Zwcad 2006 professional v2006.5.5
النتائج 1 إلى 2 من 2
    yassine-maroc
    yassine-maroc غير متواجد حالياً
    [BIMG]http://img100.imageshack.us/img100/5794/clipboard019vm.th.jpg[/BIMG]
    ZwCAD 2006 is a great alternative for AutoCAD with native DWG version from 2.5 to 2006. ZwCAD 2006 can read, save and edit the files produced by AutoCAD (2.5-R14-2006) and the other way round. It's the intelligent choice for architects, engineers, designers, and virtually any professional who creates professional 2D and 3D CAD drawings. ZwCAD can be customized with lisp, C++ (ADS), and VBA (Visual Basic for Application).
    ZwCAD's native file format is .DWG, so when you open an existing DWG file there's no file conversion and no data loss. ZwCAD also provides a high degree of compatibility with the AutoCAD command set, as well programming API's such as AutoLISP and ADS. That means you can get to work immediately using the DWG files, AutoCAD commands and applications you rely on.
    ZwCAD 2006 PRO version offers a full 3D solid modeling environment and the Microsoft Visual Basic for Applications development environment. ZwCAD 2006 professional has combined features of ZwCAD 2006 Standard, and is well suited for solid modeling applications.
    You can export and import ACIS entities such as surfaces, regions, and solids to an ACIS file in ASCII (.Sat) format. You can bring in and send out any standard ACIS solid model within ZwCAD environment. You can save your 3D models in .sat format, which can be opened in any other solid modeling application.
    ZwCAD VBA has full Visual Basic language syntax, standard forms, and support for ActiveX Controls.
    Homepage:
    CODE
    http://www.zwcad.com
    Download: 50MB
    CODE
    http://ha.newhua.com/down/zwcad2006engp.exe
    ftp://home.zwcad.com/download/zwcad2006engp.exe
    DiGERATi patch:
    CODE
    http://rapidshare.de/files/21599492/...h-DIGERATI.zip
    or DiGERATi's complete release:
    ZwCAD_2006_Professional_v2006.5.15-DIGERATI
    CODE
    http://rapidshare.de/files/21598320/zc515.zip
    The nfo is a little misleading.
    Re: crack.rar - it doesn't exist, just a mistake in the install notes.
    Install app
    Apply patch in the install dir
    Run ZwCAD, go to Help, License, choose the "Acis" module, reg with any serial and restart app.
    Now do the same for the "Zwcad" module.ZwCAD 2006 is a great alternative for AutoCAD with native DWG version from 2.5 to 2006. ZwCAD 2006 can read, save and edit the files produced by AutoCAD (2.5-R14-2006) and the other way round. It's the intelligent choice for architects, engineers, designers, and virtually any professional who creates professional 2D and 3D CAD drawings. ZwCAD can be customized with lisp, C++ (ADS), and VBA (Visual Basic for Application).
    م.محمد بن إسماعيل
    م.محمد بن إسماعيل غير متواجد حالياً
    Received: 34
    ماشاء الله اخي الحبيب
    نحن مقدرين مجهوداتك فى قسم التحكم الرقمي...............(cnc)
    و اتمنى لك التوفيق
    و اسأل الله ان يجعلها فى ميزان حسناتك
    و السلام عليكم ورحمه الله وبركاته
