Fluent Softwares Cost 5000$
النتائج 1 إلى 10 من 46
    yassine-maroc
    yassine-maroc غير متواجد حالياً
    Salamo alikom
    Fluent (Fluent Computational Fluid Dynamics (CFD) Software) FloWizard 2.04
    [BIMG]http://www.fluent.com/software/flowizard/img/tabmixer0Combined_lg.jpg[/BIMG]
    [BIMG]http://www.fluent.com/software/flowizard/img/automobiel1_lg.jpg[/BIMG]
    FloWizard is a highly automated flow modeling tool that allows design and process engineers to rapidly and accurately validate their designs much earlier in the product development cycle. Using FloWizard to rapidly analyze your fluid flow and heat transfer problems throughout development can save you time, money and improve the performance of your designs. FloWizard's Windows look-and-feel user interface is designed for ease of use and high productivity and can be customized to meet your needs
    Fluent Gambit v2.3.16
    iNFO:
    GAMBIT is Fluent’s geometry and mesh generation software. GAMBIT's single interface for geometry creation and meshing brings together most of Fluent's preprocessing technologies in one environment. Advanced tools for journaling let you edit and conveniently replay model building sessions for parametric studies. GAMBIT's combination of CAD interoperability, geometry cleanup, decomposition and meshing tools results in one of the easiest, fastest, and most straightforward preprocessing paths from CAD to quality CFD meshes.
    As a state-of-the-art preprocessor for engineering analysis, GAMBIT has several geometry and meshing tools in a powerful, flexible, tightly-integrated, and easy-to use interface. GAMBIT can dramatically reduce preprocessing times for many applications. Most models can be built directly within GAMBIT's solid geometry modeler, or imported from any major CAD/CAE system. Using a virtual geometry overlay and advanced cleanup tools, imported geometries are quickly converted into suitable flow domains. A comprehensive set of highly automated and size function driven meshing tools ensures that the best mesh can be generated, whether structured, multiblock, unstructured, or hybrid. GAMBIT's range of CAD readers allow you to bring in any geometry, error free, into its meshing environment. GAMBIT also has an excellent boundary layer mesher for growing optimum grid cells off wall surfaces in your geometries for fluid flow simulation purposes.
    More Info:
    http://www.fluent.com/software/gambit/index.htm
    Fluent TGrid v4.0.16
    iNFO:
    TGrid is a specialized preprocessor used to create unstructured tetrahedral and HexCore meshes for complex and very large surface meshes. TGrid offers advanced prism layer creation tools which give greater mesh flexibility, particularly in the case of complicated shapes. TGrid is also equipped with an advanced wrapping procedure that produces a high quality, size function driven connected triangular surface mesh from a large set of unconnected faceted surfaces. TGrid's robust, automated algorithms save preprocessing time and generate high-quality meshes for CFD analysis in FLUENT.
    Surface and volume meshes may be imported into TGrid from GAMBIT, ANSYS, CATIA, I-DEAS, NASTRAN, PATRAN, Pro/ENGINEER, Hypermesh, and more. Extensive tools are included in TGrid for improving imported surface mesh quality and for rapidly assembling meshes from multiple parts..
    classical_man
    classical_man غير متواجد حالياً
    رااااااااااااااااااااااااااااائع
    classical_man
    سيدي العزيز ،،،
    الروابط التالية لا تعمل :
    http://enfull.com/download.asp?id=491&soft=enfull1
    http://www10.enfull.com/FLUENT_FLOWIZARD_V2.0.4-LND.zip
    مع خالص تحياتي وشكري
    yassine-maroc
    [BIMG]http://img314.imageshack.us/img314/3098/mine7ko.png[/BIMG]
    classical_man
    شكرااااااااااااااااااااااااااااااااااااااااااااااا اااااااااااااااااااااااااااااااااااااااااااااااااا ااااااا
    classical_man
    يا سيدي العزيز ،،،
    هل يمكنك احضار برنامج Fluent لأن الروابط التي وضعتها هي فروع لهذا البرنامج الرهيب.
    مع خااااااااااااااااااااالص شكري وامتناني لجهودك الجبااااااااااااااااارة
    classical_man
    بامكانك رؤية ذلك في موقعهم يا سيدي ،،،
    classical_man
    واني اشكرك وأقدر جهدك الرائع
    yassine-maroc
    سيدنا وسيدك هو رسول الله صلى الله عليه وسلم
    سأحاول أن أجده لك إن شاء الله
    yassine-maroc
    Fluent Gambit 2.3.16
    Fluent Polyflow 3.10.4
    Fluent FloWizard 2.1.8
    Fluent for CATIA v5 1.0.8
    Fluent MIXSIM v2.0.2
    Fluent FIDAP v8.7.4
    Catia Translator For Fluent Flowizard 2.0.4
    Fluent Airpak 2.1.12
    ·FLUENT V6.2
    ماهو البرنامج الدي تريده
