زمن العجايب Tekla 16
النتائج 1 إلى 10 من 17
    زعيم الاسكندرية
    زعيم الاسكندرية غير متواجد حالياً
    Received: 261
    Given: 264
    ايها المواطنون فى ملتقى المهندسين العرب
    السلام عليكم ورحمة الله وبركاته ،،
    انه بحق زمن العجايب
    فى الوقت الذى نلهث فيه وراء tekla 15
    يظهر لنا tekla 16 مع الكراك
    والآن ما رايكم فى زعيمكم ؟؟؟؟؟؟؟؟؟؟؟؟
    Tekla 16 BETA + Default Environment
    info:
    If you have installed an earlier beta version, do the following first:
    * Uninstall previous beta versions
    * Remove TS_16_Env_Installer.exe from C:\TeklaStructuresDownloads\16.0
    Installing Tekla Structures 16.0 Public Beta:
    1. Install the software
    * Click one of the software installers below, either the 32-bit or the 64-bit version, depending on your computer set up
    o The software installation package also installs the common environment, which is utilized by all the other environments. Do not uninstall the common environment.
    o You can also download the installation package for installing later
    2. Install the localized environment(s)
    * Click the environment file you want to install
    o The environments can be installed only if Tekla Structures 16.0 software is installed first. You need to install at least one environment.
    screenshots:
    Image is shown in its original resolution (774x189). Click this bar to resize image to fit in page (700x171). Click image to open in new window.
    Download Links:
    Code:
    http://rapidshare.com/files/30534634...ware.part1.rar
    http://rapidshare.com/files/30534713...ware.part2.rar
    http://rapidshare.com/files/30534745...ware.part3.rar
    http://rapidshare.com/files/30534466...fault_inst.rar
    screenshots:
    Image has been scaled down 14% (700x344). Click this bar to view original image (808x396). Click image to open in new window.
    Download Links:
    Code:
    http://rapidshare.com/files/305453304/T16b.rar
    Password:
    Code:
    FromCivilEA
    kehh
    kehh غير متواجد حالياً
    للاسف رفض برنامج الرلبيد
    طلب account
    م عبد الحكيم مواس
    م عبد الحكيم مواس غير متواجد حالياً
    الصورة الرمزية م عبد الحكيم مواس
    Received: 269
    Given: 472
    السلام عليكم عمنا الزعيم
    طالما اعترفنا فيك زعيم فانت الزعيم
    بكل ما تعنيه الكلمة من معنى الزعامة
    أشكرك على limconx
    و على كل شيء ممتاز قدمته
    أرجو إن امكن تحميل الملفات على 4shared
    و لك جزيل الشكر حتى الشكر قليل عليك
    فلك التحية bow to the king
    الله يوفقك لكل خير .
    سنا الإسلام
    سنا الإسلام غير متواجد حالياً
    Received: 257
    جزاكم الله خيرا وبارك الله فيك
    متغيبة عن الملتقى
    أحمد عصام الدين
    أحمد عصام الدين غير متواجد حالياً
    الصورة الرمزية أحمد عصام الدين
    Received: 17
    مشكور يا زعيمنا
    رمزي2009
    رمزي2009 غير متواجد حالياً
    Received: 41
    ممكن تحميلها علي موقع اخر
    herb
    herb غير متواجد حالياً
    شــــــــــــــــــــــــكـــــــــــــــــــــــر ا
    زعيم الاسكندرية
    Received: 261
    Given: 264
    اقتباس المشاركة الأصلية كتبت بواسطة kehh مشاهدة المشاركة
    طلب account
    فعلا ولكنى قمت بتحميل جزأين بواسطة برنامج download direct الذى يحمل من الرابيد شير بدون حساب
    اقتباس المشاركة الأصلية كتبت بواسطة abo alafkar مشاهدة المشاركة
    أشكرك على limconx
    هذا ليس شيئا من بعد خيرك يا عم ابو الأفكار واحنا بنتعلم منك اما عن الاعتراف بالزعامة فانا امزح فقط فى المشاركات لألفت الأنظار لما فى المشاركة واتمنى من كل قلبى ان يستفيد كل اعضاء الملتقى من مشاركاتى كما استفدت انا سابقا
    لك جزيل الشكر على مرورك الطيب وعلى تحيتك واعدك ان احاول الرفع مرة اخرى على اى موقع آخر
    اقتباس المشاركة الأصلية كتبت بواسطة سنا الإسلام مشاهدة المشاركة
    اجمل ما فى مشاركاتك هو توقيعك المميز دونا عن سائر التوقيعات وشكرا لك على مرورك الطيب واذا كان لديك روابط بديلة لبرنامج tekla 15 لأن عندى مشكلة فى التحميل من الميديا فير وشكرا لك مقدما
    اقتباس المشاركة الأصلية كتبت بواسطة أحمد عصام الدين مشاهدة المشاركة
    مشكور يا زعيمنا
    فى يوم من الأيام تمنيت ان تكون مشاركاتى فى نفس مستوى مشاركاتك المميزة عن برامج الساب والسيف ولكنك تسبقنى بمراحل يصعب تداركها
    شكرا لك على مرورك الطيب يا عم عصام وجزاك الله خيرا
    اقتباس المشاركة الأصلية كتبت بواسطة رمزي2009 مشاهدة المشاركة
    ان شاء الله
    اقتباس المشاركة الأصلية كتبت بواسطة herb مشاهدة المشاركة
    دوهدا
    دوهدا غير متواجد حالياً
    شكرا بس ممكن رفع البرنامج على الميديافير
    موحا المغربي
    موحا المغربي غير متواجد حالياً
