الطلمبات الطاردة المركزية
صفحة 2 من 2 الأولىالأولى 1 2
النتائج 11 إلى 14 من 14
    amrhawash
    amrhawash غير متواجد حالياً
    الصورة الرمزية amrhawash
    Received: 9
    Given: 3
    مشكوووووووووووووووووووووووووووووووووووور جدا جدا ياهندسه
    kindheart186
    kindheart186 غير متواجد حالياً
    A centrifugal pump is one of the simplest pieces of
    equipment. Its purpose is to convert energy of an electric
    motor or engine into velocity or kinetic energy and then into
    pressure of a fluid that is being pumped. The energy
    changes occur into two main parts of the pump, the impeller
    and the volute. The impeller is the rotating part that
    converts driver energy into the kinetic energy. The volute is
    the stationary part that converts the kinetic energy into
    pressure
    kindheart186
    Classification of centrifugal pumps:
    Centrifugal Pumps can be classified based on the manner of which fluid flows
    through the pump. The manner in which fluid flows through the pump is
    determined by the design of the pump casing & the impeller. Centrifugal pumps
    may be classified in several ways. For example, they may be either single-stage or
    multistage. A single-stage pump has only one impeller; a multistage pump has two
    or more impellers housed together in one casing. In a multistage pump, each
    impeller usually acts separately, discharging to the suction of the next stage
    impeller. Centrifugal pumps are also classified as horizontal or vertical, depending
    on the position of the pump shaft. Centrifugal Pumps are classified into three
    general categories:
    سعد العادلى
    سعد العادلى غير متواجد حالياً
    الصورة الرمزية سعد العادلى
    Given: 3
    شكراااااااااااااااااااااااا
    اكبر موقع باللغة العربية علية جميع كتب التبريد والتكييف بالعربية على الموضوع التالى الرابط
    مستنى ردكم
    اخوكم / سعد العادلى
