دراسة كاملة عن الشلر
النتائج 21 إلى 25 من 25
  1. [21]
    ابو شوك
    ابو شوك غير متواجد حالياً
    اخي المهندس ارجاء الامساعدة فس مجال اسمه والنوع الدك ماهي الاعطالة له وكيفيت عملية التوصيل وشكرا
  2. [22]
    tosh
    tosh غير متواجد حالياً
    Refrigeration principle
    Weak solution transported by solution pump to the high pressure generator , is heated by heat source in high pressure generator ,and concentrated to for intermediate solution. The intermediate solution is heated in low-pressure generator by the refrigerant vapor produced in the HP generator and flowing through copper tubes of low-pressure generator ,and concentrated to form strong solution, and to produce more refrigerant vapor.
    Refrigerant vapor is condensed in the condenser to become water, which enters evaporator through throttle unit. Refrigerant water is distributed over the tube bundles of evaporator by evaporator pump, and evaporated under vacuum by absorbing the heat of chilled water, resulting in a lower temperature. Strong solution is distributed over the tube bundles of the tow obsorbers through solution distributor to obsorb the refrigerant vapor coming from the evaporator, and weak solution is produced.
    Refrigeration cycle is the cycle of refrigerant water, which is changed from liquid state to vapor ,and then from vapor to liquid state, and solution cycle with solution changed from strong to weak and vice versa, two cycles are repeated to to produce cooling effect continuously, high and low temperature heat exchanger are provided to improve the heat efficiency by exchanging heat between strong and weak solution,
    مبدأ التبريد
    يتم ضخ المحلول الضعيف التركيز (محلول الليثيوم برومايد) بواسطة مضخة الي مولد الضغط العالي ، حيث يتم تسخينة في مولد الضغط العالي بواسطة البخار القادم من auxiliary steam header عملية التسخين هذه تفقد المحلول بعض الماء عن طريق التبخر و يسمي البخار الناتج من عملية التسخين هذه (بخار التبريد) و يتحول المحلول من محلول ضعيف التركيز الي محلول متوسط التركيز.
    يعاد تسخين المحلول المتوسط التركيز في مولد الضغط المنخفض بواسطة بخار التبريد المنتج في مولد الضغط العالي ، والذي يتدفق من خلال أنابيب النحاس في مولد الضغط المنخفض ، و يزيد تركيزة و يتحول الي محلول قوي التركيز ، و يتم إنتاج مزيد من بخارالتبريد .
    بخار التبريد الذي تم إنتاجة يتم تكثيفة في المكثف الي ان يتحول الي مياه, تسمي (مياه التبريد) ، والتي تدخل الي المبخر خلال وحدة خنق,و يتم توزيعها اي (مياه التبريد) علي أنبوب المبخر بواسطة مضخة ، وتتبخر في ظل فراغ (ضغط سالب ) بواسطة امتصاص حرارتها ، مما يؤدي إلى انخفاض درجة حرارتها. المحلول القوي التركيز يوزع على أنبوبي الماصيين لإمتصاص بخار المبردات القادم من المبخر ، وينتج محلول ضعيف.
    دورة التبريد هي دورة الماء المبرد ، والتي تتغير من الحالة السائلة إلى بخار ، ثم من بخار إلى الحالة السائلة ، ودورة المحلول هي تغير حالة المحلول من القوي الي الضعيف ، والعكس بالعكس ، وتتكرر دورتين للتبريد لانتاج تأثير مستمر ، درجة الحرارة المنخفضة و العالية للمبادل الحراري لتحسين كفاءة الحرارة عن طريق تبادل الحرارة بين المحلولين القوي و الضعيف .
  3. [23]
    mazin s y
    mazin s y غير متواجد حالياً
    رد: دراسة كاملة عن الشلر
    اخواني مهندسي التبريد
    لدي عده شلرات سعه كل منهم 750 طن تبريد ونستخدم ابراج التبريد المفتوحه لتبريد مياه المكثف وانتم تعلمون ان مقدار المياه الفاقده في هذا النوع عاليه جدا اضف الى ذلك كميه المواد الكيماويه المتسخدمه لمعالجه المياه المذكور
    ارغب باستبدال النظام المفتوح ينضاام مغلق للتغلب على خسائر المياه اود مساعده اخواني المهندسين المعنيين في ذلك علما باني مهندس كهرباء ومعلوماتي في مجال التبريد خبره عمليه والقليل من المطالعات الشخصيه
    الارقام المتوفره لدي ارجو ان تساعدكم في اقتراحاتكم وهي ما يلي
    سعه الشلر 750 طن
    درجه الحراره الداخله 90 فهرنهيت
    الحراره الخارجه 82 فهرنهيت
    كميه المياه الداخله لبرج التبريد 300 جالون امريكي/ ساعه
    معدل حراره البيئه المحيطه 42 درجه مئويه
    ارجو المساعده ان امكن وتحياتي مقدما للجميع
  4. [24]
    دعيبس
    دعيبس غير متواجد حالياً
    أرجو الأفادة عن عمل كلا من ال fcu و ahu وهل يعملا في نفس الشبكة أم لكل منهما شبكة منفصلة . جزاكم الله خيرا
  5. [25]
    nofal
    nofal غير متواجد حالياً
    عضو فائق التميز
    Received: 99
    جزاكم الله خيرا .
