التروس واستخداماتها *gears
النتائج 1 إلى 10 من 19
    الصورة الرمزية حسن هادي
    حسن هادي
    حسن هادي غير متواجد حالياً
    خلال متابعتي لبعض مواقع النت لفت انتباهي من خلال موسوعة الويكابيديا الشرح لهذا الموضوع لذا ارتأيت ان انقله في الملتقى لكي يتسنى لمن يبحث من الاخوة الاعضاء في الملتقى ان يجده جاهزا **ومن الله التوفيق
    حسن هادي
    Differential (mechanical device)
    A cutaway view of a car final drive unit which contains the differential
    حسن هادي
    روابط فعالة ////////////
    *******s
    [hide]
    حسن هادي
    Purpose
    حسن هادي
    [edit] Epicyclic differential
    Epicyclic gearing is used here to apportion torque asymmetrically. The input shaft is the green hollow one, the yellow is the low torque output, and the pink is the high torque output. The force applied in the yellow and the pink gears is the same, but since the arm of the pink one is 2x-3x bigger the torque will be 2x-3x higher.
    An epicyclic differential uses epicyclic gearing to split and apportion torque asymmetrically between the front and rear axles. An epicyclic differential is at the heart of the Toyota Prius automotive drive train, where it interconnects the engine, motor-generators, and the drive wheels (which have a second differential for splitting torque as usual). It has the advantage of being relatively compact along the length of its axis (that is, the sun gear shaft).
    حسن هادي
    اليكم الرابط ارجو ان يكون مفيدااااااااااااااااااااااااا
    http://en.wikipedia.org/wiki/Differential_(mechanics)
    حسن هادي
    حسن هادي
    حسن هادي
    Clipart illustrations of a simple machine, gears. Gears are used by connecting them to an axle, and using the interconnecting cogs to move other gears or parts of a system. Their mechanics are similar to the wheel and axle.
    Clock, Wheels of a
    A clock is run by wheels. Each wheel turns another to keep the clock running....
    Cog-wheel
    "A small projection in machinery, used to impart motion. C. wheel, a wheel having cogs on its circumfrence." — Williams, 1889...
    Crown-wheel
    A wheel with cogs or teeth at right angles to its plane....
    Drill, twist bit
    Twist drill bit....
    Epicycloidal Teeth
    "Epicycloidal teeth, teeth for gearing cut in the form of an epicycloid." -Whitney, 1911...
    Epicycloidal Wheel
    A wheel or ring fixed to a framework, toothed on its inner side, and having in gear with it another toothed wheel of half the diameter of the first, fitted so as to revolve around the center of the la...
    Epicycloidal Wheel
    "Epicycloidal wheel, a wheel or ring fixed to a framework, toothed on its inner side, and having in gear with it another toothed wheel, of half the diameter of the first, fitted so as to revolve about...
    حسن هادي
    Gearing
    A train of wheels for transmitting and varying motion in machinery....
    Gears
    "It is found preferable, therefore, when a great difference of velocity is required, to use a combination of wheels, of moderate size. In the following figure, three wheels are seen thusly connected....
    Gears
    A pinion and spur gear meshed together. ...
    Mitre-wheels
    "2 wheels revolving in contact, but in different planes, so as to transfer motion from one plane to another." — Williams, 1889...
    Planet wheel
    The exterior wheel of the sun and planet motion of gears. ...
    Rack and pinion gears
    A gear system with a rack gear and small pinion gear. Used to conovert circular motion to rectilinear motion. ...
    Rack and worm gears
    A gear system with a rack gear and worm gear. Used to conovert circular motion to rectilinear motion. ...
    Rag-wheel
    A wheel furnished with projecting pins on the rim, which fit into the links of a chain....
    Ratchet-wheel
    "A circular wheel, with teeth on the circumference, by which it can be moved or its motion stayed." — Williams, 1889...
    Righthand spiral gears
    Righthand spiral gears...
    Rotary pump
    "The design is to produce a continued stream, by simply turning it into a crank, thus converting the piston into cog-wheels and the vertical motion into a rotary one." -Comstock 1850...
    Sprocket
    A sprocket and chain....
    Sprocket
    Sprocket
    Sprocket
    Spur-wheel
    "A wheel having teeth projecting radially from the circumference." — Williams, 1889...
    Wheel, Cog
    A wheel having teeth or cogs, used in ransmitting motion by enguaging the cogs of another similiar wheel or a rack. ...
    Wheel, Core
    A wheel having recesses into which cogs or another wheel may be inserted, or into which cogs may be driven....
