كتاب انظمة التكي
النتائج 1 إلى 10 من 49
    هارون الرشيد
    هارون الرشيد غير متواجد حالياً
    كتاب انظمة التكييف والتبريد ASHRAE Handbook - HVAC Systems & Equipment 2004
    كتاب انظمة التكييف والتبريد ASHRAE Handbook 2004 - HVAC Systems & Equipment
    الانظمة والاجهزة للتكييف والتبريد ASHRAE Handbook 2004 - HVAC Systems & Equipment
    2004 ASHRAE Handbook - HVAC Systems & Equipment
    2004 ASHRAE Handbook - HVAC Systems and Equipment
    Table of Contents
    This volume helps system designers and operators in selecting and using equipment, by providing in-depth descriptions of features and differences of a wide variety of common systems, and the equipment (components or assemblies) that comprise them.
    AIR-CONDITIONING AND HEATING SYSTEMS
    Chapter 1. HVAC System Analysis and Selection
    2. Building Air Distribution
    3. In-Room Terminal Systems
    4. Central Cooling and Heating
    5. Decentralized Cooling and Heating
    6. Panel Heating and Cooling
    7. Cogeneration Systems and Engine and Turbine Drives
    8. Applied Heat Pump and Heat Recovery Systems
    9. Design of Small Forced-Air Heating and Cooling Systems
    10. Steam Systems
    11. District Heating and Cooling
    12. Hydronic Heating and Cooling System Design
    13. Condenser Water Systems
    14. Medium- and High-Temperature Water Heating Systems
    15. Infrared Radiant Heating
    AIR-HANDLING EQUIPMENT
    Chapter 16. Duct Construction
    17. Room Air Distribution Equipment
    18. Fans
    19. Evaporative Air-Cooling Equipment
    20. Humidifiers
    21. Air-Cooling and Dehumidifying Coils
    22. Desiccant Dehumidification and Pressure Drying Equipment
    23. Air-Heating Coils
    24. Air Cleaners for Particulate Contaminants
    25. Industrial Gas Cleaning and Air Pollution Control
    HEATING EQUIPMENT
    Chapter 26. Automatic Fuel-Burning Equipment
    27. Boilers
    28. Furnaces
    29. Residential In-Space Heating Equipment
    30. Chimney, Gas Vent, and Fireplace Systems
    31. Unit Ventilators, Unit Heaters, and Makeup Air Units
    32. Hydronic Heat-Distributing Units and Radiators
    33. Solar Energy Equipment
    GENERAL COMPONENTS
    Chapter 34. Compressors
    35. Condensers
    36. Cooling Towers
    37. Liquid Coolers
    38. Liquid-Chilling Systems
    39. Centrifugal Pumps
    40. Motors, Motor Controls, and Variable-Speed Drives
    41. Pipes, Tubes, and Fittings
    42. Valves
    43. Heat Exchangers
    44. Air-to-Air Energy Recovery
    UNITARY EQUIPMENT
    Chapter 45. Unitary Air Conditioners and Heat Pumps
    46. Room Air Conditioners and Packaged Terminal Air Conditioners
    47. Mechanical Dehumidifiers and Heat Pipes
    حمل من هنا :
    http://www.megaupload.com/?d=Y1RKD564
    لفك الضغط :
    www.allislam.net/vb
    بعد الانتهاء من التحميل انسخها على cd وافتح الكتاب من هناك
    م. عبد المنعم
    م. عبد المنعم غير متواجد حالياً
    Received: 22
    جزاك الله خيراً عنا ..
    لكـــــــــــــن ..
    مع الاسف الموقع محجوب في كثير من البلدان ولله الحمد ..
    ممكن أحد من الأخوة الكرام ، في حال نجاح التحميل ، ان ينقله الى مواقع تحميل أكثر شرفاً .. وما أكثرها .. وجزاكم الله كل خير عنا
    abuyaser
    abuyaser غير متواجد حالياً
    Received: 12
    حجم الملف كبير جدا أكثر من 91 ميغا ياحبذا لو جزء إلى أربعة أجزاء
    abuyaser
    Received: 12
    بعد العناء الشديد و اكمال التنزيل لم يعمل ويطلب السيدي الأصلي كان ينبغي أخذ السيدي الأصلي كصورة Image على برنامج النيرو لنتمكن من الحصول على نسخة مطابقة للأصل
    moghrabi
    moghrabi غير متواجد حالياً
    to all brother
    Here the links to:
    American Society of Heating, Refrigerating and Air-Conditioning Engineers (ASHRAE) Handbooks [216MB]:
    http://rapidshare.de/files/20339544/...2000.part1.rar
    http://rapidshare.de/files/20343988/...2000.part2.rar
    http://rapidshare.de/files/20335259/...2000.part3.rar
    please do not forget me from Duwaa
    and thank you to all
    and espacially to brother Haroun alrasheed many thanky too
    moghrabi
    Achi Haroun
    Brother abu yasser has right:
    could you check it please and upload it again als ISO-Image
    thank you
    م. عبد المنعم
    Received: 22
    أخي الكريم moghrabi ..
    جزاك الله كل خير ووفقك الى ما يحبه ويرضاه ..
    أخي الكريم باختصار ..
    اذا ماحملنا الملفات اعلا ه التي وضعتها .. هل ستعمل بعد التحميل ؟؟... هل جربتها بنفسك ؟؟..
    فانت تعلم ان حجمها كبير للغاية ، واخونا ابو ياسر .. حمّلها ولم تعمل بعد ..
    وننتظر ردكم الكريم ..
    moghrabi
    Achi Abdulmunaaem
    I downloaded it and it was ISO-Image
    it is the file : ASHRAE_Handbooks_1997-2000.ISO
    the setup does not work but you can see all pdf-Files without problem with all Links it works
    Jazakuma allaha kul alkheir too
    a-scorpion
    a-scorpion غير متواجد حالياً
    Question ياهو انقذوني
    لا تحطو مواقع التنزيل السيئة هاذي تعبت وانا احاول انزل منها ومافي أمل وكل ما اشوف موضوع يشدني بالأخر أكتشف انو ملف محطوط هناك وما حينزل معايا انقذونا وشوفو حل انا حاليا محتاج الأشري سي دي بس مو قادر اخدو الموقع كل ما اضغط زر يرميني بصفحة ثانية والموقع التاني مقفل فأرجوكم ياإخوان الخير أنقذونييييييييييييييييييي
    هارون الرشيد
    يا اخوان الكتاب يعمل بشكل ممتاز جدا
    فقط انسخ الكتاب على سي دي
    افتح الكتاب من السي دي باختيار اوبن وليس اتو رن
    سيطلب برنامج الاكروبات تحديث بيط وافق عليه وحملة حجمه بسيط جدا
    بعدها يمكنك تصفح الكتاب بكل سهولة ويسر
