please guys quickly i am stack
النتائج 1 إلى 3 من 3
    ولـد بريـطانيا
    ولـد بريـطانيا غير متواجد حالياً
    soory to write in english
    but i am in the libry an the assignment will hand it in by 2moro and i stack in these three Qs
    al5warzmyat
    Question1
    Write an algorithm that accepts an array
    A[1 : : : n], and an array B[1 : : :m] and outputs an
    array
    C[1 : : : n+m] containing all the elements of the array A followed by all the elements
    of the array
    B, preserving the order of the elements. For example: if A = [1; 2; 3; 4; 5],
    and
    B = [9; 8; 7; 6] then the output will be an array C = [1; 2; 3; 4; 5; 9; 8; 7; 6].
    Question 2
    Write an algorithm which calculates the number of
    occurrences of an item M in an array
    A
    [1 : : : n]. With array [6; 10; 2; 23; 6; 10; 6; 12] and input 10 it should return 2, while with
    the inputs
    2; 5; 6 it should return the results 1; 0; 3 respectively.
    Question 3
    Write an algorithm which inputs an array and decides if all the items are distinct. For
    example when run on [2, 4, 5, 2] it should return false, while on the array [5, 2, 6, 1, 7, 9]
    it should return true.
    please guy help me if u know
    من مواضيع ولـد بريـطانيا :
    ولـد بريـطانيا
    i am wating u guys
    VIP75
    VIP75 غير متواجد حالياً
    الصورة الرمزية VIP75
    يا غشاش .. حل لوحدك... اعملك برشامة تنفعك
    KHALED MUSTAFA
    KM COMPUTER SYSTEMS
    EGYPT
