ارجو المساعدة
النتائج 1 إلى 2 من 2
    h_azawi
    h_azawi غير متواجد حالياً
    ارجو المساعدة
    مرحبا جميعا ...
    ممكن مساعده
    محتاجة شرح لبرنامج الاوتوكاد 2009 ..اريده شرح تفصيلي وواضح للمنتدئين..
    مشكوريييييييييييييين
    من مواضيع h_azawi :
    Securitysuite
    Securitysuite غير متواجد حالياً
    الصورة الرمزية Securitysuite
    السلام عليكم,
    تفضل اخى
    AutoCAD 2009 & AutoCAD LT 2009 All-in-One Desk Reference For Dummies
    Nobody ever said AutoCAD was easy, which is why you need AutoCAD & AutoCAD LT 2009 All-In-One Desk Reference for Dummies! These nine minibooks cover all the stuff you need to know to set up AutoCAD for 2D or 3D, create drawings, modify and share them, publish your work, and more. There’s even a minibook devoted to increasing your options with AutoCAD LT!
    This one-stop guide to creating great technical drawings using AutoCAD 2009 shows you how to navigate the AutoCAD interface, set up drawings, use basic and precision tools, and use drawing objects. You’ll learn how to annotate your drawings, use dimensioning and hatching, and work with AutoCAD’s new Annotation Scaling feature. You’ll also find out how to work with solids, texture surfaces, add lighting, and much more. Discover how to
    * Navigate the AutoCAD interface
    * Work with lines, shapes, and curves
    * Add explanatory text
    * Understand AutoCAD LT’s limitations
    * Render your drawings
    * Create and manage blocks
    * Use AutoCAD advanced drafting techniques
    * Comply with CAD management and standards
    * Share your work with others
    * Customize the AutoCAD interface, tools, and more
    Complete with Web links to advanced information on navigating the AutoCAD programming interfaces, using custom programs, getting started with AutoLISP, and working with Visual Basic for AutoCAD, AutoCAD & AutoCAD LT 2009 All-In-One Desk Reference for Dummies is the only comprehensive AutoCAD guide you’ll ever need.
    http://rapidshare.com/files/250564104/ATC.rar
    Jon McFarland, "AutoCAD 2009 and AutoCAD LT 2009: No Experience Required"
    Learning AutoCAD, like learning any complex computer program, requires a significant commitment of time and attention and, to some extent, a tolerance for repetition. AutoCAD 2009 and AutoCAD LT 2009: No Experience Required is a simple, yet engaging tutorial that takes readers through an entire project, designing a simple cabin from start to finish, while helping them become familiar with AutoCAD tools and techniques. As you work your way through the book, you'll familiarize yourself with the AutoCAD interface and basic commands, develop efficient drawing strategies, learn how to work with AutoCAD's major features, get comfortable with the 3D modeling tools and methods for applying materials, and ultimately, build a set of drawings that document your progress through the project that can be used later as reference material if you need to refresh a specific skill.
    http://depositfiles.com/de/files/7003257
    VTC - Autodesk AutoCAD 2009 Certified Associate [Tutorial] | 280 MB
    AutoCAD 2009, written by software vendor Autodesk, is the world’s most widely used Computer Aided Design (CAD) package. It lets you design, visualize and communicate your ideas with ease and efficiency. Led by Shaun Bryant, this course provides viewers with the basic essentials needed to take and pass the AutoCAD 2009 Certified Associate exam.
    What's Inside
    Introduction
    -Getting Started with Autodesk Certification (03:57)
    -What Do You Need to Do? (01:02)
    AutoCAD 2009
    -Workspaces (04:15)
    -Keyboard Input (07:06)
    -User Interface (06:54)
    -Shortcut Menus (04:43)
    -Specific Interface Tools (07:33)
    -Working with Files pt. 1 (06:52)
    -Working with Files pt. 2 (03:17)
    -Displaying Objects (05:17)
    Basic Drawing Skills
    -Inputting Data pt. 1 (05:16)
    -Inputting Data pt. 2 (03:05)
    -Inputting Data pt. 3 (05:07)
    -Inputting Data pt. 4 (05:36)
    -Creating Basic Objects pt. 1 (07:19)
    -Creating Basic Objects pt. 2 (03:07)
    -Creating Basic Objects pt. 3 (02:53)
    -Object Snaps (04:20)
    -Polar & PolarSnap (03:19)
    -Object Snap Tracking (04:49)
    -Units (05:22)
    Working with Objects
    -Selecting Objects (06:01)
    -Moving Objects (04:56)
    -Copying Objects (02:25)
    -Rotating Objects (04:32)
    -Mirroring Objects (02:36)
    -Creating Arrays pt. 1 (05:10)
    -Creating Arrays pt. 2 (03:42)
    -Scaling Objects (03:42)
    -Grips (06:23)
    Organization & Inquiry
    -Using Layers pt. 1 (04:37)
    -Using Layers pt. 2 (03:37)
    -Object Properties (06:14)
    -Quick Properties (02:16)
    -Matching Object Properties (06:31)
    -Linetypes (03:46)
    -Inquiry Commands (05:40)
    Altering Objects
    -Trim & Extend (05:09)
    -Parallel & Offset Geometry pt. 1 (03:24)
    -Parallel & Offset Geometry pt. 2 (04:46)
    -Joining Objects (03:08)
    -Breaking Objects (03:14)
    -Fillets pt. 1 (01:40)
    -Fillets pt. 2 (01:54)
    -Chamfers (04:13)
    -Stretching Objects (03:48)
    Working with Layouts
    -Using Layouts (04:45)
    -Using Viewports (06:31)
    Annotation
    -Multiline Text (MTEXT) (04:09)
    -Single Line Text (DTEXT) pt. 1 (04:15)
    -Single Line Text (DTEXT) pt. 2 (03:40)
    -Editing Text (04:15)
    -Using Text Styles (04:30)
    Dimensioning
    -Creating Dimensions pt. 1 (05:31)
    -Creating Dimensions pt. 2 (03:13)
    -Using Dimension Styles pt. 1 (05:42)
    -Using Dimension Styles pt. 2 (02:16)
    -Editing Dimensions (05:11)
    -Using Multileaders (05:45)
    Hatching
    -Hatching Objects (03:39)
    -Fills & Gradients (04:18)
    -Editing Hatch Objects (02:53)
    Reusable *******
    -Using Blocks (04:08)
    -DesignCenter (02:56)
    -Tool Palettes (04:29)
    -Using Tool Palettes (03:51)
    Additional Drawing Objects
    -Polylines (06:10)
    -Splines (02:34)
    -Ellipses (03:08)
    -Tables (06:06)
    Plotting Drawings
    -Page Setups (04:28)
    -Plotting Drawings (04:19)
    -Viewing DWF Files (02:44)
    Drawing Templates (DWT)
    -Drawing Templates pt. 1 (05:17)
    -Drawing Templates pt. 2 (04:27)
    Wrap Up
    -What was Covered / Final Thoughts (01:13)
    -About this Author (00:28)
    Download:
    http://uploaded.to/file/kmttwo/VTC.A...rial.part1.rar
    http://uploaded.to/file/wlz007/VTC.A...rial.part2.rar
    http://uploaded.to/file/gdrqmn/VTC.A...rial.part3.rar
