بحث عن كتاب HVAC Maintenance and Operations
النتائج 1 إلى 2 من 2
    عثمان الإرتري
    عثمان الإرتري غير متواجد حالياً
    أبحث عن كتاب مهم جدا وهو:HVAC Maintenance and Operations Handbook
    وهو للمؤلف Robert C. Rosaler
    أرجو من يجده أن يخبرنا بكيفية الحصول عليه و ذلك لأهميته للمبتدئين.
    شكرا للباحثون
    عثمان
    نبذة عن الكتاب:
    Keep your HVAC system running in peak condition—and avoid costly breakdowns and inefficiencies. Just turn to this first comprehensive guide to the proper maintenance, operations, and performance of heating, ventilating, and air conditioning (HVAC) systems and related components. Written by a team of leading HVAC pros, the handbook provides everything you need to effectively operate and maintain heating equipment...distribution equipment...cooling systems...pumps...valves...and boilers. It also provides proper procedures for indoor air quality (IAQ) control and system commissioning.
    Keep your HVAC system running in peak condition--and avoid costly breakdowns and inefficiencies. You'll find clear, accurate answers to all your HVAC questions in this comprehensive guide to the proper maintenance, operations, and performance of heating, ventilating, and air conditioning (HVAC) systems and related components. Written by a team of leading HVAC professionals, this handbook provides everything you need to effectively operate and maintain heating equipment. . .distribution equipment. . .cooling systems. . .pumps. . .valves. . .boilers. . .and control equipment. Packed with performance characteristics, calculations, and hundreds of detailed illustrations, this reference will help you: properly install all HVAC equipment; properly conduct the commissioning process; apply modern maintenance management techniques; learn the economics of repair vs. replacement; apply effective IAQ (indoor air quality) control; apply effective condensate control; ensure the reliability and efficiency of HVAC systems. This practical book will also give you the savvy to accurately measure system performance. . .utilize the right maintenance equipment and tools. . .and train your employees in proven HVAC procedures.
    سفيان34
    سفيان34 غير متواجد حالياً
    ممكن تفصيل بالفرنسية عن هدا الكتاب
    السلام عليكم و رحمة الله
