ALL PLCs
صفحة 5 من 9 الأولىالأولى 1 2 3 4 56 7 8 9 الأخيرةالأخيرة
النتائج 41 إلى 50 من 86
  1. [41]
    SAAD RASHED
    SAAD RASHED غير متواجد حالياً
    الصورة الرمزية SAAD RASHED
    اقتباس المشاركة الأصلية كتبت بواسطة مهندس/اسماعيل مشاهدة المشاركة
    ممكن معلومات عن plc ماركه LG
    http://www.lgis.com/product/product/...in.asp#A02;001
    اليك هذا الرابط
  2. [42]
    hatemeid
    hatemeid غير متواجد حالياً
    To Eng SAAD RASHED
    thanks alot for your help
    Dear sir,
    I have the Attached Network and it was Working Good , But Suddenly the Hard Disk of PC was Damaged and i forced to install the windows , RSlinx , Rslogix500 and Rsview runtime again
    But when i tried to make Communication with the Network using RSlinx on PC
    I Have No Response from the CPU , and i return the CPU of SLC5/03 PLC to initial Factory Setting by Jumber (VBB , GND ) terminals and downloaded the Rslogix 500 user program again ,But when i tried to make communication again with the system using Rslinx with the following configurtion:
    Driver Type: RS-232 DF1 Device
    Device: SLC-CH0 / micro / panel view
    comm port : com1
    baud rate: 19200
    parity: None
    Stop Bits: 1
    Protocol : Full Duplex
    Error Checking: CRC
    the communication is passed for only SLC5/03 and i can't communicate with micrologix1000.
    Notes :
    ALL the Devices is Powered UP
    My Questions are:
    1- Why this bad communication happened ?and how i overcome this problem?
    2-What the right configuration of the Rslinx that i can communicte with all Devices
    (micrologix1000 and SLC 5/03)
    الصور المرفقة
  3. [43]
    مهندس اليكس
    مهندس اليكس غير متواجد حالياً
    شكرا يا باشا
  4. [44]
    SAAD RASHED
    All plc tec
  5. [45]
    hatemeid
    الى المهندس Saad Rashed
    انا كان لى سؤال وكنت محتاج مساعدتك فى الاجابة عليه
    ارجو الرد
  6. [46]
    SAAD RASHED
    all plc tec
  7. [47]
    hatemeid
    Have you had answer to my question? yes or No, this is third queary
    :confused:
    اقتباس المشاركة الأصلية كتبت بواسطة hatemeid مشاهدة المشاركة
    Dear sir,
    comm port : com1
    baud rate: 19200
    parity: None
    Stop Bits: 1
    Error Checking: CRC
    Notes :
    My Questions are:
  8. [48]
    المتكامل
    المتكامل غير متواجد حالياً
    الصورة الرمزية المتكامل
    Received: 17
    كنت امنى ان تشرح هذه plc ؟
  9. [49]
    SAAD RASHED
    أعتذر للأخوة لعدم الرد أو المشاركة لظروف خاصة ونعاود اللقاء
  10. [50]
    SAAD RASHED
    Dear sir,
    comm port : com1
    baud rate: 19200
    parity: None
    Stop Bits: 1
    Error Checking: CRC
    Notes :
    My Questions are:
    راجع الكتيب الخاص بكل cpu مع استخدام الكابل و ال adapter الخاص بذلك مع العلم ان الوصلة التى استخدمتها لا تصلح مع الجميع
