ال Sensors للمحرك _ طلب معلومات
النتائج 1 إلى 2 من 2
    الصورة الرمزية Ayman
    Ayman
    Ayman غير متواجد حالياً
    Received: 10
    اود معرفة معلومات عن ال Sensors للسيارات الجديدة
    حدث كسر بمفتاح السيارة و لم تعمل بسبب ذلك و بعد اصلاح المفتاح لا تزيد عدد لفات الموتور عن 3000 بسبب هذا الSensor و طبعا لا بد من برمجته في الوكاله
    لماذا لا نستطيع برمجته؟
    السيارة هوندا أكورد
    ramzi khashan
    ramzi khashan غير متواجد حالياً
    الصورة الرمزية ramzi khashan
    (automotive engi (sensors
    the sensors consists of 2 type
    the sensor is a device that converts the physical or chemical action to electrical signal
    types of sensors
    1. active sensors
    2. passive sensors
    • the active sensor like the genrator needs no electrical source only when apply some physical or chemical or heat ,it produce electrical signals
    • the passive sensor needs electrical source from ecu about 5 volt
    the sensor output signal may be voltage or current or frequency this output signal go to the ecu in order to reshape it or modify it according to the sensor and and its role .
    • example about active sensor : wheel speed sensor it consists of iron core rapped with windding and when the toothed wheel rotates an electrical signal produced.
    • example about passive sensor :its the oxygen sensor that is placed in the exhaut mainfold it needs 5 voltage ref from ecu this sensor consists of zerconium material that when we apply it to co2 it changes the ref voltageto less than 5 volt then the ecu will treat this signal and can control the injector opening time
    • but with respect to the key programming,i think you can find it in the alldata ok
