SolidCAM 2006 R10 SP9 for SolidWorks
النتائج 1 إلى 3 من 3
    yassine-maroc
    yassine-maroc غير متواجد حالياً
    Salamo alikom
    [BIMG]http://www.cadventureinc.com/images-cv/products/SolidCAM-1.jpg[/BIMG]
    [BIMG]http://www.solidworks.com/uploads/solutionpartner/screenshots/solidcam%20animated%20screenshot.gif[/BIMG]
    iNFO:
    SolidCAMreg; is an advanced computer-aided manufacturing tools. SolidWorks operating in the same environment, arising from the conversion of data files from the loss, delay time, computer-assisted processing, process more convenient.
    SolidCAM provides 2.5 axle Xianxiao, 3 axle Xianxiao, 3+2 multilateral processing, 5 axle gearing processing Juxiao +-driven tool 2/4 axle electric spark processing (2/4) axle electric spark processing (2/4 axis cut). SolidCAM system advantages include :
    · speed support any CNC machine controller.
    · camber or entity can not directly do 2D or 3D conversion processing setting.
    · pioneering processing model be kept valuable processing technologies and procedures, as required by the rapid changes can be processed graphics processing procedures.
    -- automatic detection units expected, automatic - Kok, 3D ridges along the side of automatic processing, secondary processing support.
    · processing setting, it can produce rapid calculation of NC procedures, cutlery can be automatically re-numbered.
    · provide 2D/3D cutlery trails simulation, CAD graphics simulation, materials simulation, simulation entity, mutilated materials show that within lathe / Waijing diverse simulation machines, and can demonstrate value calculation processing time.
    -- intelligent cruise processing law : no mention knives during processing can reduce the mention of the knife knife to the surface negative degrees.
    · support G2/G3 arc cutting : general machine tools can quickly smooth out the curved surface.
    -- can do it both vertical and horizontal shafts, within / Waijing, contours, Shencao, cut, carry noodles cutting shafts, cars teeth cutting, the process at one go, without stagnation period.
    · flexible NURBS camber, with entities for geometric computation, the camber can not automatically linked up into a single camber.
    · keep records of graphics, even sudden power can preserve ultimate design graphics.
    ONly one links
    من مواضيع yassine-maroc :
    التعديل الأخير تم بواسطة yassine-maroc ; 2006-07-13 الساعة 02:55 AM سبب آخر: dd
    [BIMG]http://img314.imageshack.us/img314/3098/mine7ko.png[/BIMG]
    maqsoud
    maqsoud غير متواجد حالياً
    merci mon ami yassin tres interessente sujet
    عمار باقر سالم
    عمار باقر سالم غير متواجد حالياً
    الصورة الرمزية عمار باقر سالم
    thanks
    thanks
    thanks
    thanks
    thanks
    thanks
    thanks
    thanks
    thanks
    thanks
    thanks
    thanks
    thanks
    thanks
    thanks
    thanks
