للمهندسيين ... برنامج R-Drive Image V.3.0.3047
النتائج 1 إلى 8 من 8
    Mu7ammad
    Mu7ammad غير متواجد حالياً
    Received: 8
    اخوانى الاعزاء .....
    نزل الاصدار الجديد للبرنامج R-Drive Image وهوالاصدار رقم ver.3.0.3047 ... وهو برنامج يقوم بعمل BackUp لاجزاء الهارد ديسك ...
    R-Drive Image 3.0 is a potent utility providing disk image files creation for backup or duplication purposes. A disk image file contains the exact, byte-by-byte copy of a hard drive, partition or logical disk and can be created with various compression levels on the fly without stopping Windows OS and therefore without interrupting your business. These drive image files can then be stored in a variety of places, including various removable media such as CD-R(W)/DVD, Iomega Zip or Jazz disks, etc.
    R-Drive Image restores the images on the original disks, on any other partitions or even on a hard drive's free space on the fly. To restore system and other locked partitions R-Drive Image is switched to the pseudo-graphic mode directly from Windows or bootable version created by the utility is launched from CD disc or diskettes.
    Using R-Drive Image, you can completely and rapidly restore your system after heavy data loss caused by an operating system crash, virus attack or hardware failure. You can also use R-Drive Image for mass system deployment when you need to setup many identical computers. In other words, you can manually setup one system only, create an image of the system, and then deploy it on all other computers, saving your time and costs. If you need to restore only certain files from a disk image, you can connect that image as a virtual disk and copy those files directly from the disk image using Windows Explorer or any other file utility.
    R-Drive Image
    V.3.0.3047
    التحـــميل
    موقع الشركة
    كيفية تحميل الملفات من خلال موقع Rapidshare !
    والله ولى التوفيق
    aikidoo
    aikidoo غير متواجد حالياً
    شكرا لكم على المجهودات الجميلة وجزاكم الله خيرا
    الرزامي
    الرزامي غير متواجد حالياً
    ألف شكر لكم على هذه المعلومات القيمة
    عبد الكريم
    عبد الكريم غير متواجد حالياً
    Eng. Taher
    Eng. Taher غير متواجد حالياً
    البرنامج موجود عندي المشكلة في الكراك
    ابيشان
    ابيشان غير متواجد حالياً
    اين الكراك
    لا فائدة من البرنامج من غير الكراك
    فورميكاس
    فورميكاس غير متواجد حالياً
    مشكورون على الموضوع الممتاز
    ابيشان
    اقتباس المشاركة الأصلية كتبت بواسطة mu7ammad مشاهدة المشاركة
    نزل الاصدار الجديد للبرنامج R-drive Image وهوالاصدار رقم Ver.3.0.3047 ... وهو برنامج يقوم بعمل Backup لاجزاء الهارد ديسك ...
    r-drive Image 3.0 Is A Potent Utility Providing Disk Image Files Creation For Backup Or Duplication Purposes. A Disk Image File Contains The Exact, Byte-by-byte Copy Of A Hard Drive, Partition Or Logical Disk And Can Be Created With Various Compression Levels On The Fly Without Stopping Windows Os And Therefore Without Interrupting Your Business. These Drive Image Files Can Then Be Stored In A Variety Of Places, Including Various Removable Media Such As Cd-r(w)/dvd, Iomega Zip Or Jazz Disks, Etc.
    r-drive Image Restores The Images On The Original Disks, On Any Other Partitions Or Even On A Hard Drive's Free Space On The Fly. To Restore System And Other Locked Partitions R-drive Image Is Switched To The Pseudo-graphic Mode Directly From Windows Or Bootable Version Created By The Utility Is Launched From Cd Disc Or Diskettes.
    using R-drive Image, You Can Completely And Rapidly Restore Your System After Heavy Data Loss Caused By An Operating System Crash, Virus Attack Or Hardware Failure. You Can Also Use R-drive Image For Mass System Deployment When You Need To Setup Many Identical Computers. In Other Words, You Can Manually Setup One System Only, Create An Image Of The System, And Then Deploy It On All Other Computers, Saving Your Time And Costs. If You Need To Restore Only Certain Files From A Disk Image, You Can Connect That Image As A Virtual Disk And Copy Those Files Directly From The Disk Image Using Windows Explorer Or Any Other File Utility.
    r-drive Image
    v.3.0.3047
    والله ولى التوفيق
    السلام عليكم ورحمة الله
    كل الشكر لك اخي
    البرنامج عندي من زمان وهو فعال 100%
    تحياتي الك
