Autodesk Architectural Desktop 2007
النتائج 1 إلى 2 من 2
    yassine-maroc
    yassine-maroc غير متواجد حالياً
    Salamo alikom:
    Autodesk Architectural Desktop provides the best AutoCAD–based design and documentation productivity for architects. With its easy-to-use features and flexible implementation options, drafting and construction document production is easier, faster, and more accurate. Autodesk Architectural Desktop enables you to create your architectural documentation faster. The software also gives you more tools that automate tedious drafting tasks, making document coordination even easier.
    * A Better AutoCAD for Architects: Work in the familiar AutoCAD environment, using tools that are purpose-built for architectural drawing and design.
    * Immediate Productivity: Begin using Architectural Desktop with minimal training, creating documentation, drawings, and schedules faster and with fewer errors.
    * Flexibility in Implementation and Use: Architectural Desktop is compatible with your existing project management methods. Begin using it immediately and make a smooth transition to more advanced features at your own pace.
    * Smooth Collaboration: Exchange information easily using the industry-leading DWG file format, and use integrated rendering to create lifelike design visualizations that enhance communication with clients.
    Homepage:
    http://www.autodesk.com/archdesktop
    ahmedhamid
    ahmedhamid غير متواجد حالياً
    Received: 10
    اخى احتاج البرنامج جدا
    ربنا يكرمك ممكن تحط روابط شغالة ؟الروابط دى مش شغالة
