الزعيم يتالق رغم انف الشعب Cype 2010.d
النتائج 1 إلى 10 من 49
    زعيم الاسكندرية
    زعيم الاسكندرية غير متواجد حالياً
    Received: 262
    Given: 264
    السلام عليكم ورحمة الله وبركاته ،،،،
    رغم انف الشعب بملتقى المهندسين العرب
    الزعيم يتالق ويعلن التحدى ويهدي الشعب هذه المشاركة
    استمتعوا باوقاتكم ولا تنسونى من صالح دعائكم
    Cype 2010.d
    info:
    The last version released in September.
    CYPECAD is the software for reinforced concrete and steel buildings which provides the spatial
    analysis, structural element design, reinforcement and section edition, and construction drawings of the
    structure.
    It carries out the analysis of three dimensional structures composed of supports and floor slabs, including
    their foundations, and the automatic design of reinforced concrete and steel elements.
    With CYPECAD, the engineer holds a precise and efficient tool to resolve all the aspects related
    to the analysis of the structure of any type of concrete as well as being adapted to the latest international Codes.
    Analysis and design of reinforced concrete and steel structures made up of : columns, walls and shear walls;
    concrete, steel and composite beams; joist floor slabs (generic, reinforced, prestressed, in suit, steel, and open- web),
    hollow core plates, composite slabs, waffle slabs and flat slabs; mat foundations or pad footings, pile caps or foundation beams;
    Integrated Metal 3D jobs (steel, aluminum and timber sections) with 6 degrees of freedom per node, including the design and optimization of sections.
    Design and analysis of three dimensional structures made up of nodes and bars, with simple and composite section design and optimization.
    Three dimensional bar structure project with steel, aluminum and wooden sections, including foundations (pad footings, pile caps, strap and tie beams) and bracing systems against lateral loads, allowing ties that work only in tension.
    Joint and base plate design for metallic structures.
    Geometric generator of rigid portal frames and simple and multiple trusses. Automatic generation of wind and snow loads.
    Design and optimization of roof and lateral purlins. Exports the geometry and loads to the program Metal 3D.
    Analysis, check and design of reinforced concrete retaining walls with their corresponding strip foundation (footing or pile cap).
    The analysis includes applied seismic loading and global stability check (slip circle).
    Analysis, design, and Code check of embedded retaining walls. The types of walls available are the following:
    · Generic material.
    · Concrete slurry, reinforced by panels.
    · Reinforced concrete secant piles.
    · Mini piles.
    · Steel sheet piles.
    Different types of support elements (active and passive).
    Design and check of reinforced concrete box culverts, rectangular or trapezoidal, single or multiple cell, enabling crossings below
    roads and drainage works. Free polygonal outline on plan and section.
    screenshots:
    Download Links:
    Code:
    ftp://ftp.cype.net/2010/cype2010d.zip
    The crack:
    Code:
    http://rapidshare.com/files/286796016/c2010d.rar.html
    Password:
    Code:
    RAR Password for crack: FromCivilEA
    فاطمةالمهاجرة
    إستشارية الهندسة المدنية
    الصورة الرمزية فاطمةالمهاجرة
    Received: 164
    Given: 149
    حسنا متالق ساقيمك من قبل ان ارى برنامجك اتمنى انه يستحق ذلك لانني لا اعرف كيف اسحب التقييم اذا اكتشفت العكس
    م. الباحث
    م. الباحث غير متواجد حالياً
    ارجو من الاخ الكريم اعادة رفع الكراك على موقع اخر ولكم جزيل الشكر
    life for rent
    life for rent غير متواجد حالياً
    Received: 19
    اعتقد ان جزاة الراجل الشكر والتقدير..............حتى لو لم يكن يستحق البرنامج.....ولكنه الف شكر للباشمهندس على عمله الطيب جزاه الله خيرا
    زعيم الاسكندرية
    Received: 262
    Given: 264
    الموضوع سهل جدا
    بامكانك تسجيل مشاركة سلبية واعطاء تقييم سلبى مستقبلا
    محمد 977
    محمد 977 غير متواجد حالياً
    تسلم ايدك
    مشكووووووووووور يا حضرة الزعيم
    تسلم الايادي و نتمنى منك المزيد و المزيد من الـتألق
    الف الف شكر
    mohy_y2003
    mohy_y2003 غير متواجد حالياً
    الصورة الرمزية mohy_y2003
    Received: 350
    Given: 439
    الموضوع سهل جدا
    13-10-2009 03:41 am
    ربنا ما يجيب تقييم سلبي يا اخت فاطمه - وبعدين يا اخت فاطمه لو طلع البرنامج غير جيد من وجهة نظرك يبقي خلاص يعوض ربنا عليكي في التقييم - يعني مش لازم ترجعيه وتاخدي ثمنه تاني ههههههههههه ولا ايه رايك - وخدي بالك يا اخت فاطمه ان سياسة الاستبدال خلال 24 ساعه فقط وده معناه انك مش ها تلحقي تشغللي البرنامج اصلا يعني من الاخر يعوض عليكي ربنا في التقييم لو كنتي قيمته ولو لم تكوني قيمتي الزعيم فانا رايي انك تنتظري شويه لحين التاكد من جودة المنتج
    ومتشكرين يازعيم ولو اني خايف ان البرامج الكتير دي ممكن تعمل اثر سلبي علينا وكله يدخل في بعضه وتبقي مجزرة وثورة قد تؤدي الي زعزعه الاستقرار في حكم معاليك
    الإمام محمد الغزالي
    hassananas
    hassananas غير متواجد حالياً
    Received: 224
    Given: 6
    فاطمةالمهاجرة
    Received: 164
    Given: 149
    اهلا اخ محي ليش هو انا قدرت انزلو طبعا لا, يبدو انو ملف كبير وزعيمنا قالنا استمتعو, قال استمتعو قال
    hassananas
    Received: 224
    Given: 6
    ارجو من الاخ الكريم اعادة رفع الكراك ولكم جزيل الشكر
