بعض التعريفات والأساسيات فى الميكانيكا Basic Mechanics
النتائج 1 إلى 9 من 9
    الصورة الرمزية أحمد رأفت
    أحمد رأفت
    أحمد رأفت غير متواجد حالياً
    Received: 11
    Given: 14
    Some Definitions
    Basics
    علم الميكانيكا كان يطلق علية العرب قديمآ علم الحيل
    Mechanics is the branch of physics concerned with the behavior of physical bodies when subjected to forces or displacements, and the subsequent effect of the bodies on their environment.
    Mechanics is the study of the way matter and forces interact with each other. Here we are concerned with macroscopic bodies, i.e., bodies that you can easily see, in the solid state.
    classical mechanics is one of the two major sub-fields of study in the science of mechanics, which is concerned with the set of physical laws governing and mathematically describing the motions of bodies and aggregates of bodies geometrically distributed within a certain boundary under the action of a system of forces
    Quantum mechanics (QM) is a set of principles describing physical reality at the atomic level of matter (molecules and atoms) and the subatomic (electrons, protons, and even smaller particles).
    Statics is a field within mechanics which concerns itself with forces when no change in momentum occurs.
    Dynamics is a field concerned with forces and matter when a change in momentum does occur.
    Kinematics is a study of motion without regard to the forces present. It is simply a mathematical way to describe motion
    Force a force can most easily be described as a push or a pull. When a force is applied to an object, the velocity of that object changes. This change in velocity constitutes an acceleration. So, forces are tied to accelerations.
    Newton's First Law of Motion (Law of Inertia) A body persists its state of rest or of uniform motion unless acted upon by an external unbalanced force.
    الجسم الساكن يبقى ساكنا ما لم تؤثر عليه قوة خارجية فتحركه، و الجسم المتحرك بسرعة ثابتة في خط مستقيم يبقى على هذه الحالة ما لم تؤثر عليه قوة خارجية فتغير الحالة الحركية له.ويسمى أيضا هذا القانون بقانون القصور الذاتي.
    Newton's second Law of Motion (Motion Law) the net force on a particle is equal to the time rate of change of its linear momentum. Force equals mass times acceleration (F = ma) the net force on an object is equal to the mass of the object multiplied by its acceleration.
    إذا أثرت قوة على جسم أكسبته عجلة تتناسب طرديا مع القوة المؤثرة ،و عكسيا مع كتلة الجسم.
    يارب أكون أفدتكم ببعض من اساسيات علم الميكانيكا (علم الحيل)
    وياريت لوتشاركونا وتكملولنا باقى الأساسيات
    ويارب يوفقنا ويوفقكم لما هوا خير
    د.محبس
    د.محبس غير متواجد حالياً
    عضو متميز جداً
    الصورة الرمزية د.محبس
    Received: 20
    Given: 6
    عجبتني هذه العبارة
    شكرا
    مهندس ميكانيك
    1981
    د.محمد باشراحيل
    إستشاري الملتقى
    Received: 127
    Given: 15
    معلومات مفيدة ..
    مهندس أحمد رأفت ..
    بارك الله فيك ..
    SAIF.A.GHANNAI
    SAIF.A.GHANNAI غير متواجد حالياً
    بارك الله فيك على مجهوداتك
    SAIF.A.GHANNAI
    اخوتى المهندسين جزاكم الله خيرا سلفا اريد منكم ان تفيدونى بارشادات وتحوطات السلامة عند العمل على ظهر القاطرات البحرية وزوارق السحب بالموانئ
    اسامة القاسى
    الصورة الرمزية اسامة القاسى
    بارك الله فيك
    م.بشار الراوي
    م.بشار الراوي غير متواجد حالياً
    الصورة الرمزية م.بشار الراوي
    Received: 14
    جهد متميز شكرا
    Bashar Al-Rawi
    M.Sc.in Mech.Eng
    Quality Control Engineer
    Methanex Engineer
    Methanex Engineer غير متواجد حالياً
    Excellent
    مانع صالح
    مانع صالح غير متواجد حالياً
    Given: 4
    لربما أحدكم يريد الاستزادة عن الميكانيكا فليقرأ هذه الرابط
