في صناعة المخلل
    و اذا احد المهندسين بيشرحلنا عن صناعة المخلل او بيعطينا رابط عن صناعة المخلل بيكون وفا و زاد
    و تحياتي لزملائي في المنتدى
    shaher
    shaher غير متواجد حالياً
    أريد معرفة شاملة حول موضوع الدهانات وتركيباته
    ولكم جزيل الشكر
    عبدالله مناصرة
    عبدالله مناصرة غير متواجد حالياً
    الصورة الرمزية عبدالله مناصرة
    اعتقد هذا ربما يفيدك
    Item: Sodium Benzoate (E211)
    35% Water Soluble at 20°cSolubility
    99% Purity
    8,for 35% SolutionPH
    The phase:" Food Grade Preservative" Indicated on the Package
    Production and Expiry Dates(month, year)
    Enclosed Upon Receiving Certification of Analysis
    chopin
    chopin غير متواجد حالياً
    Sodium benzoate (E211), also called benzoate of soda, has chemical formula C6H5COONa. It is the sodium salt of benzoic acid and exists in this form when dissolved in water. It can be produced by reacting sodium hydroxide with benzoic acid.
    Uses
    As a food additive it is used as a preservative, effectively killing most yeasts, bacteria and fungi. Sodium benzoate is effective only in acidic conditions (pH < 3.6) making its use most prevalent in foods such as preserves, salad dressings (vinegar), carbonated drinks (carbon dioxide), jams (citric acid), fruit juices (citric acid), and chinese food sauces (soy, mustard, and duck). It is also found in alcohol-based mouthwash. More recently, sodium benzoate has become apparent in many soft drinks, including Sprite, Sunkist and Dr Pepper. It can be identified in soft drinks by 'sodium benzoate' or E211.
    It is found naturally in cranberries, prunes, greengage plums, cinnamon, ripe cloves, and apples. Concentration as a preservative is limited by the FDA in the U.S. to 0.1% by weight though organically grown cranberries and prunes can conceivably contain levels exceeding this limit. Some believe the limit is 0.1% because larger amounts are poisonous. However, the International Programme on Chemical Safety found no adverse effects in humans at doses of 647-825 mg/kg of body weight per day.[2-3]
    Cats have a significantly lower tolerance against benzoic acid and its salts than rats and mice.[4] Sodium Benzoate is however, allowed as an animal food additive at up to 0.1%, according to AFCO's official publication.
    Mechanism of food preservation
    The mechanism starts with the absorption of benzoic acid in to the cell. If the intra cellular pH changes to 5 or lower, the anaerobic fermentation of glucose through phosphofructokinase is decreased by 95%.
    Safety and health
    In combination with ascorbic acid (vitamin C, E300), sodium and potassium benzoate may form benzene, a known carcinogen. Heat, light and shelf life can affect the rate benzene is formed. The Food and Drug Administration (FDA) is currently (as of March 2006) performing tests, but the Environmental Working Group is calling for FDA to publicly release all tests and use their authority to force companies to reformulate to avoid the benzene forming combination
    Don’t Stop
    mahmoudxx
    مشكورين اخوة على هذا الشرح الوافي
    فتاة العلم
    فتاة العلم غير متواجد حالياً
    ابا اعرف عن أهمية الأسترات في الجالات الصناعية..................
    ياليت تراسلوني على الخاص..................
    mahmoudxx
    اشكرك يا فتاه العلم على اهتمامك في الموضوع
    و ارغب في مراسلتك و لكني لم استطع ان اصل الى ايميلك لهذا السبب ساضع ايميلي
    و ارجو مراسلتي
    و لدي الكثير من الاستفسارات و انا مهتم بالموضوع و بحثت عنه كثيرا
    Eng.Foam
    Eng.Foam غير متواجد حالياً
    شكرا جزيلاً
    شكراً جزيلا
