بحث فى engineering for sustainability
النتائج 1 إلى 4 من 4
    الصورة الرمزية Eng-Maher
    Eng-Maher
    Eng-Maher غير متواجد حالياً
    مشرف قسم الهندسة البحرية.
    Received: 103
    Given: 408
    ENGINEERING FOR SUSTAINABILITY
    concept of sustainability arises because of the
    fi nite and limited resources of the world. This limitation is
    exacerbated by the continual growth of the world’s population,
    whose demand on resources increases signifi cantly with time.
    To overcome this problem, sustainable development, which is
    defi ned in the Brundtland Report as “development that meets
    the needs of the present without compromising the ability of
    future generations to meet their own needs” is imperative. It
    refers to the optimal utilization of these resources with the
    aim of maximizing their usage effectiveness while at the
    same time minimizing the adverse effect of their use on the
    environment. This includes conservation and enhancement
    of resources by gradually changing our approach towards the
    development and utilization of technologies. The principle
    of sustainability must be translated into practical engineering
    projects; otherwise, resources may be completely depleted or
    the environment may suffer irreversible damage.
    In a discussion paper
    1 presented by the President of the
    Institution of Professional Engineers New Zealand (IPENZ)
    under the auspices of the IPENZ Presidential Task Committee
    on Sustainability in 2003-04, four key sustainability factors
    for engineers in the profession were identifi ed:
    1. To manage changes in the environment (both local
    and global) resulting from engineering activities which
    threaten the continued viability of the planet;
    2. To ensure the equal distribution of resources and safety
    of engineering activities for both current and future
    generations;
    3. To ensure that the skills of professional engineers in
    problem solving are carried out holistically; and
    4. Where practicable, to make good existing problems
    caused by past failures to follow sustainability
    principles.
    للتحميل
    http://www3.ntu.edu.sg/CEE/research/.../2008/rb21.pdf
    odwan
    odwan غير متواجد حالياً
    عضو داعم للملتقى
    الصورة الرمزية odwan
    Received: 11
    بارك الله فيك أخي المشرف وتقبل تقديري مع فائق إحترامي
    وفق الله الجميع لما يحب ويرضى
    م . أيمن محمد عدوان
    grasp, the more you need
    محمودشمس
    محمودشمس غير متواجد حالياً
    عضو متميز جداً
    Received: 14
    بارك الله فيك اخي ..................
    Eng-Maher
    Received: 103
    Given: 408
    مشكورين جميعا بارك الله فيكم
    الحمد لله
