معدات ربط الشبكات Networks connecting Devices
النتائج 11 إلى 20 من 29
    Hilal
    Hilal غير متواجد حالياً
    شكرا والله اتحفتينا بهذه المعلومات
    MDREAM
    MDREAM غير متواجد حالياً
    شكرا لك عالمجهود الرائع
    تحياتي
    Mdream
    MDREAM
    ملتقى المهندسين العرب
    منتدى التحكم الرقمى بإستخدام الحاسب (CNC)
    MDREAMES*YAHOO.CO.UK
    hanloo
    hanloo غير متواجد حالياً
    لعل هذا مفيد
    The Wire to the Internet
    . Network Model . Network Layer Protocols . HTTP, FTP, ... . Network Infrastructure . Cabling, Hubs, … . PC Hardware . PCI, PCMCIA, …. .
    Demo
    People Don’t Need To See Paula Abdul
    . A 4 Layered Network View
    . Physical
    . Data (MAC addr, switching)
    . Network (IP addr, routing)
    . Application (65K conversations possible via
    Ports)
    . Think like a network device, not the User!
    A MAC address is unique for each Network Card (NIC).
    IP addressing
    Reserved address space
    10.x.x.x Class A
    172.16-31.x.x Class B
    192.168.x.x Class C
    What address to use?
    If is isn’t reserved, you may not get out
    Requesting address space
    ICANN or your ISP
    DHCP
    DNS issues
    IPv6 vs IPv4
    Vendor support
    Is it a real User requirement?
    Operating System Support
    Remote logins, “shrink wrap” support, file portability, etc
    Decimal2Binary
    . What Protocols? . The Internet as most see it (http, https) . File sharing (FTP, SMB) . Terminal Access (Telnet, SSH, X11) . Email (smtp, pop, imap)
    . Network Address Translation (NAT) . We all connect as one! . Do you need to NAT?
    . Myth: Proxy servers or firewalls . One way Firewall? . I can see you, hopefully you can’t see me.
    . Network Elements
    . Cables (voice/data)
    . Hubs and Switches
    . Routers and Firewalls
    Network Design
    . Topology
    . Bandwidth
    . Applications
    . House wiring
    . Dial tone = 48 volts
    . Ring = up to 150 volts
    . Color Pairs
    . Why talk about phone wiring?
    . Networks start from the wire
    . Most older buildings have legacy wiring
    . Do you reuse the building wiring?
    Your House Wiring
    Pair 1
    Pair 2
    Green
    Yellow
    Tip
    Red
    Black
    Ring
    . Color blind? . Primary Colors/Secondary Colors of bundles . Data cable colors you need to know. (Secondary Colors) . Do you have to remember colors?
    . Today most network connects are CAT5 and come color coded.
    Primary
    Secondary
    Colors
    Colors
    White
    Blue
    Red
    Orange
    Black
    Green
    Yellow
    Brown
    Violet
    Grey (Slate)
    100 Pair Cable Bundle Tag Colors
    Bundle Num (pair #)
    Tagged Color Wrap
    1 (1-25)
    Blue
    2 (26-50)
    Orange
    3 (51-75)
    Green
    4 (76-100)
    Brown
    . What is the difference between Cat 3, 5, 6
    . Cables you need to know how to make (Straight Through and Crossover)
    . Tools of the trade (toner, crimper, cable checker, scissors)
    Straight Through Cable Crossover Cable
    RJ-45 PIN
    RJ-45 PIN
    1 Rc+
    3 Tx+
    2 Rc
    6 Tx
    3 Tx+
    1 Rc+
    6 Tx
    2 Rc-
    RJ-45 PIN
    RJ-45 PIN
    1 Tx+
    1 Rc+
    2 Tx
    2 Rc
    3 Rc+
    3 Tx+
    6 Rc
    6 Tx
    . Hubs . All for one, one for all . Repeater
    . Switches . Forwarding based on MAC (bridge) . Auto-negotiation (speed/duplex) . In-line power . Segmentation (vlans) . How are they managed?
    . Embedded Web servers
    . SNMP (Simple Network Management Protocol)
    . What can be managed . Interfaces, Auto-negotiation, segments, broadcasts, etc. . Routing?
    . Routers . Forward packets based on Network addresses . Routing protocols . IP addresses/subnets . Broadcast domains . Software vs. ASIC
    . FreeBSD, RedHat Linux, etc . Cisco, Linksys, Nokia, etc. . Firewalls . Traffic analysis is based on SRC/DST IP addresses, ports, and/or
    packet *******s.
    . NAT
    . Inbound/outbound Access Control Lists (ACL)
    . Software vs. ASIC
    Wired vs. Wireless
    Media Types (Coax, Twisted Pair, Fiber,
    Wireless, Dialup?)
    Security – is it a concern?
    Speed – How fast is fast!
    Remember that the slowest link in the network is
    the base speed all hosts will talk.
    Your cable plant
    What type of media?
    Wireless? What is your channel plan?
    Types . PCI . PCMCIA . USB
    To install the hardware use these general
    rules: . PCI – install the card first, then software . PCMCIA and USB – install the software first, then
    the hardware
    3COM Setup Linksys Setup PCI Card Setup
    . Setup a wireless access point . Web interface
    . Ping test . PC connected via Cat5 to Access Point . PDA connected via Wireless
    . Overview of network level protocols, architecture, and design
    . “Under the Hood” look at real network components
    . Demo of configuration and operation of wireless and wired links
    bahm2006
    bahm2006 غير متواجد حالياً
    المعلومات جميلة جدا ولكن اتمنى التواصل بما هو امتداد لهذه المعلومات ولك الاجر والثواب
    شكرا جزيلا
    sumaya
    sumaya غير متواجد حالياً
    thanks
    for you
    sam6015
    sam6015 غير متواجد حالياً
    thanks
    thanks for you on this importannt iformation
    please moreeeeeeeeeeeeeee
    يحيى الكاف
    يحيى الكاف غير متواجد حالياً
    معلومات جيدة استفدت منها كثيرا جزاك الله خيرا
    م/ يحيى الكاف
    saifalseedi
    saifalseedi غير متواجد حالياً
    thank you very much
    dear
    madridieng
    madridieng غير متواجد حالياً
    الصورة الرمزية madridieng
    thanks man for this important information
    مهندس محمد منير
    مهندس محمد منير غير متواجد حالياً
    الصورة الرمزية مهندس محمد منير
    شكرا لك أخى الكريم
