دورة في تركيب شبكات Wan ( عملياً )
صفحة 5 من 23 الأولىالأولى 1 2 3 4 56 7 8 9 15 ... الأخيرةالأخيرة
النتائج 41 إلى 50 من 224
  1. [41]
    م.العراقي
    م.العراقي غير متواجد حالياً
    عضو تحرير المجلة
    الصورة الرمزية م.العراقي
    Received: 13
    سنكون سعداء كثيرا بذلك اخي ياسين ... وانا ايضا سأحاول كتابة شئ من ذلك بالعربية .. لعل الفائدة تعم الجميع .
    تحياتي
    سلام عليكم
    1 Not allowed!
    لا يكفي أن تعرف ... بل يجب أن تعرف كيف تطبق ما تعرف
  2. [42]
    ياسين2999
    ياسين2999 غير متواجد حالياً
    Talking
    غدا إن شاء الله .
  3. [43]
    yzairi
    yzairi غير متواجد حالياً
    الأخ م. العراقي تحية طيبة وبعد
    سأقوم بشرح كامل مبسط باللغة الإنجليزية لما طلبته
    إذا كان ذلك يريحك
    م. ياسين زائري
  4. [44]
    yzairi
    Bridge, Router, Repeater, Switch
    Dear all readers
    1. Router is a device that connects two networks - frequently over large distances. It understands one or more network protocols, such as IP or IPX.
    The Router accepts packets on at least two network interfaces, and forwards packets from one interface to another. The Router's may be programmed to filter out some packets, and to dynamically change the route by which packets are routed. Router's often use different media on each interface. For instance, a router might have one Ethernet port and one ISDN port.
    2. Bridge is
    (1) To cross from one circuit, channel or element over to another.
    (2) A device that connects two LAN segments together, which may be of similar or dissimilar types, such as Ethernet and Token Ring. A bridge is inserted into a network to segment it and keep traffic contained within the segments to improve performance.
    Bridges learn from experience and build and maintain address tables of the nodes on the network. By monitoring which station acknowledged receipt of the address, they learn which nodes belong to the segment.
    Bridges work at the data link layer (OSI layer 2), whereas routers work at the network layer (layer 3). Bridges are protocol independent; routers are protocol dependent. Bridges are faster than routers because they do not have to read the protocol to gleanrouting information.
    Bridges with more than two ports (multiport bridges) perform a switching function. Today's LAN switches are really multiport bridges that can switch at full wire speed.
    3. Gateway
    (1) A computer that performs protocol conversion between different types of networks or applications. For example, a gateway can convert a TCP/IP packet to a NetWare IPX packet and vice versa or from AppleTalk to DECnet, from SNA to AppleTalk and so on.
    Gateways function at layer 4 and above in the OSI model. They perform complete conversions from one protocol to another rather than simply support one protocol from within another, such as IP tunneling. Sometimes routers can implement gateway functions.
    An electronic mail, or messaging, gateway converts messages between two different messaging protocols. See LAN and IP gateway.
    (2) A computer that acts as a go-between two or more networks that use the same protocols. In this case, the gateway functions as an entry/exit point to the network. Transport protocol conversion may not be required, but some form of processing is typically performed.
    (3) An earth station and computer complex that switches data and voice signals between satellites and terrestrial networks.
    (4) The Gateway as far my knowledge an earlier name for router .
    Repeater
    (1) A communications device that amplifies (analog) or regenerates (digital) the data signal in order to extend the transmission distance. Available for both electronic and optical signals, repeaters are used extensively in long distance transmission. Theyare also used to tie two LANs of the same type together. Repeaters work at layer 1 of the OSI model.
    (2) The term may also refer to a multiport repeater, which is a hub in a 10BaseT network.
    Dear Arab-eng.org readers you can refer also to Router and Bridge for more information about repeaters
    Switch
    Electronic device that directs the flow of electrical or optical signals from one side to the other. Switches with more than two ports, such as a LAN switch or PBX, also you can say or it is a standard that they route the traffic
    Yassine Zairi
    SSE
    Al Bustan Shopping Mall
  5. [45]
    م.العراقي
    عضو تحرير المجلة
    Received: 13
    سلام عليكم
    اخي yzairi ... اشكرك على اثرائنا بهذه المعلومات .. واتمنى استمرار التواصل .
    شاكر ومقدر لك جداً .
    لكنني كنت اطمع في المعلومات عن
    1.10.10.10 20.10.10.10 ....... وما زلت اطمع في ذلك اخي ياسين :)
  6. [46]
    yzairi
    الأخ م. عراقي
    ممكن جدا نتكلم على الياهو silencervx
    مع أجمل تحية
    ياسين
  7. [47]
    ياسين2999
    Talking
    السلام عليكم ,
    هذه بعض النتائج التى تحصلت عليها التى قمت بترجمتها من الفرنسية , أرجو انه لا تكون عناك أخطاء بالإنجليزية ( الإنجليزية عندى ليست بالجيدة )
    أرجو تحميل الملف المرفق ,
    في إنتضار التعقيب تقبلو تحياتى ,
    ياسين.
  8. [48]
    م.العراقي
    عضو تحرير المجلة
    Received: 13
    سبحان الله ، اسم ( ياسين ) اصلاً ليس واسع الانتشار ، وهنا أنا أتحدث الى زميلين عزيزين وكلاهما ( ياسين ) . :)
    شاكر لكما جداً جداً .
    وادعو باقي الاخوة الاعضاء للمشاركة .. لأننا نريد أن يستفيد الجميع .
    جزاكم الله ألف خير .. سلام عليكم
  9. [49]
    yzairi
    شكرا يا م. العراقي
  10. [50]
    yzairi
    IP Addressing Standards
    الإخوة الأعضاء
    تحية طيبة وبعد
    حسب ما أراده الأخ م. العراقي سأبدأ بشرح IP Addressing Standards للمؤسسات
    في خلال يوم أو يومين
    لكن سيكون هذا متعب للبعض الذي قد لن يستوعبه بتلك السهولة
    والسلام
