Calc area of heat transfer using HYSYS for
النتائج 1 إلى 10 من 14
    مهندس تحت التجربة
    مهندس تحت التجربة غير متواجد حالياً
    If you have HYSYS process simulator but without the Heat exchanger package you can estimate the area of heat transfer using the following simple method.
    First you need to identify what flows in the shell side and what flows in the tube side.
    Second you need to identify regions within the heat exchangers:
    If you have phase change anywhere in the unit, phase change can be either single component phase change or mixture phase change. If you have a single component phase change, use average values for the heat transfer coefficient (between 2000-5000).
    If it was a multi component phase change use a normal flow correlation. It will overestimate the real area but it will put the design in the safe side.
    Now for normal flow in the pipes use the Seider Tate correlation
    Eq.4
    h: Heat transfer coefficient (W/m2.K)
    μ: Viscosity of the furnace effluents measured at the temperature fluid (Pa.s)
    μw : Viscosity of fluid measured at the temperature of the wall (Pa.s)
    k: Thermal Conductivity of the fluid W/m.K D: Inner Diameter of Tube (m)
    G: Mass velocity (Kg/m2.s) Cp : Heat capacity ( J/Kg.K)
    For normal flow in the shell side use the Zhukauskas correlation shown below for Reyonlds number between 200,000 and 2,000,000
    Eq.5
    μ: Viscosity of the cooling water measured at the temperature fluid (Pa.s)
    Re : Reynolds number
    k: Thermal Conductivity of the fluid W/m.K D: Outer Diameter of Tube (m)
    Subscript (w) : Determined at wall temperature.
    Now here comes HYSYS part
    In HYSYS simulator enter the heat exchanger design form. Press the Design tab and use the weighted mode in the Heat exchanger design. Then in the intervals section put 100 intervals in both sides.
    Then go to performance
    Setup
    Add vapor properties (heat capacity, thermal conductivity, viscosity) if you have vapor flowing the side or heavy liquid properties if you have liquid flowing in the side. Add the properties both in shell side and in tube side.
    Then go to tables
    Press the radio buttons for vapor and heavy liquid properties
    Copy the properties to an already prepared spread sheet which has the correlations calculated based on properties. (see top correlations)
    You can use the following spread sheet, just copy the properties in the specific columns and specify the diameters.
    The spread sheet calculate the area automatically
    من مواضيع مهندس تحت التجربة :
    مهندس تحت التجربة
    عذرا على عدم وضوح الملف انظر هذا الملف
    • نوع الملف: doc area.doc‏ (25.5 كيلوبايت, 253 مشاهدات)
    صابرسعيد
    صابرسعيد غير متواجد حالياً
    الف شكر يا بشمهندس بس لو سمحت لو عندك النسخة الجديدة من Hysys 2004
    تبعتت رابط ليها او تبعت كلمة سر الدخول على الموقع للتعليم مع الشكر
    مهندس تحت التجربة
    السلام عليكم و رحمة الله
    أظن يوجد في المنتدى رابط لتنزيل برنامج HYSYS 3.2
    و أحببت أن أنبه أن معادلة حساب معامل انتقال الحرارة في ال shell تعتمد على أعلى مقدار لل mass velocity (G) و في البرنامج (G) تحسب بافتراض أن المادة تعبر خلال أنبوب قطره يعادل القطر الخارجي لأنابيب مبادل الحرارة .
    و يمكن الحصول على تصميم مبالغ أكثر بجعل (G) تحسب اعتماداً على قطر المبادل الحراري كله
    و شكراً
    lordfayez1212
    lordfayez1212 غير متواجد حالياً
    اريد من الأعضاء المساعدة بكتب في دباغة الجلود الطبيعية والصباغة
    وارسال الكتب و الابحاث lordfayez1212*************
    thank youuuuuuuuuuu]
    lordfayez1212
    need help by books in chmestry of tanning and thanks much
    saaaaaam
    saaaaaam غير متواجد حالياً
    شكرا للجميع
    كيميا
    كيميا غير متواجد حالياً
    يعطيكم العايفية مهندسينا
    الفنك
    الفنك غير متواجد حالياً
    Thaaaaaaaaaaaaaaaaaaaaaks
    هشام جيني
    هشام جيني غير متواجد حالياً
    مشكووووووووووووووووووووووووووووووووور
