اريد شخص خبير ب steel design باسرع وقت
النتائج 1 إلى 3 من 3
    الصورة الرمزية نغم 2008
    نغم 2008
    نغم 2008 غير متواجد حالياً
    هاله النجار
    هاله النجار غير متواجد حالياً
    الصورة الرمزية هاله النجار
    طيب اعرضى الاسيمنت يمكن يكون حد بيعرف حاجه فيساعدك
    ونوع الديزاين ايه؟؟
    انا طالبه برضو بس اخر سنه
    يمكن اقدر افيدك
    وربنا يوفقك ياقمر
    نغم 2008
    steel design
    In Figure 3 below, a C 15 x 33.9 tension member is bolted to a 16”x5/8” gusset plate. The maximum factored tensile load used in the design of the tension member (Pu) is equal to 200 kips.Both of the tension member and the gusset plate are made of A36 Steel. The connection between the member and the gusset plate is made using 1”-diameter bolts.The owner has decided to change the usage of the building which will result in an inctrease of the loads about (20%) of the original load values used in the original design of the building. Do you recommend the use of this tension member to carry the expected new loads? Why?
