ALGOR Designcheck v19.1 SP1
النتائج 1 إلى 9 من 9
    yassine-maroc
    yassine-maroc غير متواجد حالياً
    [BIMG]http://img288.imageshack.us/img288/4568/socketl4yk.th.gif[/BIMG]
    With ALGOR DesignCheck finite element analysis (FEA) software, you can verify your single part designs with a first-pass engineering analysis to virtually test the behavior of product designs, speed up time to market and make better, safer products at a lower cost.
    Available directly from the Alibre Design Professional Tools menu as an Add-on, DesignCheck makes it easy to perform finite element modeling and analysis, evaluate results and prepare professional design reports.
    * Direct CAD/CAE data exchange with Alibre Design for single parts
    * Windows-native data input screens
    * Multiple view windows
    * Tree view of the model and associated data
    * Real-time data checking for reasonable input
    * Automatic 3D solid hybrid meshing (bricks on the model surface and tetrahedra inside) with a built-in aspect ratio check
    * Intelligent, automatic, feature-based mesh refinement tools and point-and-click definition of areas where a finer mesh is desired
    * Right-click application, modification and deletion of surface forces, surface constraints and FEA properties
    * Static stress analysis with linear material models
    * Analysis results displayed graphically for von Mises stress and deflected shape
    * Image output in the BMP, JPG, TIF, PNG, PCX and TGA formats
    * Animations through AVI creation and display tools
    * Automatic generation of professional text or HTML design reports
    Homepage:
    CODE
    http://www.algor.com
    Download:
    ALGOR.Designcheck.v19.1.SP1.MULTiLANGUAGE.ISO-TBE
    CODE
    http://rapidshare.de/files/20322183/ad191sp1.part1.rar
    http://rapidshare.de/files/20323787/ad191sp1.part2.rar
    La tansouna men salihi do3a
    من مواضيع yassine-maroc :
    التعديل الأخير تم بواسطة yassine-maroc ; 2006-06-16 الساعة 09:45 PM
    [BIMG]http://img314.imageshack.us/img314/3098/mine7ko.png[/BIMG]
    MDREAM
    MDREAM غير متواجد حالياً
    يسلموا
    بس لم ينزل عندي سو 6 كيلو بايت
    تحياتي
    Mdream
    yassine-maroc
    i just downlaod it yesterday it work all link are ok.
    try again.
    yassine-maroc
    MUSLIM125
    MUSLIM125 غير متواجد حالياً
    يا MDREAMيبدوا انك استخدمت Download Accelratorفى التحميل
    رابيد شير المجانى لا يدعم التحمسل بالداونلوداكسيليريتور لذا فالنتائج كما ترى
    الحل ان تعمل Disable للدوانلودأكسيليريتور وتحمل التحميل العادى بواسطة الExplorer
    م.محمد بن إسماعيل
    م.محمد بن إسماعيل غير متواجد حالياً
    Received: 33
    اقتباس المشاركة الأصلية كتبت بواسطة MUSLIM125
    السلام عليكم ورحمه اللهوبركاته
    اخي الحبيب MUSLIM125 يا مرحبا بيك بعد غياب طويل
    فعلاً اخي هذه اكيد هي المشكله و فعلاً هكذا حلها
    جزاك الله كل خير
    yassine-maroc
    أنا باستعمل internet download manager ؤبيدعم العربي وبضغط على المجانى وحمل بسرعة هو الوحيد الدي و الله أعلم بيدعم هده الخاصية ماستعمل premuim account
    design-baron
    design-baron غير متواجد حالياً
    السلام عليكم يا أخ ياسين
    أولا أحب اشكرك على هديتك الغالية دي، بس أنا عندي استفسار، أنا نزلت الملفين بتوع البرنامج من على الرابيد شير و الملفين بيفتحوا عندي على الوين رار، بس مش لاقي فيهم اي برنامج setup او install علشان ابدأ تنزيل البرنامج، ياريت لو تفيدني في الموضوع ده لأني محتاج البرنامج ده جدا. و شكرا
    ahmadalhamdan
    ahmadalhamdan غير متواجد حالياً
    أحتاج نسخة من برنامج Algor
    هل من يرسل لي أرجو المساعدة
    وشكراً لكم
