برنامج Electronics Workbench Design..
النتائج 1 إلى 4 من 4
    مفاعل_نووي
    مفاعل_نووي غير متواجد حالياً
    زائر
    السلام عليكم،
    صيد اليوم برنامج Electronics Workbench Design
    Suite V 9.0.155
    للمهندسين و المحترفين و التقنيين..:
    Multisim is a powerful simulation tool that includes a complete, fully
    integrated version of Multicap for design entry leading to simulation.
    Verify circuits and locate errors before they propagate further down the design flow
    and become costly mistakes. Investigate circuits using the industry’s only
    virtual instruments and "change-on-the-fly” interactive simulation. Gain true
    understanding of your circuit’s performance with a comprehensive suite
    of analyses. Multisim helps optimize designs and minimize time-to-market.
    ULTIBOARD — PCB LAYOUT
    Ultiboard combines power with ease of use to quickly get error-free boards to production.
    Ultiboard’s user interface is carefully designed so that the most critical repetitive
    tasks such as trace editing and component placement can be performed quickly, with
    minimum steps and fewer mouse clicks. In addition, Ultiboard boasts one of the
    industry’s only real-time systems so that all DRC, ratsnest, polygon, and force
    vector information is updated in real-time as you work, for instant feedback and greater efficiency
    ULTIROUTE — AUTOROUTING
    Ultiroute is the only autorouting program to employ “Progressive Routing” — breakthrough
    technology that combines grid and gridless (shape-based)routing techniques into
    a single engine. Get better board layouts with higher completion, shorter
    trace lengths, and fewer vias through gridless routing, while
    most traces are still placed on the grid for easy editing.
    السعر = يتراوح بين $1350 - $9760 دولار
    لتحميل البرنامج :
    http://*********************/dz/forumdisplay.php?f=35
    تم تحرير الرابط بواسطة المشرف Mu7ammad
    mtm*
    mtm* غير متواجد حالياً
    شكرًا أخى على هذا البرنامج الطيب
    ولكن أريد نفس البرنامج الأصدار الخامسv5.0
    وشكرًا000كثيرًا
    abu mohamed
    abu mohamed غير متواجد حالياً
    اخى ممكن الوصله مره اخرى لو سمحت
    Mu7ammad
    Mu7ammad غير متواجد حالياً
    Received: 8
    تم غلــق الموضوع
    ... دعائية للاعلان عن موقع شخصى ...
    مع الشكر والتقدير
    والله ولى التوفيق
    .... فهــــــــــــرس ملتقــــــــــى البرامـــــــــج ....
    ... اعتــــــذر عن عدم التواجد ...
    ... العين تقراء السطور ... والعقل يقراء ما بين السطور ...
